View Full Version : Urethane bushings squeaking
69X22
11-04-2011, 06:26 AM
What is the best way to stop the urethane bushings from squeaking in a G-bar rear suspension?
11-04-2011, 08:19 AM
remove them and lube em up good.
Johnny Blaze
11-04-2011, 08:26 AM
Make sure to use the proper lube.
parsonsj
11-04-2011, 08:38 AM
Urethane bushings need periodic lubrication, and wear out quickly. To add to what Vince said, remove 'em, inspect 'em, (replace 'em if necessary), lube 'em, put 'em back in service.
You should probably plan on doing that annually at a minimum, more often if the vehicle is used daily.
69X22
11-04-2011, 11:00 AM
What do you guys recommend to lube them with?
Johnny Blaze
11-04-2011, 11:28 AM
http://www.spohn.net/shop/1982-1992-GM-F-Body/Suspension/Polyurethane-Bushing-Chassis-Grease/Polyurethane-Bushing-Chassis-Grease-14-oz-Tube.html
69X22
11-04-2011, 02:38 PM
