View Full Version : GM Performance Parts LS Muscle Car Oil Pan -19212593 / LH8
Chad-1stGen
11-19-2011, 07:01 PM
This pan is off my never installed Mast Motorsports LS3 427. It had oil in it and was on the motor when it was dynoed.
What I'm selling:
The pan
Oil pick up tube
Two rear oil pan bolts (these are the specific length ones to the pan).
What's not included. Remaining oil pan bolts. windage tray, dipstick, Oil pan gasket
$95 plus shipping.
GRNOVA
11-19-2011, 07:03 PM
Is this just a stock f body Pan might b interested if not
badazz81z28
11-19-2011, 08:49 PM
I would like to know if its an F-body pan as well.
reedld
11-19-2011, 09:00 PM
No...it is not OEM f body..I have this exact pan on my 78 TA and it hangs a bit low..I am swapping it out for the stock ls1 f body pan. My car came with the LH8 pan..and although it has not it anything..it does hang below the crossmember.
https://static1.pt-content.com/images/pt/2011/11/OilPan2-1.jpg
Chad-1stGen
11-19-2011, 09:32 PM
As mentioned above this is not a stock F-Body pan. It is GM's "muscle car" oil pan. I believe it's just the Hummer OEM pan so the sump is fairly deep. It's deep because the moved it back so far to clear cross members and rear steer cars.
reedld
11-20-2011, 04:55 AM
Chad, you are correct. It is specifically for the hummer H3. Thanks for pointing out the fact that the rear two bolts are longer..That will help me later....GLWS.
