View Full Version : Killer deal on the ultimate stock 1st Gen F-body subframe
Proforged
12-05-2011, 10:13 AM
For SEMA 2011, we set out to use the best bolt-on parts available in the aftermarket to create the ultimate upgraded stock subframe - and we're offering a killer deal on it to one lucky 1st Gen owner. The subframe has never been installed - everything is brand new.
We started with a brand new, OEM-replacement subframe from AMD. The performance upgrades are centered around the all-new Proforged CamberTech Tubular Upper and Lower Control Arms. The geometry-corrected upper arms utilize a stock-car style ball joint and the lower arms feature Delrin bushings and a truss-style coil over mount for full shock travel. The Tubular Upper and Lower Control Arms won't be available until March 2012 - so you'll be the only one on the block running this setup until then.
We're not selling anything off this subframe individually, but we've listed the prices below so you can see how much the whole package would cost to replicate. The package price is at the bottom.
Specs:
AMD OEM-replacement subframe ($1149)
Proforged CamberTech Tubular Upper Control Arms ($649 - estimated)
Proforged CamberTech Tubular Lower Control Arms ($599 - estimated)
Ridetech Triple Adjustable CoilOver Shock System ($1350)
Ridetech Tall Spindles ($350)
DSE Camber Shim Track Kit ($85)
Hellwig Elite Series Front Sway Bar ($156)
Proforged Billet Aluminum Sway Bar Brackets ($89)
Delphi 670 Steering Box ($599)
Proforged Inner Tie Rod Ends, Idler Arm, and Pitman Arm ($225)
Proforged Bumpsteer-corrected Tall Outer Tie Rod Ends ($99)
Proforged Billet Aluminum Tie Rod Adjusting Sleeves ($69)
Totally Stainless High Strength Stainless Steel Hardware ($269)
PST Forged Aluminum Hubs and Brackets for C6 Corvette Brakes ($399)
6-Piston C6 Z06 Corvette Calipers ($983)
14" Disc Brakes Australia 5000 series two-piece rotors ($864)
Right Stuff Detailing Stainless Steel Brake Lines ($89)
Total - $8023
Special Pro-Touring.com Price - only ONE available: $5999 INCLUDING freight to the 48 US States!
This is a first-come, first serve deal. The savings is well over $2000 when you factor in shipping costs.
Here are a few photos - the only thing that has been changed since these photos is the addition of the Ridetech Tall Spindle:
Thanks for looking, and let us know if you have any questions!
