View Full Version : New to Supercharges, have SN2000 & have some questions
ed1le
11-07-2011, 05:32 PM
Picked up the Iroc in my signature last weekend and have some questions about the combo, boost potential, power potential, etc. Car runs, seems tight but had either an intake leak or headgasket (prior owner had intake off and after re-installing discovered coolant in oil). Regardless, yanking the engine to freshen since there's coolant in the oil. I've read that the SN2000 maxes out around 8lbs of boost. My set up has a procharger intercooler so wondering if that would help increase the boost any? Also, engine has Comp Cams C305 cam w/ 1.6 roller rockers; would I be better off w/ a blower cam of some sort? As a wicked idle, just curious if there might be a better matched cam that could help make more power. The other question is, what's the power potential of this combo currently? ZZ4 block w/ forged rotating assembly, compression is 9.2, Pro Topline heads (64cc, 205cc & 2.02/1.60) there is some port work done to the heads on the intake side (have intake off already), has 30# injectors, 58mm TB, 1-3/4 SLP headers, etc. Lastly, there's an NEX 125hp wet nitrous setup on it. Claims to have never been sprayed but curious what concerns, if any, there might be w/ nitrous & boost. Contemplating just selling the kit but not sure.
