View Full Version : heat sheilding material for gas tank?
rab
11-28-2011, 10:12 AM
1st off im not sure were to post this ?......
this ? is not for my protouring car, but for my 90 awd mazda protege winter ride,i did a dohc bp swap and homemade turbo set-up.
well the gas tank leaked and needed repair, the straps and heat sheild are rotted/rusted away...
well i just restored the gas tank,made new straps,still have to make a replacement heat sheild ect,ect. well these parts are not around or available anymore or are high priced.
well cause of the driveshaft mazda made a weird gas tank, they call it a saddlebag style, ie the driveshaft and exhaust run thru the middle, there is 2 sumps,1 on each side but still connected in the middle, its hard for me to explain, but i guess you could say it looks like a pair of sunglasses U--U
im still going to make a heat sheild out of sheetmetal, but i want to put some kind of sticky backed heat sheild material on the bottom of the tank also.
what kind of heat sheilding material do you guys reccomend?
11-28-2011, 08:33 PM
tin and fiber glass combo....you'll have to make. you see alot of late model cars with it. forget the stickey stuff.
rab
11-28-2011, 10:42 PM
is it just fiberglass matte inbetween sheetmetal???
any good pics of one?
rab
11-30-2011, 09:26 PM
i made the heat sheild today,but i would love to hear somemore info on heat shielding, maybe i can smash some kind of shielding inbetween the sheild and tank, since this shield mounts to the tank.
Kenova
12-01-2011, 10:35 AM
Some coating companies can apply a thermal barrier coating to anything you bend up. I've seen it used on turbo housings and under hood exhaust components.
Ken
