View Full Version : 69 Camaro DSE Dash insert, by Fletchers Customs
fletcherscustoms
12-01-2011, 12:34 PM
I was asked by a customer and fellow forum member "canrc" Raj to build a custom DSE dash insert , loaded with Autometer gauges for his Camaro he is building. We used a DSE insert, loaded with 9 gauges, radio slot, and vintage air vent.
http://www.lateral-g.net/forums/showthread.php4?t=24328&page=2&highlight=raj
The wiring was a custom harness from American Autowire, all wires use OEM style double crimp terminals, individually shrink wrapped and color coded to each wire color. Then fully routed for maximum clearance behind the dash, and allows for easy removal of the entire harness as a whole unit if need be.
The entire unit was sanded, primed, wet sanded then sprayed with a 60% gloss Matte single stage.
I wanted to show you guys another side of what we can offer here at Fletcher's Customs. These are available in any setup you can imagine, and priced very well. And the easy part all you got to do is drop in place and secure some wiring. Contact me for any more info
Here are some pics
Bad94
12-01-2011, 01:15 PM
I really like that set up.
OLDFLM
12-01-2011, 01:16 PM
Looks GREAT brother!! I'd expect nothing less than perfection from your shop!
zipsimons
12-01-2011, 01:32 PM
Any chance you would be up for a trade out on a dash panel for a 70-72 malibu? I made a custom 6 gauge cluster conversion to take place of the sweep style instrument panel. Its a simple cut out and drop in installation with mounting screws that mimic the factory dash pad screws. It also has turn signal and high beam indicators. The trade out I am requesting is my mdf templates for cnc aluminum ones. I will give you the rights to produce and sell them as well. you can see some pics in my build thread and I can send more if you entertain my offer.. Let me know.. Love your work by the way!
Zip
407-970-4046
Doug1
12-01-2011, 03:27 PM
Very nice work Chad! That thing sure is purdy!
QDiesel
12-01-2011, 08:18 PM
Very nice!!
DirtShark
12-01-2011, 10:16 PM
Really nice work, clean as can be...
robin93784
12-02-2011, 04:58 AM
what is the cost on a setup like that?
