View Full Version : Torque Arm 3 link Cantilever rear coilover idea
linkstar69
01-11-2012, 11:41 PM
Hey All, I have a pickup that I like to use as a bit of a low buck development mule for my Australian Chrysler Valiant (think Dodge Dart).
I've been thinking about a rear suspension upgrade for a while and would like to do something both interesting and functional and the idea of locating the shocks longitudinally along the chassis rails really appeals to me. (keeping weight both low and forward) I'm happy to do the fab work where required so I don't fear having to make the parts that don’t already exist.
My plan for the 3 Link is similar to the GM F Body torque arm set up but the links on the side would look like the letter L from the side. Disregarding the gussets. For the centre torque arm I'll probably just adapt an aftermarket piece like the sphoon ones.
I know there’s lots of clever people on here so I'd love to have my ideas pulled apart before I do any fab work.
Here's sketch I just did in an effort to explain my ramblings. (not in the drawing is some sort of diff centring device, I'd most likely run a watts link as thats whats under my leaf sprung dart)
https://static1.pt-content.com/images/pt/2012/01/cee1ae89-1.jpg
Thanks for looking
exwestracer
01-12-2012, 05:32 AM
A couple of things to do some more thinking about...
THe pivot points of the links (corner of the L) have to hold the links upright. THey can't be allowed to move side to side, or the springs will shove them whatever direction they feel like. All the spring knows is it wants to be LONGER... That means huge mounts and roller bearings or solid bushings at the corner, which means the links are restricted to pure vertical motion. The axle however, is going to want the links to twist so it can roll. Your only real option here is really big soft rubber bushings at the axle end. Did Ford ever sell twin I beam axle pickups with front leaf springs in OZ? If so, you'll know what type of rubber bushings I'm referring to?
The links themselves will be carrying all the weight of the rear of the vehicle. You can get away with this, but I would make a full triangle out of them, rather than leave half the link un-supported. Honestly, it's not the greatest idea for handling or load carrying. Kinda neat for being different, but not too practical.
Bryce
01-12-2012, 06:12 AM
I agree with Ray, the lower link chassis mount has to be a solid busing not a heim joint. I think this system will have lots of roll bind or at least roll resistance not due to roll center, CG and springs rate.
I will draw something up similar and post it here. It will reduce the roll bind and increase the fab but also increase the cool factor.
Bryce
01-12-2012, 06:38 AM
Here you go a quick sketch....
The lower link still carries all the rear weight of the car and needs to be designed to prevent beam bending.
01-12-2012, 03:46 PM
i like this set up too....
https://static1.pt-content.com/images/pt/2012/01/129_0901_23_zjeep_jk_wrangler_suspension-1.jpg
linkstar69
01-12-2012, 04:56 PM
The pivot points of the links (corner of the L) have to hold the links upright. They can't be allowed to move side to side, or the springs will shove them whatever direction they feel like. All the spring knows is it wants to be LONGER... That means huge mounts and roller bearings or solid bushings at the corner, which means the links are restricted to pure vertical motion. The axle however, is going to want the links to twist so it can roll. Your only real option here is really big soft rubber bushings at the axle end. Did Ford ever sell twin I beam axle pickups with front leaf springs in OZ? If so, you'll know what type of rubber bushings I'm referring to?
Thanks for the reply, very good points too. The design I posted would only work with something like a solid aluminum bushing at the front and as you mentioned the bushing ay the diff would need to be very soft to stop the whole thing from binding during travel. The other way to control side to side movement of the upper shock mount would be to make the upright of the L shorter but that would also change the ratio acting on the shock.
This one has to fall into the category of sometimes simple is not better and theres no use in being different for different sake, nice discussion.
linkstar69
01-12-2012, 05:03 PM
Thanks for chiming in Bryce, I was hoping you and exwestracer would make some suggestions as I always find your input very informative. The rational behind my original thinking was to see if a version of this type of suspension was viable without the bell crank but the points you both have made ring very true.
Plus I think the sketch you've posted could potentially be easier to package and still has everything low and forward of the axle.
linkstar69
01-12-2012, 05:08 PM
Yeah I love the pirate 4x4 message board just for the fab work and suspension design some of those guys pull off.
exwestracer
01-12-2012, 06:39 PM
Bryce, I think you'd still need a solid bushing in there somewhere to prevent the lower arm from rolling over to the side, no?
G-Rob
01-12-2012, 06:52 PM
Pretty sure that's a Jeep kit not a one off. Big bucks though.
linkstar69
01-12-2012, 07:27 PM
That does look more kit than fab but how many kits bolt in any way lol
hotrod56
01-15-2012, 10:21 PM
I am looking to do the same thing.
exwestracer
01-16-2012, 05:35 AM
hr56,
For a PT application, I think you'd want to move the bellcrank and shock assemblies closer to the ends of the axle housing. Keep in mind that the bellcrank pivots are still bearing all the rear weight, so that area of the frame has to be strong enough to carry the load. Just because the coilovers are laying down doesn't change the physics of where the load is transferred from the axle. Keep us posted, looks like a neat project.
linkstar69
01-16-2012, 09:49 PM
HotRod56 I cant see your pic for some reason....
Anyway I figured I'd keep this discussion going and throw some more questions out there. I've noticed while researching this stuff that quite a few guys who are building kit cars and imports are adapting bike coil overs. I think my application may be light enough with some effort to be able to use them as well with some lightening efforts.
While looking for shock options I stumbled onto some interesting info that I think is relevent to this thread.
First this Yamaha R1 Belcrank and dogbone. Keep in mind I've just been web surfing so I've got no idea of the size of these units but they look interesting.
https://static1.pt-content.com/images/pt/2012/01/ab428158-1.jpg
This linkage design is an interesting take on things I haddn't thought of.
https://static1.pt-content.com/images/pt/2012/01/b78ba3c5-1.jpg
As is this:
https://static1.pt-content.com/images/pt/2012/01/ec510a7f-1.jpg
I also stumbled onto this article that gave some really interesting comment in regard to placement etc
http://www.promecha.com.au/leverage_linkages.htm
Hotwhilz
01-17-2012, 04:02 AM
This bike shock Idea crossed my mind, this will be intersting, lots of potential and those shocks are often double adjustable and the spring can always be tighten up for extra load, Guys, please feel free to post pros and cons on this set up above.
exwestracer
01-17-2012, 08:11 AM
The bike linkage (in stock form) tends to be very progressive. This stuff was tried on F1 cars back in the late 60s. The spring rate is harder to predict, as shock travel changes for each inch of wheel travel.... Hmmm, like stock coils or leaf springs I guess...
If you plot out spring movement vs wheel movement it should be easy enough to figure out what springs you need. The bike shocks work fine, but the base damping may need to be altered. With a stock bike shock, I'm not sure how easy that would be.
Hotwhilz
01-17-2012, 01:41 PM
Wonder if 4" total travel would be a bit on the short side for street use? Wich end of the link would need to be lenghtened / shortened to be more like 6-8" wheel travel, hard to figure with my small head!
Manageable?
Let's hear it! Got some showa shocks with external reservoir, they may do but the travel (4" inch ) got me wondered!
Bryce
01-17-2012, 01:46 PM
I only have 4" of rear travel on my falcon. Its okay for me. My DD 95 mustang has 1" of travel before it hits the bumps. With the correct spring rate and shock it works just fine, the huge bumps are a hassle.
exwestracer
01-17-2012, 03:11 PM
Manageable?
Move the shock eye closer to the rocker pivot. Less shock movement per inch of wheel travel.
linkstar69
01-18-2012, 01:13 AM
Ray, you are right about the bikes having progressive linkages but the good part about new street bike shocks is they've become considerably less progressive thus more predictable if I'm understanding what you're saying.
Also that Yamaha bell crank I referenced looks like an isosceles triangle so you could clock it to not have a multiplying effect.
Hotwhilz
01-18-2012, 07:43 AM
Thanks guys, now you really got me thinking!
Let's see if this will fit room wise! don't want to cut up the floor anywhere unless really needed.
Bryce, Im' actually reading your build thread, your three link set up is intersting along with the watts, very inspiring! 4" is a no no here we have speed bumps all over the place to get out of my neighbourhood I got to go over 4 of them!!
I'm thinking about building some rockers with multiple holes in them in order to set up the needed wheel travel and then build one to the desired specs.
linkstar69
02-02-2012, 01:40 AM
How off center can the torque arm afford to be? Ie if I was to weld brackets to support it on the axle housing next to the pumpkin would that be ok or does it need to be more centered than that?
Sorry for the newb question but I'm not all that familiar with this style of set up.
After further reading the jaguar and factory five asymetrical 3 link came up as a good design, would these theories of off setting the "middle" link apply to a torque arm design as well?
exwestracer
02-02-2012, 08:34 AM
The further off center you place the arm, the more of the torque reaction "hit" will affect that side tire. Often they are offset slightly left just for packaging reasons. For drag racing, offsetting the arm to the right can help counteract torque roll. This would not be such a good idea for road racing or autoX, as the car will behave very differently accelerating out of left or right hand turns.
linkstar69
02-02-2012, 01:53 PM
So just to the right of the pumpkin would be an ok compromise but any further I run the risk of affecting the predictability of the car from corner to corner.
Btw by right we are talking about the right side if you were looking from the rear of the vehicle forward?
