View Full Version : Best Spindle for Replacing B Body Spindle on A-Body?
BulldawgMusclecars
01-05-2012, 06:19 PM
AFX? The car already has Hotchkis uppers set up for the tall spindles, so I want to keep them, but eliminate the problems associated with the existing spindles. We're planning to use C6 brake components.
Mingus
01-05-2012, 07:32 PM
I have AFX spindles and really like them. Tobin at KORE3 has some nice C5/C6 brake packages for them and is great to deal with. L&H Kustoms also makes tall spindles.
BulldawgMusclecars
01-07-2012, 06:29 AM
Thanks, I just wanted confirmation from someone who has used them in this application. I agree, Tobin is great to deal with. I'll be ordering from him on Lonestar, Sabre, and a GN I'm working on.
killerjay
01-10-2012, 11:26 AM
you may have to change the upper control arms as the King Pin Inclination angle on the B body spindle is different than the AFX Spindle that is why you had to purchase special upper control arms for the B body spindles as well the upper ball joint taper is different.
chevelletiger
01-15-2012, 08:22 PM
scandc stage 2 plus as close as you can get to an afx set up. tall upper and lower ball joints with spc upper arm on STOCK SPINDLE!talk to mark,i have this set up and love it.phil
BulldawgMusclecars
01-19-2012, 06:00 PM
This car came in with this setup (done many years ago), and I'm trying to reuse the arms if possible. But, if another tall option won't work with them, we'll have to change them.
BulldawgMusclecars
I'll give Mark a call tomorrow and see what he thinks. Thanks!
csouth
01-19-2012, 09:09 PM
You can use the Hotchkis uppers, but I'm sure Mark will give the reasons why there are better options. I sold my Hotchkis setup after talking to him and ordered the SPC uppers with L&H spindles. FYI, the spindles are a little delayed so you'll need to be patient....
