View Full Version : Killer deal on the ultimate stock 1st Gen F-body subframe
Proforged
01-12-2012, 10:56 AM
For SEMA 2011, we set out to use the best bolt-on parts available in the aftermarket to create the ultimate upgraded stock subframe - and we're offering a killer deal on it to one lucky 1st Gen owner. The subframe has never been installed - everything is brand new.
We started with a brand new, OEM-replacement subframe from AMD. The performance upgrades are centered around the all-new Proforged CamberTech Tubular Upper and Lower Control Arms. The geometry-corrected upper arms utilize a stock-car style ball joint and the lower arms feature Delrin bushings and a truss-style coil over mount for full shock travel. The Tubular Upper and Lower Control Arms won't be available until March 2012 - so you'll be the only one on the block running this setup until then.
We're not selling anything off this subframe individually, but we've listed the prices below so you can see how much the whole package would cost to replicate. The package price is at the bottom.
Specs:
AMD OEM-replacement subframe ($1149)
Proforged CamberTech Tubular Upper Control Arms ($649 - estimated)
Proforged CamberTech Tubular Lower Control Arms ($599 - estimated)
Ridetech Triple Adjustable CoilOver Shock System ($1350)
Ridetech Tall Spindles ($350)
DSE Camber Shim Track Kit ($85)
Hellwig Elite Series Front Sway Bar ($156)
Proforged Billet Aluminum Sway Bar Brackets ($89)
Delphi 670 Steering Box ($599)
Proforged Inner Tie Rod Ends, Idler Arm, and Pitman Arm ($225)
Proforged Bumpsteer-corrected Tall Outer Tie Rod Ends ($99)
Proforged Billet Aluminum Tie Rod Adjusting Sleeves ($69)
Totally Stainless High Strength Stainless Steel Hardware ($269)
PST Forged Aluminum Hubs and Brackets for C6 Corvette Brakes ($399)
6-Piston C6 Z06 Corvette Calipers ($983)
14" Disc Brakes Australia 5000 series two-piece rotors ($864)
Right Stuff Detailing Stainless Steel Brake Lines ($89)
Total - $8023
Special Pro-Touring.com Price - only ONE available: $5999 INCLUDING freight to the 48 US States!
This is a first-come, first serve deal. The savings is well over $2000 when you factor in shipping costs.
Here are a few photos - the only thing that has been changed since these photos is the addition of the Ridetech Tall Spindle:
Thanks for looking, and let us know if you have any questions!
BlackPearl
01-22-2012, 06:22 PM
Zack,
What could I expect as a result of this set-up compared to my current set-up? I have the stock Sub-frame with all the Hotckiss up-grades. Also, I currently already have the Bear 6P brakes and would those transfer over without issue?
Bob
Proforged
01-23-2012, 05:05 AM
Zack,
Bob
Hi Bob,
You would notice a large handling improvement. The Hotchkis setup is great - don't get me wrong - but it still has the backwards factory camber curve. Our setup is designed to correct that backwards camber curve to deliver a very significant improvement in handling.
There are a few main differences:
1. You're starting with an all-new subframe - you original subframe has 40+ years on it. I'm sure you have some degree of frame sag etc with your original unit.
2. Our upper control arms are caster-slug adjustable, meaning you can dial in a lot (or a little) caster. I believe the Hotchkis arms do not have this.
3. Our upper arms use a extra-tall upper ball joint, which corrects the camber curve. This is the single biggest difference. A setup that uses stock ball joints and stock spindles does not change the dynamic suspension geometry.
4. This uses a coil over setup vs. the Hotchkis is conventional shock and spring. Our setup will be lighter.
5. Not sure what steering box you're running, but we have the Delphi 670 box on here - the best one you can get.
6. Yes, you can absolutely use your Baer setup!
1Bad68camaro
01-24-2012, 06:50 PM
Is the subframe painted or powdercoated?
UMI Tech
01-24-2012, 07:02 PM
Zack:
I need this for R&D!
ramey
Proforged
01-25-2012, 06:51 AM
Zack:
ramey
Should I just put it on the credit card? :)
Proforged
01-25-2012, 06:55 AM
I'm guessing that they electrocoat it, which is more common for OEM-type parts like this. I don't think it's painted traditionally, and it doesn't look like powder coating to me. I don't see any specs on the coating in their literature.
It's a nice finish.
68Formula
01-25-2012, 07:49 AM
Wow, great deal. Wish this was up a few years ago when I was doing my upgrades.
Gitter Dun
01-25-2012, 02:58 PM
Any details on roll center changes?
Proforged
04-30-2012, 10:31 AM
Still available!
Roberts68
05-05-2012, 04:36 AM
I sent you a PM about availibility of your upper control arms 5 days ago but didn't hear back. Were these one off or will they be coming to market?
Btt for you. GLWS
MK69RSSS
05-05-2012, 08:29 PM
Is this sold. Very interested cash buyer?
SLO_Z28
05-05-2012, 11:09 PM
Also curious. Whats the roll center, instant center, scrub radius, and bump steer look like?
Proforged
05-07-2012, 07:37 AM
Hi all,
The subframe has been sold!
With regard to the control arms - we are running production on the ball joints still. We'll keep everyone advised as to when they are ready to ship - probably a couple months still at this point.
Geometry-wise - these will end up somewhere in the middle of a 0.50" taller ball joint and a tall spindle (usually 1.50" taller) - the ball joint in our arms is 0.90" taller.
If you are running tall spindles, we will use a standard height ball joint pin - in this case, the main benefit to these arms will be more wheel clearance, more caster, and low-friction bushings.
Hope this helps!
