View Full Version : Wanted: Camaro or Firebird tilt column, through 1978 (or earlier)
SparkyRnD
12-20-2011, 07:55 PM
I'm looking for a used tilt column from a floor shift car, from a camaro or firebird, up until 1978. In 79 they changed the bottom of the column, so I need 78 and earlier. It can be scratched, wobbly and just plain rough. Looking for inexpensive, hopefully in the double digits.
SLO_Z28
12-20-2011, 08:50 PM
I have one partially disassembled in my office I was going to throw away, PM me your phone number and ill check into shipping it and toss ya a pic.
SparkyRnD
12-20-2011, 09:03 PM
James, thanks. My email is [email protected], and my number is (404) 954-1662
SparkyRnD
12-21-2011, 05:16 PM
oh, and I don't need the wheel, just the column.
SparkyRnD
12-27-2011, 06:40 PM
still looking for a column if anyone has a line?
jeff-san
01-01-2012, 07:53 AM
if your still looking for a column, I have had one in my garage for 15 years. you can call me and tell me to help verify what it is but I was told it's for a 69 Camaro. I can take a few pix with my phone if that helps too.
tilt, blk, key in the ignition
jeff
831-214-2335
SparkyRnD
01-01-2012, 07:59 AM
Yep, still need one. Does yours have a collar on the bottom that is spot / tack welded in place?
jeff-san
01-02-2012, 08:51 AM
I just emailed pictures of the column...if you need further shots just ask. I have a lot of other 67-72 parts laying around so if you need anything else, feel free to email me a list.
Happy New Year...Jeff
SparkyRnD
01-02-2012, 07:29 PM
Jeff, thank you for the pictures. I noticed there was a hole in the side, near the key. Was that for an automatic shifter?
4mul8ion
01-02-2012, 08:58 PM
I also have a tilt column from a 75 or 76 T/A that I'm not going to use if you're still looking. Mostly there but missing the plastic end on the tilt lever.
Kevin
jeff-san
01-03-2012, 10:31 AM
I had to look at the picture that I sent. If it's the picture I saw the extra hole is for the turn signal or the tilt lever...it's missing one of them, can remember which one. let me know if you need any other pictures to help clarify it for both of us.
jeff
SparkyRnD
01-03-2012, 01:28 PM
Kevin
Kevin, I sent you a PM, I'm interested.
jeff
Jeff, I did some looking back at the articles I found, and I need a 70-78 Camaro column. Not sure what the differences are, but they stated that the earlier models wouldn't work for my type of swap.
4mul8ion
01-03-2012, 08:41 PM
Pictures sent.
SparkyRnD
01-04-2012, 11:39 AM
Kevin, thanks for the pictures. What are the wires hanging out of the top, were those from the horn? Also, is there a top collar that isn't shown?
4mul8ion
01-04-2012, 08:22 PM
Hi -
Yep, I was wondering if that would be clear or not. They're part of the cruise switch built into the turn signal stalk. The Trans Ams had a horn inside the center collar with the electrical contacts. I emailed you more pictures to, hopefully, clarify.
I'm a bit unclear what you mean about the top collar. If you mean the collar that the factory formula steering wheel bolted to, yes, I have that and it'll be included. See the email for those pics too. The exploded views that I can find in my 1970 factory manuals show a plastic cover plate with three screws but I'm not sure if GM included it for the T/A columns with the formula wheel. If they did, I no longer have that piece.
Kevin
