View Full Version : OUSCI - Are you wanting an invite for 2012?
Larry Callahan
01-10-2012, 04:49 PM
If you are dying to get into the 2012 Optima Batteries Ultimate Streetcar Invitational then show us what you would like to bring. There are two ways to get in. Be given an invite or win your way in at an event.
So, post up some pictures and tell everyone about your ride. No pictures? That's fine. Tell us what you have and would like to bring.
Please note: This is not a way to get invited. I do not decide anything. I just thought it would be fun to see who is dying to get in.
Who knows, maybe this thread might get the attention of the powers that be and some of us will get picked.
Bryce
01-10-2012, 05:50 PM
Since my falcon is finally driveable, it would be cool to go!
My falcon has my designed front and rear suspension.
https://static1.pt-content.com/images/pt/2011/06/tn_full_IMG_19661-1.jpg (http://www.motortopia.com/photos/619774)
https://static1.pt-content.com/images/pt/2010/02/tn_full_new_falcon_pics_21610_022jpg_Thu-1.jpg (http://www.motortopia.com/photos/493448)
LM7_67
01-10-2012, 10:07 PM
I'd love to go, but there's no way my car would ever show up in a SEMA booth.
OK I will throw my hat in!
Our Shop is 50 years old this year, we have several car shows planed for the year, a booth and hot rod area in the works with goodguys, also in talks to have a booth at SEMA again, its been a few years since the shop was there and members the first year SEMA was established, the shop has always been a Hot Rod, Drag Racing shop, and for the last few years our own shop cars have been Touring styles, so we will have a 63 Nova running some time this year, my own 68 Camaro and a few other cars along the way heres a short list on my car, as it stands now
https://static1.pt-content.com/images/pt/2012/01/IMG_7472-1.jpg
Project Plain Jane
Suspension & Brakes;
Hotchkis 2" Front coils
Hotchkis 1.5" Rear Leafs
Hotchkis 1-1/8", Hollow Sway bar (front)
Hotchkis Machined Tie Rod Sleeves
Hotchkis Sub Frame Connectors
Hotchkis Rear Shock Tower Brace
Hotchkis Chassis Max Handle Bars
Hotchkis Premium Steering Rebuild Kit
Helwig adjustable Rear Sway bar
Complete welding of all seams on the factory sub-frame (for strength) and then Glass shot peened to reduce torsional chassis stresses (Peen-Rite)
Global West aluminum body mounts and stainless sub frame bolts
Global West 6 degree Upper tube arms (Urethane bushings)
custom made lower arms (del-a-lum bushings)
QA1 single adjust shocks Front and Rear
AGR 12.7:1 gear ratio Billet power steering box and High volume pump
Derale Power Steering Fluid Cooler
Magnefine Inline power steering Filter
C5 13" corvette brakes, 12" caddy rear disc brakes
Hawk Performance's HP Plus disc brake pads
Coys C55 wheels 17x8” front 17x9.5” rear
Engine;
Seasoned, GM 350 engine Bored 30 over and surface Decked (010 4 bolt block) and stroked to 383
Cast Flat Top pistons(2 Valve Reliefs 10.7:1 w/64cc heads)
ARP Main Bolts
ARP 134-7901 Oil Pump Driveshaft
Melling M55HV (high volume) pump with matching pick up tube for oil pan
Patriot Racing Heads 64cc CNC ported
Comp Cams Roller rockers and Comp Cams Hardened Push Rods
Holley Street Dominator intake
Edelbrock 1406 carb jetted (.098", .101", .071"x.047 orange middle hole) or for race events a Holley HP
Moroso Carburetor Spacer 1”
Holley blue Electric Fuel Pump
3/8" Stainless Steel Front to rear fuel line
1 5/8 in. Holley Headers
Safety wired header bolts
2.5” Mandrel bent Aluminized Exhaust Front to rear with H Crossover
HITACHI Mini Starter (high torque)
MSD Distributor - 6AL digital box - MSD 8.5 Ceramic plug wire set
Prothane's poly urethane engine mounts and ARP engine mount bolts
ARP stainless engine complete bolt kit
Made 4 You spark plug wire holders
Be Cool Radiator
Aluminum over flow bottle
16” Electric cooling fan and custom built aluminum fan shroud
Transmission
Richmond Super T-10 is a four speed (1st gear is 3.42, 2nd is 2.28, 3rd is 1.46, and 4th is 1 ) Rex no jump sliders
Prothane 7-1604 transmission mount
621 bell housing
Centerforce clutch
Centerforce aluminum Flywheel 158 tooth
ARP Flywheel Bolts
Hurst/Indy 4-Speed Shifter (7 1/2” tall shift arm)
Lakewood shift fork
Lakewood pilot bearing
Stock balanced Drive shaft with Currie Enterprises U-Joints
Detroit locker posi unit
Trunk Mounted Optima Battery and black mountain Battery Mount
Interior and exterior
Corbeau Forza seats
Morris Classic Concepts 3 point seat belt
Talbot Vintage racing mirrors
Detroit Speed and Engineering 7 speed wiper kit
Detroit Speed and Engineering 68 RS electric headlight Door update kit
Billet RS grill kit
Tri-Bar Jaguar Halogen headlights
LED Tail lights and front turn signals
Ride Tech/Air Rides billet fuel cap
American Autowire Classic update kit full car harness
Auto Meter instruments
Covans Classic dash panel
Cool IT thermo tec insulation
Southern rods hot rod heater (smoothed firewall) with custom single switch control
Grant GT steering wheel
https://static1.pt-content.com/images/pt/2012/01/camp_1106_37_zrun_to_the_coastweb_exclus-1.jpg
https://static1.pt-content.com/images/pt/2012/01/IMG_5204-1.jpg
Bryce
01-11-2012, 10:25 AM
Good luck with everything Rod. Is there a bolt on class? HAHA.
You going to RTTC this year?
aray327
01-11-2012, 03:55 PM
This would definitely be me bringing a 'pocket' knife to a gun fight! But they say its not the dog in the fight, but the fight in the dog!!!
[ATTACH=CONFIG]53877[ATTACH]
My lil-dog will fight with:
VERY fresh restoration. Bumpers will be on by SEMA/OUSCI
6.0 lsx
Factory sub frame - all welded up
Tubular uca/lca
Qa1's on the corners
Frame connectors, front/ rear sway
ETC, ETC, ETC!!!
It may not be the biggest gun or the badest dog but it would surely look nice at SEMA and OUSCI...
BOLT ON CLASS!! sweeeet i totally win!!
and yes I will be at RTTC again(lots of fun), just removed the heads on the car but it will be ready in a few weeks
Bryce
01-11-2012, 05:41 PM
Cool! I hope to be there too, if I can budget for it.
hotrod69camaro
01-11-2012, 07:22 PM
539125391353914 69 Camaro with 541 HP 383 stroked small block, Tremec 5 speed. Detroit Speed Quadra Link rear suspension, Optima battery secured in the trunk. Afco valved DSE rear coil over shocks. 9 inch rear end with 350 gears,13 inch Baer brakes all 4 corners, Guldstrand Mod to front sub frame, Speed Tech upper and lower A arms, QA1 coil over front shocks, steering box reworked by Lee steering, DSE steering pump with Setrab cooler, DSE sub frame connecters with a roll cage and 4 point saftey harness with on board fire extinguisher. I have track time at Willow Springs, and at El Toro and Goodguys autocross.As well as OCRC driving school. Would love to compete and race at the Optima Batteries Street Car Invitational.........Thanks..........Mike
Nessumsar
01-12-2012, 10:09 AM
Nifty idea Larry.
You guys know I woud love to go and represent the 99%!
https://static1.pt-content.com/images/pt/2012/01/1107chp04oruntothecoastiievent72chevrole-1.jpg
https://static1.pt-content.com/images/pt/2012/01/CHPP_2011_10_NMCA_017-1.jpg
'72 Nova with suspension modifications by Fab53, 315s on each corner, 315whp 388 SBC, TH350, C5 brakes, no heater/ac/vents.
Soon to have fender flares, and a possible color change....
rrelco
02-21-2012, 07:29 PM
How about an El Camino......
https://static1.pt-content.com/images/pt/2012/02/201110OctoberOct23WestCoastRacingGreen11-1.jpg
https://static1.pt-content.com/images/pt/2012/02/DSC_0673-1.jpg
Larry Callahan
02-21-2012, 07:34 PM
Some great pictures and rides. Keep them coming!
sik68
02-21-2012, 09:35 PM
I would love to be a part of OUSCI some day. I represent the young generation of pro-touring, and built my car 'Trackday' under a tarp over the course of 6 years. I have done many events and track days throughout California in the last couple years, and can't get enough of it.
-Steven
https://static1.pt-content.com/images/pt/2008/08/IMG_3458-1.jpg
https://static1.pt-content.com/images/pt/2011/03/IMG_0074-1.jpg
SicMonte
02-22-2012, 06:06 AM
I would greatly appreciate a chance to participate in the OUSCI!! I feel that my car would stand out in the crowd and perform well...and hey...it's not a camaro!!! I have plenty of on track experiance as I used to drive a 1983 RX7 in the SCCA Spec-7 class for two years. This would be a dream come true!!!
Here is my build thread to see everything that is going on with my car!!
https://www.pro-touring.com/showthread.php?67083-Project-SicMonte&highlight=sicmonte
Some pictures and AutoX videos...
https://static1.pt-content.com/images/pt/2011/11/PictureDD006-1.jpg
https://static1.pt-content.com/images/pt/2011/11/PictureDD023-1.jpg
https://static1.pt-content.com/images/pt/2011/11/PictureDD057-1.jpg
https://static1.pt-content.com/images/pt/2011/04/Picture179-1.jpg
gSj8wucu80Q
71duster
02-22-2012, 06:43 PM
what! no mopars! lol! i'll throw mine in the hat. nothing fancy '71 duster with a 360/600 tremec and alot of suspension work. home built,not bought.
55876
55877
thedodgeboys
02-22-2012, 07:20 PM
my 1970 Dodge Challenger 6.1 Hemi 6-Speed
https://static1.pt-content.com/images/pt/2012/02/IMG_1297-1.jpg
https://static1.pt-content.com/images/pt/2012/02/mopp_1108_011970_dodge_challengerexclusi-1.jpg
https://static1.pt-content.com/images/pt/2012/02/SCAN0001-1.jpg
Ron S
04-15-2012, 10:01 AM
I have been wanting to go to SEMA since I was 16, and just time wise, have never been able to make it happen. The Optima event in my opinon is one of the coolest motorsport events of the year, I'd love to go, can't imagine anyone on this site that wouldn't. I'd love to bring my Mustang or my AMX if its done by then.
https://static1.pt-content.com/images/pt/2012/04/CarPics329L-1.jpg
https://static1.pt-content.com/images/pt/2012/03/DSC00298L-1.jpg
PT Sportwagon
05-13-2012, 06:43 PM
Well what might be the breaker for some of us is that the OUSCI rules state that the vehicle MUST be shown at the SEMA show proceding the event. So unless you have an in with someone. Most of us common/back yard builders are out. even if you qualify at a regoinal event. rules state it.
BTW: Some bada$$ rides here. Love the AMX. I'll post up some info and picts of the wagon, for you to laugh at.
Tim
Flash68
05-13-2012, 07:29 PM
Ron, if there is a qualified car for this event that hasn't gone, I say your Mustang is it!
Tim
Most of the cars are invited well before the SEMA show and then they show up the week of SEMA to be in the Optima corral leading up to the event on Saturday.
PT Sportwagon
05-13-2012, 08:31 PM
Well another thing that I read in the rules is that the winners of the regional qualifiying events unless you have competed before you will not be able to compete in the OUSCI. refer to: http://www.optimainvitational.com/rules_2010.html refer to rule 3-3b. I am just stating what the rules say and it says nothing about vehicles qualifiying at a regional event will be featured in the Optima car corral.
Tim
PT Sportwagon
05-15-2012, 03:55 PM
Well like I said here is some picts and info on my POS, for you to laugh at: It is a work in progress and these pictures are a couple years old. So some things have changed. just remember I have no place to work on it just the Apt parking lot. And I am poor. So it maybe 10 years or more before it is done if ever:fingersx::fingersx:
1971 Buick Sportwagon
Buick 350 Rochester 4 bbl
Th350 transmission, posi rear end (i think)
Hooker Comp headers
Jegs header back exhaust
Autometer gauges
Monroe Shocks
A/C removed
Goodyear reatta II tires 215/70-14
factory 14x6 rims ( Have a set of MotorWheel Spyders for it)
BBB 3 core radiator
MSD Fire wires
Tim
594435944459445
k7king
05-20-2012, 02:51 PM
I'm attempting to qualify with my 63 Pontiac Tempest. Wish me luck.
http://youtu.be/803QkYg--nU
RSX302
05-20-2012, 07:15 PM
This is an awesome event and some heavy hitters come to play. I would love to come back to OUSCI and redem thyself, but doubt I can due to the rules.
Many cars that enter don't see track time and some not even street time to work out the bugs, so you see at least half of the field lagging and many dropping out due to some sort of mechanical issue. This was my crutch since my car saw street so mechanical issues were good, but not track at the time so handling could have been much better. Although it did ok (placed 8th overall) it (I) had much room for improvment. Since my 2008 OUSCI entry, I have performed alterations to the brakes and suspension and tested at Willow Spings. The car is night and day compaired to what it was. Oh yea, there is the new engine thing too and the Ford stripe gone.
Even if I can't play again in this event, I would love to get back to Spring Mountain and see what my car can do. Looks like you need better than 1:50's on the road course if you want to be in the top 5 and mid/low 1:40's if you want to battle for top. Times are seriously moving. My road course time was only 2:00 at the time,but I know it will be much better now. 15 sec better? Hmmm
https://static1.pt-content.com/images/pt/2012/04/RSX-1.jpg
HUSTLESTUFF
08-21-2012, 09:37 PM
I'd love to see some track time. Registered today for SEMA and plan on taking the car. Would love to display at sema as well. Another home built except for paint. Just fired the new bullet today. 512 cu in 4spd w/ gearvendor and 4.10 Dana. Should put out 650 hp.
636266362763628
RobNoLimit
09-26-2012, 09:50 AM
http://youtu.be/OWnW2VkgfVY Here's a short video about my newest truck build. I got all my toes crossed.
67zo6Camaro
10-05-2012, 04:08 PM
Man I love this truck. I have even driven this thing for a day at Adams Motorsports Park, and I have to say I really think this truck could beat almost anyone at OUSCI. Maybe even a top contender for the prize. I can't wait to see it there this year.
CA B4C
10-05-2012, 05:09 PM
I can not agree with you more!! If this event were held without "Hellboy," they would have to change the name to the Optima Batteries Streetcar Invitational. Clearly one of the ultimate cars (truck) were omitted.
Flash68
10-06-2012, 11:42 PM
I think that truck should be there too Brett.
mpozzi
10-07-2012, 08:34 AM
It should be there simply for the fact that it's NOT a first-gen Camaro. A nod for OUSCI invite gets better odds if your ride deviates from the norm with the cool and fast bits built on a platform that it wasn't designed for originally.
"Hellboy" qualifies on all counts as it's all that and fast, too.
Mary Pozzi
snappytravis
10-07-2012, 05:44 PM
Hooker Comp headers
Autometer gauges
Monroe Shocks
A/C removed
BBB 3 core radiator
MSD Fire wires
Tim
594435944459445
Right on another wyo guy,
RobNoLimit
10-08-2012, 05:48 PM
Thanks to everyone supporting my Truck and pushing for an entry, that in it's self means a lot to me. This past weekend at RTTC Karl and the Blu-Balz Camaro and I battled it out once again. He took the top spot on the autocross beating my best by .030 sec. But, one the road coarse, the little red truck out ran all comers with a 1.43.38 fast lap to win the Road Coarse event. Had a great weekend. Thanks again to the ASCS and everyone for their support.
PT Sportwagon
10-20-2012, 02:05 PM
Rob, that is a way cool truck, good luck with the invite. I think Mary is correct in it should get the nod because it is not a first gen camaro. It is titally out of the box. Which makes it way kool.
Tim
RobNoLimit
11-01-2012, 04:03 PM
Thanks to Optima and everyone else's help. We got a golden ticket today!!!! Now it's on.
Go get them Rob!! Drive well man and have fun!
Flash68
11-01-2012, 04:08 PM
Right on! Best of luck.
eric1967
11-01-2012, 05:15 PM
Good luck Rob.
Eric
GrabberGT
11-02-2012, 06:31 AM
Woohoo! Let the C-10 battle begin.
shawnvan
03-17-2013, 07:04 PM
This would be any car guys best reward, we all work so hard on our hotrods. Big thanks to all the guys that make this sport possible. I built this car so my wife could drive it to work and I could beat on it on the weekends. So far so good. With our limited budget we had to do it all ourselves including chassis and paint.( it does help to have friends who can steer you into success) Here is a quick rundown.
1965 Chevelle Malibu
1998 LS1 T56
1985 Corvette front and rear suspension
245/45 17 front
285/40 18 rear
EBC blue stuff brakes
Vintage Air a/c
Royal Purple oils
and of course OPTIMA battery
730517305273053
PT Sportwagon
03-19-2013, 03:45 PM
Well I picked up a factory Pro-touring car. A 2013 Ford Focus ST, why do I say factory pro-touring well Ford took the Focus and upgraded the brakes, suspension, and interior. just about doubled the Horsepower. I am still building my POS wagon, but the Focus ST is a pocket rocket.
Tim
