View Full Version : Black steel braided hose for Hydroboost??
staged67gspwr
12-28-2011, 02:57 PM
Hi,where or who can i get black steel braided hose for my hydroboost?any recommendations appreciated.
sjaroslo
12-28-2011, 03:12 PM
Quick Google search only turned up this, which may or may not be appropriate for your situation--and the Stainless is painted after manufacture...
http://www.votionspeed.com/servlet/the-656/PTFE-Braided-Stainless-Steel/Detail
MuscleRodz
12-28-2011, 05:12 PM
does not exist for the psi requirements. we have looked all over and only thing we have found is either painted stuff or shrink tube covered. The only thing that comes close is factory style ps hp hose custom made to length
Fuelie Nova
12-28-2011, 07:22 PM
What are the psi requirements for Hydroboost?
Tom
hessdawg
12-28-2011, 10:27 PM
1500-3000psi
staged67gspwr
12-29-2011, 06:51 AM
Thanks guys!
$Mike70Z-28
12-29-2011, 07:00 AM
look here mr g
http://www.race-mart.com/AFCO-37102.html
quarterbooty
12-30-2011, 04:19 PM
I did some searching and came across Aeroquip's 1503 hose, which meets SAE 100R5. In -06 size, it's rated for 2250 psi. Reusable fittings are available; however, they're specific to this hose. More information is available here (http://aeroquip.cc/1503-06aeroquipsinglewirebraidsae100r5hose1503-6.aspx). You can buy it through Talon Hydraulics (http://www.talonhydraulics.com/store/index.php?main_page=product_info&cPath=39_8_77&products_id=387) for $8 a foot.
Hydratech®
12-30-2011, 07:33 PM
Power steering systems can generate hydraulic pressure spikes in use (in excess of the PS pump pressure relief settings), and we therefore suggest you look for hose ends and fittings that will provide a 2000+ PSI rating. Ratings less than this can be a weakness in any power steering system that can fail under hard punishment. Aluminum hose ends are not advised, along with hose that rates less than 2000 PSI. You overbuild everything to extreme duty ratings so that you can pound on your rides, right? Failures take the fun out of it, so don't skimp in this area. The Aeroquip TFE hose that we use in our systems is rated for 3000 PSI and 450+ degrees. Many alternate hose choices may meet the pressure criteria, though some barely rate for 250 degree operating temps. With a hard session out on the track, many underhood temps can get close to the rating on certain types of hose. Summary? Watch your specs on hose and hose ends when plumbing any type of PS system!
Beauty is always in the eye of the beholder, and some want to work with a certain theme, or make the hoses less visible in their engine compartments. I have worked with so many customers over the years to find that they typically don't realize just how much they like the braided stainless / silver hose end look until they see a car with one of our systems installed with the lines neatly plumbed. I have always felt that something so good looking should not be hidden... The symmetry of having two braided stainless hoses running to the hydraulic brake unit, with the vibratory polished separators, and silver hose ends is just "right". Having the third low pressure return line from the brake unit in black makes it "disappear", which helps to keep the visual balance right. When customers do the third line in matching SS braid, it also looks good, though seems to get more of a visual of being "hosey" in my opinion.
We have many ways to accomodate the black hose look, with the image below being the most popular:
https://static1.pt-content.com/images/pt/2011/12/blackcover-1.jpg
This is our standard production line set using the Aeroquip TFE AN-6 components, though covered with simple 7/16 ID electrical convoluted nylon tubing. It provides a nice high tech look, is inexpensive, available most everywhere, and is super simple to install - ten minutes and you're done! Don't like it? Yank it back off in two minutes... We have also used the black flexible nylon woven braid covers with good results, with black heat shrink tube on the ends to keep the nylon overbraid from fraying out - it looks phenomenal when done cleanly, as the hoses interestingly look even smaller with the super thin woven black covers. Here is but one common place where you can get this stuff: http://www.summitracing.com/parts/RFW-BS50/?rtype=10 (.500 diameter) The hose covers allow the highest rated and smallest TFE series hose to be used, yet still give you the black look you are after.
Here are the part numbers for the Aeroquip AQP hose in black. Do note that this class of hose is MUCH bulkier than the Aeroquip TFE Series. Hose outer diameter is almost as fat as your thumb at .68" and the hose ends take 7/8" wrench sizes = larger hose and fittings than some expect. By comparison, the hose OD on the TFE AN-6 is vastly smaller at 7/16"...
All of these items below can be ordered at the best prices at www.aeroquip.cc You can order online or call and ask for Bryan Matheney.
HOSE: Aeroquip 1503-06 http://aeroquip.cc/1503-06aeroquipsinglewirebraidsae100r5hose1503-6.aspx Pricing is about $ 5 a foot
90 degree female AN-6 hose end: http://aeroquip.cc/fbm1389-fcm1389.aspx
45 degree female AN-6 hose end: http://aeroquip.cc/fbm1386-fcm1386.aspx
Straight female AN-6 hose end: http://aeroquip.cc/fbm1302-fcm1302.aspx
90 degree 3/8 male flare 5/8-18 thread: http://aeroquip.cc/fbm1392-fcm1392.aspx (PS pump high pressure output)
45 degree 3/8 male flare 5/8-18 thread: http://aeroquip.cc/fbm1382-fcm1382.aspx (PS pump high pressure output)
Straight 3/8 male flare 5/8-18 thread: http://aeroquip.cc/fbm1363-fcm1363.aspx
These separators in silver would look good: http://www.summitracing.com/parts/EAR-167211ERL/ (.68" inner diameter) (too bad Earl's doesn't have them in black)
:usa:
Fuelie Nova
12-31-2011, 07:49 PM
Paul
Thanks for those ideas, I just finished installing my unit I purchased from you guys.
Tom
Hydratech®
01-07-2012, 04:11 PM
Hi Tom - Thank you for choosing Hydratech Braking Systems!
Have you had a chance to run your installation through its paces yet? Any feedback to provide? Do you have any pics to post up?
:cheers:
