grenade inspector
12-03-2011, 02:41 PM
This past week I finally got the front clip separated from the body on my 67. I will need to replace both outer rockers, quarter panels, parts of the floor in the passenger compartment and trunk, the tulip panel, the front 6" or so of the inner rockers, the window channels, and the outer sections of the cowl on both sides. Also, the inside of the roof and outsides of the internal structure have surface rust so I was considering removing the roof to access these areas and clean them up.
Yes I know it would probably just be easier in the end to just get a different car, but my questions are:
would it be feasible/advisable to remove the stock roof, clean everything up and re-attach the stock panel? would there be a better way to handle this? it is just surface rust, but I don't want to go through the whole rest of the car and have the roof rot out because I didn't take care of it now.
What would be the best strategy for replacing all these panels, replace a single panel at a time in a particular order or build a bunch of bracing inside the structure and tear the car apart and piece it back together?
Thank you everyone for lending your advice and experience to my build
