View Full Version : What wire connects to the starter solenoid?
bigpat1802
12-27-2011, 06:54 AM
I'm swapping in a LM7 into my 77 El Camino.
I got in a rush and wasn't paying attention to my wiring when I disconnected the starter on the previous 305 that was in the car.
Could someone tell me what wire I'm suppose to connect to the small solenoid post?
At one time I thought I saw a thick purple wire, but now I can't find that. At another time I thought I saw some thick yellow wire. I'M LOST.....PLEASE HELP.
I also want to point out that the previous owner had switched the car to HEI on the 305 if that seems to make a difference.
Otherwise tomorrow I took off work and I will trace all my wiring back to the ignition switch.
Thanks!
Pat
sjaroslo
12-27-2011, 02:55 PM
I could DEFINITELY be talking out of my a** here so please take this with a grain of salt, but maybe it is better than just leaving you dangling.... I am looking at a wiring diagram for a 67 Camaro and the starter solenoid is supposed to have a 20 gauge yellow that goes to one side of the ignition coil, and the other side of the solenoid is a 12 gauge purple that goes through the bulkhead connector to the ignition switch. I only provide this because you said that you thought that you've seen a purple and a yellow... Don't know how the HEI would fit into the grand scheme.
bigpat1802
12-28-2011, 06:59 AM
Yeah I've read something like that as well. Since I no longer have a coil, I'm thinking its the yellow now, but I've never heard of a yellow wire going to the starter. Well I have two days to figure it out and get this beast running so......here I go!
Thanks for posting though!
Hambone!
12-28-2011, 07:30 AM
Of course, you should verify this with a test light, but it should be the purple wire on the "S" terminal. That's your start signal to the solenoid.
dhutton
12-28-2011, 07:37 AM
Purple wire to the starter solenoid as stated above. It should be a "thick" wire compared to the others.
