View Full Version : adjustable master cyl t56
lethal95
07-04-2005, 10:32 PM
i need a adjustable master cyl for my 72 camaro. the new gm piece i had broke right where the pedal linkage and rod are crimped together. anybody know where to get one.
HarleyT
07-14-2005, 04:21 AM
I had the same thing happen butI just threaded the end of the rod and made it adjustable. I think mcloed sells them
68protouring454
07-14-2005, 07:09 AM
yeah just thread the gm rod and use a femal erod end or a coupling and a male rod end to couple it to the clutch pedal, then make sure you do not have over 1 inch of travel as you will blow out master
jake
lethal95
07-14-2005, 10:14 PM
Thanks for the help . im going to do the rod end trick. but as luck has it. i was in the car working on the gauges and had to move the shifter. well now the trans is stuck in gear.
