View Full Version : Project 'Mouse Trap'...Another 67 Camaro
makoshark
01-12-2012, 06:10 AM
After many years into my build, I decided I will chronicle it here. I tore into her back in 02 after a few years of already owning and driving the car. It was a 50 footer back then, but had a lot of solid and straight sheet metal on her. My progress was/is slow, kinda like my learning curve. Enough of the boring details...
She needed new quarters and outer wheel houses. I scored a set of NOS quarters and installed them along with NOS outer wheel houses. I had to replace the passenger inner wheel house along with part of the passenger shock tower. I also had to replace the center trunk pan. I replaced both passenger and driver side floor boards as well. The full floor was not out when I replaced the floors. I also had to replace both toe boards. The dash top was rusted, so it came out, but I have yet to weld the new one in. The rear window filler panel had to be replaced along with the rear trunk lid. I despise this trunk lid I have, but I will make it work. All of the items I just described in replacing has been done over the course of about 5 years. The project stalled for a few years due to a busy schedule with work and family. Economy has hurt my business, so now I have a lot more time to work on her.
What I have done recently is installed DSE subframe connectors. DSE smooth firewall panel and I am in the process of building a custom console that is a retro version of the 67 original console. I like my tunes and am an audiophile, so I decided to utilize some unused space in the kick panels to place some 7" speakers. I designed and manufactured a sealed box out of 16 gauge sheet metal and did some massaging to the original hole in the kick panel area. This is where I am at in the build to date.
This is stage 1 of the project. Right now the goal is get it painted and assembled as well as drivable. Stage 2 will entail a new front and rear suspension along with bigger wheels and minitubed.
makoshark
01-22-2012, 01:50 PM
Small update...
makoshark
01-22-2012, 01:59 PM
Anyone here familiar with -an fittings. I'm sure they are. Please chime in. On my B&M trans cooler, I can only engage 3 threads of the 1/2" NPT to -6an fitting. That is only hand tight. Will they tighten up more with a wrench and not damage anything? Also, the trans cooler on the radiator is only allowing me to engage 1 thread of the 1/4" to -6an fitting, again only by hand. Will it too tighten up more with a wrench? Or do I need to go to a different size fittings for the trans coolers? The B&M cooler is too large, though, for a 3/8 NPT fitting. Already tried. I don't have an 1/8" npt fitting here to check the cooler on the radiator.
Also, I can't remember, which line on the steering box is the pressure line and the return line? The one closest to the firewall or furthest from it?
TheBandit
02-20-2012, 01:12 PM
Those threads on the trans cooler and radiator may simply not be NPT. If you look down inside, do they have any kind of sealing surfaces for a flare or o ring fitting? They may be straight threads designed to accept a flare fitting. Ask the manufacturer.
Nice work on the kick panel speakerbox. The center console is looking good as well, although perhaps a bit heavy in all steel?
What are your suspension plans?
makoshark
02-20-2012, 01:27 PM
Thanks...I did manage to get the right fitting for the trans cooler on the radiator. It took some inverted flair fittings. Believe it or not, the console is no heavier than the stock one at this point. I still have a bit more metal to attach to it and am going to wrap it in vinyl when finished. Wood, fiberglass or whatever would be nearly as heavy as what I have going now. The speaker boxes took some work to design and fabricate, but I am very pleased with the outcome.
makoshark
02-20-2012, 01:31 PM
My suspension plans are to install the ATS Chicane front coil-over mount for the stock subframe and install the Ridetech AirBar with coil-overs on the rear. I also am going to have to mini tub the car. The wheels I bought are 10.5" wide for the rear and that was the only size I could get. Sucks having to mini tub because now I cannot use my 67 fold down rear seat. I'm going to have to sell all that as well as my Rally wheels with new trim and center caps as well as all new BFG rubber on them.
But I get to have these:D
makoshark
03-13-2012, 03:00 AM
Thought I'd post a few pictures of the updates I have made lately. Not a lot, but I have made a little progess. I've been waiting on parts to show up and my DSE deep tubs finally showed up yesterday. I can now continue with the mini tub and hopefully get it done this week.
Also, since I change my mind as much as a 14 year old girl trying to decide who to go to the dance with, I am changing my gauge setup and am also going with a 7" screen Nav unit
