View Full Version : drip rail seam sealing
tillman
01-07-2012, 01:19 PM
Should the 3m two part seam sealer be put on bare metal and then primed or primed and then the sealer?
Tony
ChevelleNV
01-07-2012, 03:16 PM
Most seam sealers I've dealt with went on bare metal. but check the technical data sheet (should be available on the 3M website) for the particular seam sealer your using to be sure.
HotRod47
01-07-2012, 04:40 PM
Seam sealer does not have a rust preventative. It is not meant for a direct to metal use. It just stops the penetration of water/moisture. I would definitely do it over the primer. Plus it looks better that way.
Denvervet
01-07-2012, 05:49 PM
Read the tech sheet. I know fusor goes over primer.
censo69
01-27-2012, 10:32 AM
I've always done Primer then Seam sealer
