View Full Version : Weld or clamp mufflers to pipes?
Mr. Anderson
12-28-2011, 05:04 PM
Been working on my exhaust system...considering whether I should weld or clamp the mufflers in.
The tail pipes will be clamped to the rear of the mufflers to make it easier it put on and get apart....but should I weld the front pipes to the mufflers, or leave them removable? FYI, the pipes are aluminized steel and the mufflers stainless.
What have you guys done?
jlcustomz
12-28-2011, 08:39 PM
While welding is generally considered the best way, these modern band clamps seem to work pretty good. Have them on my coated headers toexhaust. Coat bolts with anti seize, I have had to r & r mine several times, still tight. I spread a little permatex ultra copper before installing bandclamps for good measure. If you weld, spray a little cold galvanizing spray on area.
Randy67
12-29-2011, 08:03 AM
I usually weld most of the system, but have a couple spots clamped so it can be removed when needed. The band clamps do work great.
Mr. Anderson
12-30-2011, 04:11 PM
Thanks for the input guys. I ordered band clamps for each end of the mufflers.
