View Full Version : Which stock car LS2 throttle body?
Samckitt
12-21-2011, 09:54 AM
I have about come to the conclusion that I will need an LS2 throttle body to work with the GMMP LS2 controller kit I have, instead of the LS3 throttle body I put on the motor. I have LS3 heads & intake & the Vette accessories & injector covers. Is there a particular throttle body I should stay away from, or one in particular I should look for? I need a drive by wire one & preferably not one that will choke it down, bigger the better right?
FatfreeGTO
12-21-2011, 03:59 PM
I used a 90mm LS7 TB has a silver blade with my LS3 intake. You need any of the 90mm silver blade throttle bodies. (not a gold blade like the new camaros/vettes have) I think the switch to the gold blade happened in 2009... Basically the gold blade opens opposite of the older silver style.
So you could run
LS2
LS7
Early LS3 from a 2008 corvette... (I think)
GeoffP
12-22-2011, 02:35 PM
I think all the LS2 throttle bodies are the same - good luck finding one for a decent price though. I shopped for several weeks before finding a good used one at a decent price. Hopefully you'll get lucky!
rocketrod
12-22-2011, 03:55 PM
I think all the LS2 throttle bodies are the same - good luck finding one for a decent price though. I shopped for several weeks before finding a good used one at a decent price. Hopefully you'll get lucky!There not. There is a truck version and at least two versions for cars. One for the vettes with a gold plated throttle plate and the other for gto's. The vette tb is supposed to be the best of the bunch.
GeoffP
12-22-2011, 06:23 PM
Sorry - whenever I think LS2 I always forget they were offered in Trailblazers, etc. I have a GTO one on my engine build to match my e40 ECM.
Samckitt
12-22-2011, 06:34 PM
Wouldn't the gold blade one be the same as the gold blade LS3 one I have? If so, can't use it, would be the same situation.
rocketrod
12-22-2011, 06:53 PM
Wouldn't the gold blade one be the same as the gold blade LS3 one I have? If so, can't use it, would be the same situation.Have you called GMPP to determine what year TB you need to work with the controller? What year is the TB you have and how did you come to the conclusion it won't work?
Samckitt
12-22-2011, 07:22 PM
Call GMPP? No, didn't know I could just call them. Not sure what year the one is I have, It's from an LS3 & is gold blade. I have spoke to a couple of tuners, both say won't work, Norris was one, & the other was Ed (?), from Virginia Beach area.
robertjra
12-22-2011, 09:53 PM
I have a stock throttle body off a 2008 cad l92 but i dont know how much they go for?
Mike Norris
12-23-2011, 10:46 AM
Here is my list of vehicles that you can use the TB's from as they are all the same.
2005-2008 Corvette - Can be LS2, LS3 or LS7
2005-2006 GTO
2008-2009 G8
On the G8 side, I mention the 2009's as I have had 4 come thru my shop that have had the older 05-08 TB on them.
These are all the "car style" TB's as I call them that have the aluminum cast housing for the electronics. The "truck style" 90mm TB's have the flat plastic electronics housing.
Hope that helps.
Mike Norris
Samckitt
12-23-2011, 10:53 AM
Yes that helps a ton, Thanks Mike!
Mike Holleman
12-23-2011, 03:44 PM
Scot, I have one from a 2005 GTO. Came on the engine I used in the Elky. 11,000 mile engine. Got the whole topend. heads, intake, TB, cam, etc. I also don't know what the value would be but I would trust whatever Mike Norris says is fair. Tis your's if you need it.
Mike
Samckitt
12-23-2011, 04:09 PM
Maybe he will chime in again, or if you come up with something, let me know, along with pics please.
Mike Holleman
12-23-2011, 04:30 PM
It is pretty much in new condition. I'll be in the shop in the AM and I'll pull it out and take a pic. Give Mike a call and ask him for a fair price. He would know. I'm easy. If you got it and were not happy I'd take it back.
Samckitt
12-23-2011, 04:40 PM
Tomorrow's Christmas eve, don't make a special trip to do it tomorrow, I'm in no hurry for it, it can wait a few days.
Scot
Mike Holleman
12-23-2011, 04:46 PM
My shop is a hundred feet from the house and I'm working on the Elky tomorrow. Mike
Samckitt
12-23-2011, 05:20 PM
Ah, was thinking "shop" as in your business & you had to drive to it.
What's the "Elky" you are working on?
Mike Holleman
12-24-2011, 07:41 AM
Nah, I'm retired. The Elky is the one in my avatar that I beat on all year. It is getting a Tick master upgrade and I'm starting my complete "go over" to be sure it will be ready for the drive and flog it will get at the Run to the Alamo in Feb. Here are pics of the TB. Like I said, it has 11,000 street miles. Should be perfect. Mike
https://static1.pt-content.com/images/pt/2011/12/DSC01284-1.jpg
https://static1.pt-content.com/images/pt/2011/12/DSC01283-1.jpg
https://static1.pt-content.com/images/pt/2011/12/DSC01285-1.jpg
