View Full Version : Steel fuel lines, what fittings to use?
astroracer
11-10-2011, 05:01 AM
I am going to run 1/2" steel hydraulic tubing for both fuel feed and return lines on Bad Ast. I have done some research but just can't seem to find good info on what fittings will work with this steel line.
I know I will probably end up with a tube nut and sleeve to adapt to the soft lines at either end but I would like some input from anyone who has done this with success.
Mark
dj3
11-10-2011, 05:16 AM
I welded bung onto hardline and then used adapters.
http://www.summitracing.com/parts/RUS-683710/
http://www.summitracing.com/parts/RUS-640550/
http://www.summitracing.com/parts/RUS-640940/
mnm99
03-24-2012, 07:34 AM
Here
http://www.swagelok.com/search/find_products_home.aspx?part=SS-810-6-8AN&item=20b6dcb5-5a04-42f1-9df7-a5d3fd3672c3
I used 1/2" compression to 8AN. Adapted that to Teflon flex hose. Perfect with no leaks. DO NOT USE the fittings made for Alum line. They will leak.
DAMN...EDIT...Just saw how old this thread was. Oh well it will help someone....
astroracer
03-24-2012, 02:06 PM
Hey thanks!
It's not that old... I had settled on compression style fittings to adapt to the -8 AN fittings. I still haven't bought them yet...
Mark
astroracer
11-01-2012, 07:59 AM
Here is an update to an old thread. I just wanted to get these fittings out there incase anyone else is wanting to run steel lines.
I will be using YOR-LOK compression fittings from McMaster Carr. They go from the 1/2" steel line to any size pipe thread you could need. I will be using the 3/8th female NPT and running 3/8th male to -8 to get from the pump and out to the engine.
http://www.mcmaster.com/#yor-lok-tube-fittings/=jz4ig9
These are designed to work with gasoline and have dual ferrules to provide a leak-free seal. No worries running these, they'll work great!
Mark
astroracer
11-02-2012, 08:54 AM
Had a few questions on another board concerning what fittings I am using. here are a couple of links to the ones I am ordering.
The Yor_lok adapter I am using is this one.
McMaster-Carr
The -8 aluminum adapter I am using is this one:
Earl's AT981608 Earl's Ano-Tuff Adapter Fittings
Mark
astroracer
11-02-2012, 08:56 AM
http://api.viglink.com/api/click?format=go&key=a9d9b9a4ad07e190e5bd8d487c60e627&loc=http%3A%2F%2Fwww.clubhotrod.com%2Fengine-talk%2F52225-compression-fittings-steel-fuel-line.html&v=1&libid=1351875434045&out=http%3A%2F%2Fwww.mcmaster.com%2F%23cadinlnord% 2F5929k56%2F%3Djzmefe&ref=http%3A%2F%2Fwww.clubhotrod.com%2Fsearch.php%3 Fsearchid%3D440827&title=Compression%20Fittings%20for%20steel%20fuel% 20line&txt=McMaster-Carr&jsonp=vglnk_jsonp_13518755883063
http://api.viglink.com/api/click?format=go&key=a9d9b9a4ad07e190e5bd8d487c60e627&loc=http%3A%2F%2Fwww.clubhotrod.com%2Fengine-talk%2F52225-compression-fittings-steel-fuel-line.html&v=1&libid=1351875434045&out=http%3A%2F%2Fwww.jegs.com%2Fi%2FEarl%2526%2523 039%253Bs%2F361%2FAT981608%2F10002%2F-1&ref=http%3A%2F%2Fwww.clubhotrod.com%2Fsearch.php%3 Fsearchid%3D440827&title=Compression%20Fittings%20for%20steel%20fuel% 20line&txt=Earl's%20AT981608%20Earl's%20Ano-Tuff%20Adapter%20Fittings&jsonp=vglnk_jsonp_13518756043374
