View Full Version : What to use on firewall, inner fender, and such
67 455 Bird ragtop
01-11-2012, 11:31 AM
Ok while the main bodywork will be painted using a base coat clear coat system what would be best for other parts. Firewall, inner fenders, core support, etc ... I was thinking about using a single stage urethane, with a little clear in the last coat for some gloss, for these areas like I already used on my roll cage bars. Which would be more durable/appropriate for these areas ???
67 455 Bird ragtop
01-11-2012, 07:41 PM
These parts will also be painted the same color as the body.
John510
01-11-2012, 11:52 PM
edit. The thing I suggested only comes in black
astroracer
01-12-2012, 04:03 AM
Why not use the same BC/CC the rest of the car is getting? BC/CC is pretty tough stuff. If you do it right the prep work is the same so there is nothing "better" out there in my opinion.
Mark
67 455 Bird ragtop
01-12-2012, 05:11 AM
Thanks. That's what I was curious about. Which was tougher. BC/CC or single stage urethane. Plus alot of these parts will be painted as I go along. But the body will be painted all at once naturally.
