    Results 1 to 11 of 11
      Melbourne, FL
      Multi meter > 10A DC ???
      Been looking for a new multi meter. My old Shack one died after 20+ years. But I'm having a hard time finding a meter that measures DC current of more than 10A. Even the analog meters I seem to find locally only do 10A DC. Any suggestions ???
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Mountain Springs, Texas
      For more than 10 amps you will likely have to go with a clamp on style ammeter function on the multimeter. Lots of them on ebay. Clamp on is much easier than connecting your ammeter in series with the load.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Melbourne, FL
      Jun 2001
      Orlando, FL
      I've got a 20A capable one. Picked it up at Radio Shack.
      ​John Parsons
      Melbourne, FL
      Scored a new Milwaukee 2239-21 M12 off of ebay as a one day cyber sale for $59.99 shipped free. These sell for $399.00 at Home Depot. The sellers normal price is $259.00. Seller had a 99.7% rating on 130k+ feedbacks so I hope it's as described.
      Rustburg, Virginia
      I have a Columbia Electric Mfg. Tong Test "clamp" style gage here at work that I use to calibrate/verify our welding machines with and it has three heads that go with it...0a-50a, 0a-200a, and 0a-500a. It measures A/C or D/C current.
      Northwestern NJ
      Ideal makes a relatively inexpensive AC/DC volt/ampmeter #61-768 for about $170.00. It's a straight VA, it doesn't read impedance, so if you need to have one that does, Then you want 61-765 GA, but your looking at a little more money, probably about $80 more. If you're a serious auto electonics guy you need a Fluke 88V/A, but it's an easy $650.00 & you still need a separate amp clamp to do above 10 DCA.
      Tommy
      Tommy Souren
      "The older I get, the faster I was."
      Grandma's 20k mile '80 Malibu Classic, in-progress factory style LS6 454, Legend LGT 700 5 speed, 9" 3.70 posi, Global West suspension, 12"/11" discs.
      Jul 2010
      Sacramento, CA
      Quote Originally Posted by LS6 Tommy View Post
      Tommy
      ^Thats what I have, I love it. I also have a 87 for the RMS functionality.
      -James
      1974 Z28 SCCA C Prepared
      1990 Firebird NASA CMC
      1989 Civic Si SCCA STC
      Florida
      Quote Originally Posted by 67 455 Bird ragtop View Post
      I see you bought a new meter but before you toss the old one open it up and see if there's a fuse you blew. I've blown the fuses in Radio Shack meters and just go get a new fuse.
      Melbourne, FL
      Quote Originally Posted by NOT A TA View Post
      Thanks. I did that. It looked like a combination of things. Looked like a few blown components and battery leakage. It was almost 20 years old. It led a good life
      Southern Indiana
      too bad you found one so cheap I have a Mac version of the OTC Perception and could have possibly sourced a low amps clamp also and it is for sale for $400 obo AND it also have single cylinder ignition capabilities.
      But oh well at least you got something to hopefully get you going.
      Lee Abel
      AFTERMARKET PERFORMANCE
