View Full Version : My 1967 Malibu pro touring project
jsrocket
12-19-2011, 04:18 PM
These are the first pics I'm posting. I am building a 1967 Malibu pro touring car with LS3 T56 and pushrod rear suspension. I really like the body style of the 66 67 chevelle and that is why I decided to spend the time to do this project. I'm over whelmed by how much work I have left on this car before it can be driven. I really appreciate the help I've received on the forum.
CruizinKev
12-19-2011, 09:21 PM
wow good work so far man! gotta love them 66 67 chevelles! :twothumbs
lcartag1
12-20-2011, 09:13 AM
Cool looking rear set up.
armourmark
12-21-2011, 07:40 AM
what wheels are those?
Rick Giles
12-21-2011, 09:29 AM
That is going to be an awesome build! Love the 66 and 67's. Can't wait to see more!:twothumbs
DirtShark
12-21-2011, 10:02 AM
Real nice set of wheels...
racedaddy
12-21-2011, 10:12 AM
nice ride, nice rear setup
jsrocket
12-21-2011, 02:44 PM
Those are Pro Wheels Formula.
daytonayellaz
12-21-2011, 03:02 PM
Awesome build! I used to have a 67 Chevellle convertible. I love these cars! Keep up the good work...:cheers:
jsrocket
12-24-2011, 05:48 AM
The engine that's going in my project is a Wegner motorsports 4.125 bore X 4.00 stroke resleeved LS3 block with callies rotating assembly and wegner performance heads. It has 11 to 1 compression and is projected to make 660 hp at the crank.52953
bart0510
12-24-2011, 06:48 PM
Nice work on the rear end set up! Looks killer so far, keep it going!
workbenchracer
12-24-2011, 08:29 PM
That looks real good. My favorite year of Chevelles. Like the rear suspension setup. Keep posting pics!
jsrocket
12-28-2011, 04:04 PM
A arms, drop spindles and shockwaves finally came today. 53092
BCHALK22
12-28-2011, 10:07 PM
I dig the car.. Cant wait to see more
BulldawgMusclecars
12-29-2011, 05:50 PM
Very nice!
jsrocket
01-04-2012, 06:43 PM
Assembled the front suspension components. 5337153372
jsrocket
01-04-2012, 06:58 PM
I put the old disc brake rotor on so I could see the car on the ground. The tire is too close to the bolt on the inner fender and there is interfearence when I drop the car down. I talked to Toben from Kore 3 today and he has a solution with one of there hub systems. He really knows his stuff and I would refer him to anyone. I downloaded one of kore 3 disc brake templates and was able to figure out which one I will order in the future. 5337953380533815338253383
Karls73
01-04-2012, 07:23 PM
This is going to be one nice ride.
sr73bu
01-04-2012, 07:53 PM
Looks great!.... I see you are using a GTO t56, If you dont like the position of the shifter or want to save money on a new shifter, Tremec sells replacement shifter cups for the f-body t-56 (to replace the gto one)... I know for my chevelle, it worked out better and f-body shifters cost a few bucks less than replacements for GTOs. Replacing it takes about 2 minutes...just a heads up... Keep up the great work!
-Sean
19 usac
01-05-2012, 10:44 AM
Great car who's front drive setup is thea on your LS-3 thanks ,Jim
sjaroslo
01-05-2012, 01:45 PM
Would guess it is Wegner's since it is a Wegner engine....
jsrocket
01-08-2012, 06:54 AM
It is Wegners front drive setup.
jsrocket
01-10-2012, 04:37 PM
-SeanThe T56 thats in my car is actually out of a 98 camaro that I bought from my brother. Part of the deal was that he would get the shifter that was on the trans he sold me and he would give me the shifter setup off the GTO T56 that he was using. So we switched shifter cups and I put the shifter on from the trans he is using. I really like were that locates the shifter in my car. Thank you very much for the info.
jsrocket
02-08-2012, 06:28 PM
552895529055291Drive shaft safty loop
jsrocket
04-15-2012, 06:42 AM
581675816858169Removed the frame from the body and proceeded to repair some areas on the frame.
jsrocket
04-15-2012, 06:44 AM
Added exra support to the frame.581705817158172
jsrocket
04-15-2012, 06:48 AM
Sent the frame out for blasting. Did some body work on some areas.581735817458175
Auto Rod Technologies
04-15-2012, 08:15 AM
Nice car.. I like the stance!!
jsrocket
04-18-2012, 05:42 PM
Primed and painted the frame.58341583425834358344
jsrocket
04-19-2012, 05:22 PM
Put the suspension on the frame.5839758398583995840058401
emanresu525
04-20-2012, 04:30 PM
Looks good J.
Joe A Sanfilippo
04-20-2012, 04:38 PM
very nice!
CruizinKev
04-20-2012, 09:05 PM
wow looks sick! :twothumbs
jsrocket
01-18-2015, 06:37 AM
https://static1.pt-content.com/images/attachhttps://static1.pt-content.com/images/attach/jpg.gif/jpg.gifhttp:/https://static1.pt-content.com/images/attach/jpg.gif/static1.pt-cohttps://static1.pt-content.com/images/attach/jpg.gifntent.com/images/attach/jpg.gifhttps://static1.pt-content.com/images/attach/jpg.gihttp://imghttps://static1.pt-content.com/images/attach/jpg.gif1.pt-content.com/images/attach/jpg.giffhttps://static1.pt-content.com/images/attach/jpg.gifhttp://https://static1.pt-content.com/images/attach/jpg.gifstatic1.pt-content.com/images/attach/jpg.gif
jsrocket
01-19-2015, 03:07 PM
https://static1.pt-content.com/images/attach/jpg.https://static1.pt-content.cohttp://img1.hthttps://static1.pt-content.com/images/attach/jpg.giftp://static1.pt-content.com/images/attach/jpg.gifpt-content.com/images/attach/jpg.gifm/images/attach/jpg.gifgifhttps://static1.pt-contehttps://static1.pt-content.com/images/attach/jpg.gifnt.com/imhttps://static1.pt-content.com/images/attach/jpg.gifages/attach/jpg.gif
