64Comet
07-06-2005, 07:15 AM
89 Ford 302 HO, stock bottom end, E303 cam, have 1.6 RR's may go to 1.72 rockers or an F303, 725 Demon carb on a single plane intake with A 3-3500 stall. Would like to keep original style headers and my intake and may go with a nitrous shot. Looking for head recomendations, aluminum or cast rion. Something that will just bolt on for the most part. Thanks!
E303
Cam Style:Hydraulic roller tappetBasic Operating RPM Range:2,500-5,500 RPMIntake Duration 050 inch Lift:220Exhaust Duration 050 inch Lift:220Duration at 050 inch Lift:220 int./220 exh.Advertised Intake Duration:282Advertised Exhaust Duration:282Advertised Duration:282 int./282 exh.Intake Valve Lift with Factory Rocker Arm Ratio:0.498Exhaust Valve Lift with Factory Rocker Arm Ratio:0.498Valve Lift with Factory Rocker Arm Ratio:0.498 int./0.498 exh. liftLobe Separation (degrees):110Intake Valve Lash (in):0.000Exhaust Valve Lash (in):0.000Computer Controlled:NoGrind Number:M-6250-E303CARB EO Number:D-225-16
F303
Cam Style:Hydraulic roller tappetBasic Operating RPM Range:2,800-6,000 RPMIntake Duration 050 inch Lift:226Exhaust Duration 050 inch Lift:226Duration at 050 inch Lift:226 int./226 exh.Advertised Intake Duration:288Advertised Exhaust Duration:288Advertised Duration:288 int./288 exh.Intake Valve Lift with Factory Rocker Arm Ratio:0.512Exhaust Valve Lift with Factory Rocker Arm Ratio:0.512Valve Lift with Factory Rocker Arm Ratio:0.512 int./0.512 exh. liftLobe Separation (degrees):109Intake Valve Lash (in):0.000Exhaust Valve Lash (in):0.000Computer Controlled:NoGrind Number:M-6250-F303
E303
F303
