View Full Version : 13"Corvette Front Brake Setup for1970-1981 Camaros
4RS FED
12-31-2011, 12:18 PM
Doubt anyone here will be interested, but you never know.
I am selling my front brake setup on my camaro
It consists of 13" Cross Drilled and slotted rotors
2003 ZO6 Corvette dual piston Calipers
KORE3 Billet aluminum hubs w/matching grease cap
ARP 3" 1/2 12point studs
Special Aluminum adapter plate that mounts the Corvette Caliper onto your spindle.
These brakes have safely stopped my car at over 175+mph in the 1/4 mile at Sacramento Raceway
Have over $1200 invested in the front brakes asking $700 plus shipping.
http://www.norcal1320.com/forums/imgcache/3726.imgcache.jpg
http://www.norcal1320.com/forums/imgcache/3727.imgcache.jpg
http://www.norcal1320.com/forums/imgcache/3728.imgcache.jpg
http://www.norcal1320.com/forums/imgcache/3729.imgcache.jpg
http://www.norcal1320.com/forums/imgcache/3730.imgcache.jpg
srh3trinity
12-31-2011, 12:43 PM
If you part it out, I would be interested in everything but the rotors and calipers. I have C6 z51 rotors and calipers waiting for the hubs and brackets. I just need to check and see if they are the exact same as thee C5 z06 stuff. let me know.
g-machine
12-31-2011, 01:14 PM
175+ in the 1/4 is impressive, what et? Nice brake package......I'd pull the trigger if I had the funds!
4RS FED
12-31-2011, 02:11 PM
Thanks, its been 8.32 in the 1/4.
Not bad for a 23* small block in a 3600# leaf spring car
srh3trinity
12-31-2011, 04:20 PM
Looks like my rotors are 13.4 inches, but I would be interested in the hubs if you break the kit up.
4RS FED
12-31-2011, 04:21 PM
It will not be broken up.
If you would like to buy everything and sell what you don't need that is fine too... ;)
badazz81z28
01-01-2012, 12:26 PM
I have interest...How much wear are on the rotors and pads? What parts that are not included would be required to run this set-up? I have a 1978 Camaro currently with the B-body 12" Upgrade.
4RS FED
01-01-2012, 12:32 PM
The only thing NOT included would be the spindle and brake lines.
You would recieve the KORE3 All Aluminum Billet hubs with the seals and bearings, washer and nut, and arp 3" studs.
You would recieve the rotors
You would recieve the calipers, caliper bracket, brake pads, bolts, and shims.
You would recieve the billet caliper adapter brackets with bolts.
The car is at the shop, but I know the pads have over 80% life left, the rotors have never been turned, and don't have any warp to them that I can tell.
If you want a picture of the amount of pad life left, just let me know. I can get any pictures that you need.
It is a 100% bolt on kit, you would need to supply the spindle and modify it accordingly.
badazz81z28
01-01-2012, 05:17 PM
Ahh...What size rim are these in?
4RS FED
01-01-2012, 06:58 PM
I have these on 17" skinnies
4RS FED
01-06-2012, 12:08 AM
take off $50 if it sells this weekend and I will pay half of the shipping........
$650 plus 1/2shipping
badazz81z28
01-08-2012, 08:23 AM
I just realized these will not fit on my spindles. I have the 79-81 larger outer bearing.
4RS FED
01-09-2012, 06:29 AM
sold
