ModernMuseum
01-14-2012, 03:22 PM
Hopefully you guys can help, because I am at a loss and my car is at a buddy's house.
Engine: cammed LS3
Fuel Pump: Walbro 255
Regulator/filter: Corvette regular that everyone uses (not sure of model number)
Tank: DSE (Mechanical fuel pump style) tank
https://static1.pt-content.com/images/pt/2012/01/6139749075_4e9e98b999_z-1.jpg
The car was dyno'd on a previous pump: a Walbro 255 from ebay and I got about 3 hours out of it before it failed. Once I got the car home from the dyno shop, within a day or so it started sputting on take-off. Eventually it got to where I could't even drive around the neighborhood and wouldn't speed up past idle. Due to the ridiculously loud whine of the Walbro, I thought it might be a bad pump.
I replaced the pump and it still whined a little, though the problem seemed to be fixed except for a very slight hesitation on take-off. Yesterday was the first day that the car was legal, so I took it out for a spin. Today, about 3 total combined hours or so after running the new pump (hell, maybe even only 2 hours), the car started sputtering again and now I can barely putter down the street. It falls on its face upon take-off and I'm stranded in town.
The pump/regulator setup that I'm using (below) may be a little obscure, but quite a few people have told me that it should work without issues. Basically, instead of sending the return line back to the tank, I am sending it back to the pump suction. I guess I could order a new pump just to get the car home, but I'd like to stop throwing money at the problem, though I'm sure I'll need a new pump anyway.
I put a mechanical fuel pressure gauge on the rail and it is reading about 55 pounds constantly. I am not sure what the pressure was right after I put the pump on; could have been more or could have been the same - not sure. What pressure are these things supposed to run? Is it a problem with the Walbro, perhaps the regulator is bad, or is there a problem with my plumbing? I would have run a return back to the tank, but there is no port for a return on the DSE tank (mechanical fuel pump version).
Help, I'm stranded!
Engine: cammed LS3
Help, I'm stranded!
