View Full Version : Who wants to run @ Thunderhill January 23rd?
Flash68
11-30-2011, 04:10 PM
I'm signed up already and a couple others are likely joining.
Get a head start and some practice time on the track that will be the site of a 2012 Run to the X (American Street Car Series) event. :smoke:
Here is the registration page and NCRC is a first class track organizer.
http://www.ncracing.org/events.php
:machine:
firebob
12-07-2011, 05:21 PM
They were guaranteeing it not to rain or your money back when they first opened up registration for this date. I looked a couple of weeks ago and it said that the gauarantee was off for anybody else that registered. I have a buddy that will be there with his Shelby. I'm waiting for warmer weather in May.
Robert
Flash68
12-07-2011, 06:47 PM
Yeah not sure why they changed that.
sgernon
01-11-2012, 12:05 PM
I just noticed this event. I've never been on the track but definitely want to learn. My car has been on the street for a few months and i think all (most) the bugs are now worked out of it. Is there still room to register for this event and would you recommend a newbie participate?
I tried to email the coordinator on the website but have not received a response yet.
Flash68
01-11-2012, 12:22 PM
There is room left in the Driving School group, which is for those with no track experience. See here:
I have not run with NCRC yet but many I know have and say it is a good track sponsor and well organized. The price is about as good as it gets to get on a track as well. I don't see why this wouldn't be a good newbie place to start.
What is your car and setup?
Dave
sgernon
01-11-2012, 12:46 PM
Thanks for the reply, are you the Dave from the site?
Car is a 72 Camaro It has a pumped up fuel injected 377, Richmond ROD 6 speed, and 3.42 gears. Have Hotchkiss leafs on the back with QA1 shocks and QA1coilers on the front. Detroit speed subframe connnectors. I boxed the LCA's and added PT F-body tubular uppers and there solid bushings in the LCA's. Factory from sway bar and no rear bar. Brakes are C5 front and LS rear with hydaboost. I'm thinking to add some more aggressive pads and rotors if I head to this event since I jsut have cheap pads and rotors on it for now. I also have an autopower bolt in bar with 5 point harnesses to keep me in the seat. I'm pretty sure the car can handle the track much better than I can
I've been driving around the street and hitting the dragstrip every other week for testing and to deal with all sorts of small issues from exhaust rubbing to fuel pumps dying to oil pan leaks and shifting isssues but after ~9 months I think 99% of them are all fixed. Most importanly the leaks are fixed :)
Did I read it right that the cost $99 plus membership? If so count me in. I guess I'll be calling in sick to work.....
DO you have any recomendations for additional car/driver prep? I live in Sac so the drive is ~2 hours. Am I a pansy to trailer the car there or should I suck it up and drive?
Flash68
01-11-2012, 06:01 PM
Oh no, that is Dave Mills. He runs NCRC.
Your car sounds killer man. Another destroked 377 -- I love it.... I just finally added race pads too so this will my first track day with those. Sounds like you got some good track day essentials there already.
Yes only $99 plus a non-member fee I think of $10. Or it's like $40 for an annual. Not sure if I will make it 4 times with NCRC this year so I did the non-member thing. Plus transponder is an extra $20 I think.
What do you mean as far as add'l prep?
I am trailering and don't feel bad about that. Ya just never know what can happen on the way, at the track, or coming home ya know.
firebob
01-11-2012, 06:06 PM
Trailer it if you can. You never know what might happen and a two hour tow back home is no fun(ask me how I know). Most everybody that can, does trailer there and back.
Robert
Gitter Dun
01-11-2012, 07:09 PM
Open group still shows plenty of room so I'll wait ti'll I see the 5 day forecast before signing up.
sgernon
01-12-2012, 03:39 PM
As far as additional prep I was thinking more along safety items I should make sure I have more than anything. I'm already going to check all my critical bolts (contol arms, ball joints, linkages, lugs, etc), brakes, fluids. A few weeks ago I actually found my upper ball joint was loose and moving in the control arm, I never would have thought that would happen but now I check everything out with a good amount of detail.
rustomatic
01-12-2012, 08:41 PM
I may go to watch, as my car is probably not nearly un-kinked enough for such a commitment; I just put the bike rack on, after all. As it looks, it is never going to rain again, so conditions should be tolerable, if not completely inspiring. Maybe if I'm outside at the right time, I'll catch someone practicing on the road by my new front yard...
Flash68
01-13-2012, 12:19 AM
Yes, definitely great idea and one everyone should pay attention to. The smallest thing can either ruin or end your track, or worse, be a big safety hazard.
We are definitely doing a nut and bolt check including fuel system, suspension, brakes before heading up. Lots to do before Jan 23.... the punchlist never stops!!! :)
Flash68
01-13-2012, 11:37 PM
Here is a list I've saved from Stielow.
My safety check list for Open Track Days....
High temp brake fluid
High temp and bedded brake pads
Fire extinguisher
Differential catch tank or cooler
Rad catch tank
Transmission catch tank or cooler
Exhaust system hanger strong enough to take a day of track use. (This was a big problem with my old One Lap of America car until I started to us OE style hangers.)
Good seat belts
Easy to read gages – better if you have warning lights
Locktighted critical fastners. (I’ve seen a brake caliper come off at speed – not good)
I run a torque run over my whole car before a track event.
Stielow
sgernon
01-16-2012, 11:08 AM
Hopefully I won't be needing a cooler for the tranny or the diff at this stage but I think everything else is covered pretty well. I've been scanning the weather reports daily and if things don't look better soon I don't think I'm going to register for this one....
Flash68
01-16-2012, 11:33 AM
I know man.... what a ****ty forecast.... altho a forecast a week out has been known to change!
Flash68
01-16-2012, 06:15 PM
Ha, Monday the 23rd as of today is the only non-rain day in sight.... LOL
http://www.accuweather.com/en/us/willows-ca/95988/daily-weather-forecast/332003?day=8
sgernon
01-16-2012, 09:18 PM
I was looking at a different site and had given up. I guess I should purchase those new brakes and get them bedded in just in case.I was looking at a different site and had given up.
http://www.weather.com/weather/wxdetail/USCA1244?dayNum=7
Flash68
01-16-2012, 10:03 PM
Yeah like any of them know what the hell is going on beyond a 24 hr outlook.... LOL
I am using accuweather because NCRC uses that site as the determining factor on whether they offer rain-out refunds on Sunday the 22nd if there is at least a 10% chance of rain.
I'd really like to go but we'll see.....
sgernon
01-17-2012, 05:19 PM
Just checked the site and the driving school is sold out at this time. I'll have to wait and sign up for the next event. I hope for everyone else the weather holds out.
Gitter Dun
01-17-2012, 07:10 PM
Have fun and be safe out there guy's. I just finished my car today and I cant wait to get her out now but weather is not looking to promising enough for me to gamble on.
Flash68
01-17-2012, 09:48 PM
Meet me at Big Willow Feb 4 then.... :)
https://www.pro-touring.com/showthread.php?86277-90-Track-Day-Willow-Springs-Big-Track-Feb-4th-in-SoCal
sgernon
01-19-2012, 11:52 AM
I am tempted to head down there but since I'm a newbie I'm debating if the 6 hour drive down is worth it. Have you run with that group before and know anything about the people? I see they give basic instruction for new drivers but I'm curious how in depth they are.
Gitter Dun
01-22-2012, 04:51 AM
I'm seeing morning showers for the 23rd. What are you guys going to do?
asifnyc
01-22-2012, 08:43 AM
sorry guys. I'm out...
Gitter Dun
01-22-2012, 11:53 AM
Weather looks good for Big Willow but thats to far south for me. Alot more practical for me to tune in my own backyard.
Flash68
01-22-2012, 11:59 AM
I requested my refund. And I just registered for Feb 4 @ Big Willow. Only $90 with free timing. I better get more than 7 laps this time there. :)
firebob
01-22-2012, 03:56 PM
Just talked to my son in Chico. He says been raining pretty good all day and the hard stuff is still coming. Good luck to youguys that still try and go.
Robert
Flash68
01-25-2012, 07:41 PM
Unbelievable... NCRC emailed me and said there was ZERO rain all day Monday.... Ha.
Gitter Dun
01-25-2012, 07:56 PM
No fricken way!! That sucks!!
firebob
01-26-2012, 05:57 PM
So are they still going to refund? I'd bet alot of people cancelled.
Robert
Flash68
01-27-2012, 01:28 AM
Robert
If you signed up back in November or earlier, you got a refund. If not, you were rain or shine - no refund.
