k7king
12-15-2011, 04:27 AM
This pic is from the catalog. I bought this tank from Ricks Camaros. It is used. I switched to a ricks Stainless gas tank. I can send pics of actual tank if needed. I paid $550. I'm asking $250 must pick up.
Seymour Indiana.
[email protected]
https://static1.pt-content.com/images/pt/2011/12/729321-1.jpg
Camaro Gas Tank, EFI Converted, With Evaporative Emissions Control, 1970-1973
Direct Replacement
18 Gallon / 68 Liters
Size 40 1/8" X 20 5/8" X 7"
0-95 Ohm Fuel Sending Unit
With Vent Pipe
Electronic fuel injection seems to be all the rage these days. Everywhere you look, Camaro's are running around with LS motors, LT1's and Ramjets. Converting over to these modern systems means more reliability, power, better gas mileage and a dressier engine bay. Converting over usually means modification to the fuel tank at great time and expense. These ready to install fuel tanks utilize a factory style stamped fuel tank and electric fuel pump that produce 85-115 PSI at 50-60 gallons per hour. All you have to do is install it in the place of your original, run 12 volts and fuel lines and your fuel system is ready. No guess work, no more headaches.
Seymour Indiana.
[email protected]
Direct Replacement
With Vent Pipe
