View Full Version : '67 Camaro build at work
Mr. Anderson
11-24-2011, 08:08 AM
Started a new job at the beginning of October. The main part of it is engine machining. It's been a lot of fun learning how to do that! The other part though, is building this car. The idea is for it to be a completely modern version of a '67 Camaro. The drivetrain is a GM Performance Products LS3 with 480 hp, with a Tremec T56. Rear end is a Moser 12-bolt w/ posi and bolt-in axles. Front suspension will be Fatman G-tech spindles, and it will have Kore3 brakes all around. A few other parts we've got so far...Ididit column, Detroit speed booster and master cylinder, Detroit Speed select-a-speed wiper motor, Detroit speed subframe connectors, Competition Engineering solid subframe bushings, and Vintage Air Gen IV Magnum A/C. Most of the fab work is done, it will be off to bodywork and paint soon.
Sorry for the poor pictures, there are all from my phone...haven't remembered to bring a real camera yet.
Smoothed firewall, Willwood clutch m/c mounted and relocated wiring harness location for more clearance around the m/c.
Mount for the GM throttle by wire gas pedal.
Only required a slight bump at the front of the tunnel to fit the T56
Car was not factory air, had to cut the holes for the astro vents. Also heavily modified the center of the dash to fit a '69 center A/C vent, a double DIN stereo, and the Vintage Air controls at the bottom.
powerplant!
Kenova
11-25-2011, 07:06 PM
Second post of the thread and I'm going off-topic .... lol.
What's the story on the Hornet?
Ken
Mr. Anderson
11-25-2011, 08:32 PM
My boss's brother (and a friend of mine)'s project. The drivetrain is stock, but he's been working on a big brake kit for these cars. Has 13" rotors and dual piston calipers...something I think he is close to putting into production. He also has an AMX with the same brake kit.
http://www.sabinespeed.com/site/index.php?option=com_content&view=article&id=8:ssas
454bug
11-25-2011, 10:20 PM
Nice list of products.
Great start to the project! :twothumbs
AKlowriderZ71
11-25-2011, 10:31 PM
Subscribed, I wanna follow this one!
SRD art
11-26-2011, 08:51 AM
Lookin' cool so far, keep it coming!
