View Full Version : converting a emergency foot brake to a hand operated e brake,
doitbby
12-09-2011, 10:30 PM
Id like to convert an emergency foot brake to a hand operated e brake.Does anyone know how to do this? Or any pictures of some cool ebrake setups?
12-09-2011, 10:57 PM
what make car? You can use a lokar kit....or a 4th generation Camaro arm and make a bracket to connect to the "y" cable.
novaderrik
12-10-2011, 03:51 AM
find a donor car that has an e brake that you like.. install it in your car.. then figure out how to get it to operate your stock e brakes..
doitbby
12-10-2011, 07:55 AM
its a 71 challenger. thanks for the help
solarguy09
12-16-2011, 02:11 PM
Sounds like someone is going to Drift a 71 Challenger....
Sweet...
John S
01-03-2012, 04:15 PM
I converted on my 86 Monte Carlo, I think this may be the only Monte around with a hand brake :)
I originally tried the Lokar kit (still have it in a box somewhere) but I did not like the way it needed to mount with the cables under the floorpan. I ended going with the 4th Gen camaro setup using a Lokar cable kit with corvette caliper ends to go with the Baer calipers. Works extremely well.
https://static1.pt-content.com/images/pt/2012/01/fbodyhandbrake-1.jpg
https://static1.pt-content.com/images/pt/2012/01/DSCN0158-1.jpg
amargari
01-08-2012, 12:44 PM
I used a setup from a 98 Camaro
www.apiem.com/camaro/brakes20100330.asp
