View Full Version : C5/C6 corvette hub bearing bolt pattern
Ppd1979
12-10-2011, 07:14 PM
Looking for the bolt pattern if someone has it for the c5/c6 hub bearings where they mount to the spindles.
12-10-2011, 11:45 PM
heres what i got.... i'll double check that 4.26" tomorrow. i thought they were symmetrical
silver69camaro
12-12-2011, 07:49 AM
They are on a 2.284" bolt circle, basically 58mm.
BADDRIDE II
12-12-2011, 08:32 AM
They are symmetrical....and measuring your way I get 3.980" spacing....and bolts that fasten are metric but measure .462" so depending on how much slop or what size shoulder the bolt has that you will be using I would adjust the hole size accordingly. If I recall the factory fasteners do have larger "shoulders" than thread size. Hope this helps.
Matts dimension though will be most helpful....but isnt the bolt circle actually 4.568?
Apogee
12-12-2011, 08:41 AM
X2...it's a symmetric 3-bolt pattern on a 58mm [2.283"] radius, or 116mm [4.567"] diameter, bolt circle. The center to center distance is 3.955" around the perimeter, hole to hole.
Tobin
KORE3
Ppd1979
12-12-2011, 07:48 PM
Thank very much everyone.
