View Full Version : Ridetech gas cap question
spacepirate
01-12-2012, 09:10 PM
Hey guys,
I've got a 68 Camaro and recently purchased the RideTech gas cap kit when they were running the deal. My question is do I need to vent it? I've got a standard tank with a 350 SBC. New to this stuff and ya gotta start somewhere.
spacepirate
01-13-2012, 10:27 AM
Does anyone have a 68 with a standard tank?
Bryce
01-13-2012, 10:46 AM
Is the cap sealed? The tank needs to vent somehow.
spacepirate
01-13-2012, 11:45 AM
<<http://www.ridetech.com/store/1967-68-camaro-gas-cap-black-anodized.html>>
Here is the set up and I purchased it with the optional vent kit. I was just curious if I needed to install that portion.
Bryce
01-13-2012, 12:08 PM
Does your tank have a vent?
My stock gas tank (1965 ford falcon) has no vent but has a vent in the filler neck. You need one vent in the system, either the tank or the cap or the filler neck.
spacepirate
01-13-2012, 12:29 PM
Copy that. I'll take a look this weekend. Thanks guys.
01-15-2012, 07:38 PM
The cap is not vented. You need to add the vent fitting to the filler neck as supplied in the kit. Stock 68 tanks used a vented cap.
spacepirate
01-15-2012, 08:53 PM
Thanks David.
ROEINONDUBS
01-17-2012, 02:08 PM
Hi Dave qwk question if I ran a non vented caP on my 68 camaro would it make it seem as if I ran out of gas even if the tank was full?
Bryce
01-17-2012, 02:14 PM
Yes, your pump would be trying to collapse the tank. Since you are pulling gas out of the tank you will need to replace that volume with air.
ROEINONDUBS
01-17-2012, 05:12 PM
Ok thanks I don't knw why they would have sent me a non vented cap
I think all there caps are non-vented just drill a small hole on the top of the neck and tap it for a brass or plastic fitting and then run a hose to a small exit hole in the trunk floor, and its vented
01-20-2012, 08:50 PM
The cap itself is not vented, It may be a Motorcycle cap or some other application. Cars built after 1971 or 72 had Charcoal canisters for Vapor Recovery and the tank was vented to it, so they did not/do not need a vented cap. The cap did have a pressure relief in it though.
ROEINONDUBS
01-22-2012, 10:28 PM
I had purchased a stock style ss cap that was suppose to be for my car but it doesn't look like its vented, and after it went on my car had fule problems
01-22-2012, 10:42 PM
Every SS cap I've seen is vented. There should be a pressure relief/vent valve visible right in the center of the cap.
