View Full Version : Tax and rental
Norrisha81
01-07-2012, 03:41 AM
Tax is considered rental property as an independent company, whether you are registered as employed or not. This enables that by letting the property will be able to use the same favourable rules as if they had a real registered company.
Corporate tax scheme gives brief opportunity for a personal landlord may be subject to taxation similar to that which private and public limited companies must use.
For all landlords are therefore able to deduct the interest payments from fully taxable income.
Income from rental of a dwelling for residential purposes, are generally taxable. For rent house only part of the year, the owner or landlord individual rooms in your home to others, the rental income will be tax free if it is below a certain amount.
There are various methods of taxation of rental income from, respectively. permanent residence and holiday home, and rules should be learned depending on your needs and property type.
Are there any further need for more concrete information and guidance about tax and rent, all contact with treasure in their home municipality?
If the property is used exclusively for rental, taxable income under the rules that apply to rental properties. The same applies if you have started commercial rental throughout the year.
