View Full Version : How do I keep fuel from sloshing out of filler neck?
nova6speed
12-13-2011, 11:02 PM
I went road racing at Thunderhill Raceway this past weekend in my Nova. Had a blast!! But had fuel creaping out of my fuel cap. I have a Rock Valley SS fuel tank with internal fuel pump, sump and baffles. I also have the stock style filler neck and stock type locking gas cap. There is also a small vent tube attached to the filler neck. I installed an extra gasket in the gas cap that makes a tight seal with the filler neck. But obviously not tight enough to prevent gas from creaping out. What's the fix? One way valve? Removing the stock filler neck and attaching a more modern filler neck? Any suggestions? Thanks...
jprewitt
12-14-2011, 04:32 AM
Sounds like you have a vented gas cap. Try swapping out the gas cap for a non-vented version.
nova6speed
12-14-2011, 04:44 PM
I am running a non-vented stock 1967 Chevy Nova chrome locking gas cap. Anyone else have this issue when they first road raced??
andrewb70
12-14-2011, 05:27 PM
I had a similar issue on my GTO. My problem was that the fuel was coming out of the tube that was attached to the vent. Once I installed a one-way valve in the vent tube all was good. Don't just plug the vent because it will cause problems as fuel levels go down. Your tank can even collapse.
MonzaRacer
12-15-2011, 11:13 AM
Drive slow and in a more subdued manner!:)
nova6speed
12-15-2011, 07:27 PM
I didn't plug up the vent tube, just left it in the original position-venting into a small hole in the frame. The fuel is definitely spilling out the gas cap. I think a call into II Much Fabrication will shed some light...thanks!!
Haaaaa...that would be too boring :)
parsonsj
12-15-2011, 07:32 PM
I think a call into II Much Fabrication will shed some light...thanks!!You bet. I know just the thing to fix it. :)
Randy67
12-16-2011, 04:51 AM
Hopefully you find a solution. I've had similar problems with my 67 El Camino. One solution I saw was in the tank of a 79 El Camino I had. The filler neck went into the tank all the way to the opposite side of the tank. Another was in the tank of the 2003 Sunfire I had, it had a flapper valve where the filler neck entered the tank (it had a plastic tank). When I pulled the tank to change the fuel pump, none of the fuel could get past that valve. Made for an easy tank removal & install without spilling anything, which I am usually good at doing (the spilling part). Unfortunately neither of these solutions are easy to do that I know of on older tanks.
nova6speed
12-16-2011, 05:40 PM
Hey everyone, I spoke to John Parsons today from II Much Fabrication. Had a very good conversation with John about the fuel slosh problem. It sounds like the cure is going to be his Gen 1 fuel vent system. Thanks to all that responded...
anthonys 69
12-16-2011, 09:05 PM
check out my post in the carb section stopping fuel from leaking out of your fill tube it might help good luck
