View Full Version : Best steering box for a pro -touring 1966 skylark??? what are you guys running???
66larkgs
11-16-2011, 05:21 AM
looking into buying a new steering box and wanted to know what you guys are running and what you guys like.
The car is a 66 skylark b body spindles, kore3 hubs, c5 brakes all around, tubular control arms , qa1 coil overs up front, 1.250 sway bar, and the only thing i need to buy is a new column and a steering box.
Thanks Paul
killer69
11-19-2011, 09:08 AM
LEE 14.1 bolt on and go
Later-A-body
11-29-2011, 10:11 PM
X2 on the Lee Manufacturing. Just send them your box, and pick the ratio you want. I run a 12.1. Works flawless. No fabrication.
UMI Tech
11-30-2011, 05:08 AM
I have a Lee steering gear on my dirt modified and although not the same situation, I can vouch for Lee's excellent tech and customer service.
ramey
CTX-SLPR
11-30-2011, 08:35 PM
Lee redid my '64 Riviera box with a much higher effort torsion rod and spool valve as well as quickened the ratio up. Can't tell you how much it improved the driving experience of the car. I liked having the original box rebuild since it keeps the internal stops in the right spot instead of worrying about matching a different box.
MuscleRodz
12-01-2011, 09:06 AM
DSE or LEE
rockytopper
12-01-2011, 09:41 AM
removed
rockytopper
12-01-2011, 09:42 AM
I'm running CPP new 500 series very happy direct bolt on to my 1965 cutlass.
MonzaRacer
12-05-2011, 12:09 AM
Lee Mfg 818-768-0371 best box period
