View Full Version : 5.3 engines
85coupe50
11-23-2011, 10:45 AM
https://static1.pt-content.com/images/pt/2011/11/53_400_PartsUnlimitedInc-1.jpg
This is what I found from another forum and a member on there turned me onto this Co. as he got his complete engine intake to oil pan with harness and ecu from them for $400.00.
Figured I would post here just in case there is someone looking for LS series engines.
Easiest way to get the info. Should be able to find the same locally when you change the locations.
www.car-part.com
Hope this Helps anyone that might be looking to snag a low buck 5.3 setup.
pjku79
11-23-2011, 10:52 AM
This isn't a company, but a website that lists all of the stock at junk yards across the country. I have been using it to locate an engine locally in San Antonio.
85coupe50
11-23-2011, 11:35 AM
Parts Unlimited Inc. is the Co. here in Houston that I have been able to find them the cheapest and also most complete. car-part.com is the site used to locate them after a forum member indicated he got his 5.3 there for $400.00. Wasn't sure if everyone knew about car-part.com I figure it had to be a good helper site for those looking to do a lot of budget builds.
