View Full Version : NEED HELP! with Willwood rear brake kits
Fastrun72
12-30-2011, 06:40 PM
Hi... I just installed my new Moser 12-bolt rear in my 1972 Camaro with Hotchkis leaf springs. I have the BIG Ford bearing Flange with 2.5" offset.
I am wanting to install Willwood's 13" Black SL4r #140-9219 kit with parking brake on 18" Rushforth's.... I was told by a Willwood tech that this kit will not work due to my staggered shock set-up and they have nothing for my application.... Is this true??? I have heard that there shouldn't be any issues with the shock positions and would like both calipers rearward facing. Does anyone have a similar set up on their second gen. Camaro or know what options i might have??
Thanks in advance, Jim :hand:
$Mike70Z-28
12-31-2011, 07:17 PM
hi jim i have wilwoods on my 2nd gen one caliper is in the front and one in the back couse of the shocks unless you relocate the shocks
Fastrun72
01-01-2012, 12:27 PM
What type rearend flange do you have and do you know what willwood kit you are using or at least what size rotors & calipers you are using such as Superlites or Dynalites etc....???
$Mike70Z-28
01-02-2012, 09:48 AM
i have gm flange rotor size is 12.19 and the calipers are dynalites
Wilwood Tech
01-03-2012, 12:49 PM
Jim,
That kit should work with your car. Wilwood makes kits for Camaro's with staggered shock set-ups utilizing both Big Ford Bearing and 12 bolt Chevy flanges. Please email me your phone info and I'll have someone from tech call you.
Thanks, Ken
[email protected], 805-388-1188.
ProdigyCustoms
01-03-2012, 04:00 PM
The 13" (4) Piston Superlite 140-9219 kit works on 70 and up stagger shock cars. The stagger is so far inboard it does not require the offset calipers like the first gens.
