View Full Version : 69 mustang project "Sally"
MattWash08
11-03-2011, 05:53 AM
Ive had this car since October 2004. I was 15 at the time. Bought it off of Ebay :hammer:
The car came out of Pennsylvania so its Definately a Rust bucket...
I am currently in college so everything happens at a very slow pace, the car shares DD duty with my truck :bananna2:
rundown of specs when i first got the car:
-tired 302 4bbl motor
-c4 auto
-manual drum brakes
-no a/c
-2.79 gears with open carrier(8" rearend)
-worn out suspension...
Whats been done so far:
-T5 manual trans swap
-Power breaks w/ front disks
-Vintage air a/c installed(Texas summers are HOT!!)
-CD player for the tunes(to drown out the squeaks lol)
-shock towers replaced
-new suspension(5 leaf reverse eye rear springs, front coils still need to be cut. Sits like a gasser:pat:)
-subframe connectors welded in
-3.80 gears and an Aburn posi in the 8" rearend
Short term goals:
-replace the leaky factory power stearing with a manual rack and pinion setup
-racing style seats
-replace my 14/15 wheel setup for late model 17" wheels off of craigslist with spacers
-cut front coils to get stance right
-Bilstein race valved shocks from Maier Racing since the car will sit so low
-larger front sway bar
-motor rebuild at some point, maybe a nice little stroker
Long Term Goals...Very Long term:
-fix/replace rusted areas... theres ALOT!(might even need to find a donor shell..)
-paint(cheap, as it will always be a driver)
-Modern ford motor with forced induction
-upgraded manual trans
-9" rearend
-mini-tubs
-some sort of aftermarket suspension
-big brakes
-caged
-Nice wheel/tire combo
now some pics..
oldest one I have, had the car for a little over a year at this point(dark picture makes it look much cleaner than it is..
https://static1.pt-content.com/images/pt/2011/11/l_4a6da82d37019822f6a2f120da53eae2-1.jpg
new towers in(still old suspenion though)
https://static1.pt-content.com/images/pt/2011/11/091-1.jpg
https://static1.pt-content.com/images/pt/2011/11/098-1.jpg
dont have a picture with the new suspenion yet that showers how high the front end really sits!!
more updates to come over the winter
DrFraZZy
11-03-2011, 07:40 AM
Those lip spoiler in the front, surely makes a huge difference! Looking good! DO it right once! even if it s slow.
MattWash08
11-03-2011, 09:28 AM
yea it has a lip spoiler again. I think it makes a big difference with the front end too
aussiebj
11-03-2011, 10:43 AM
69 stangs rule..
MattWash08
04-07-2012, 08:31 PM
I picked up some bullitts for a good deal this morning before work. Factory Anthracite 17x8's up front on some 235/50rz17 meats and some 17x10.5 repro's with nitto 315/35 drag radials out back. The color of the repro's arent spot on, theyre lighter, more of an actual silver color. But im not worried about it. all tires have good tread and it they look that bad, Ill paint the centers black on all of them. cant wait to try and stuff them. Need to pick up new lugs, and dig out the BFH in the garage haha
https://static1.pt-content.com/images/pt/2012/04/5L55Fa5H73F43Jd3H9c476e6a974e759819c7-1.jpg
Compaan-Designs
04-08-2012, 04:11 PM
I love '69 and '70 Mustangs.
This one has a nice Mach1/Boss look with the front spoiler and hoodscoop.
I'l; be watching this project for sure :)
MattWash08
04-10-2012, 02:44 PM
Old tires on outside/new on inside..
https://static1.pt-content.com/images/pt/2012/04/IMG_20120409_143709-1.jpg
test fit one front with the 1" spacers and I think theyll work great even after I get the front end down some. Also test fit the drivers side rear using the other 1" spacer I have and it pokes out just past the fender. Have some ARP studs ordered so i can swap those out and run about 7/16". Probably going to have to run about a 5/8" spacer on the passenger side as my rear is offset a little. here are some cellphone pics of the mock-up.
https://static1.pt-content.com/images/pt/2012/04/IMG_20120409_181649-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120409_181753-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120409_143055-1.jpg
Compaan-Designs
04-11-2012, 03:36 AM
Nice fitment!
rfalker1
04-11-2012, 05:26 AM
Thats one bad college DD. I wish i had my car in college, i would have been sssssssssssooooooooo awesome!!! Instead I just rode around on my bike!!!. The spoiler looks great too. Good luck with the upgrades... question though, why are u doing a cage. Do you plan on racing??
MattWash08
04-11-2012, 07:43 AM
I want to be able to take it to the occasional track day, but I will most likely run a 4-pt roll bar. none of that will be happening for quite some time though. Also, not currently DD'ing the car. after how brutal last summer was in the Texas heat even with the A/C in the car, I picked up a truck as a DD. so now I can really take my time on parts and theres no issue.
thanks.
MattWash08
04-11-2012, 07:47 AM
oops, double post..
MattWash08
04-18-2012, 06:16 PM
Got a lot done last night and today. got the studs swapped out. Pulled out the stock length front springs and put my cut springs back in. I had put on the 1" rear lowering blocks last week. I also changed the oil and went and got it inspected today. NOWW Im just trying to deal with a squealing belt issue that I am going to try and remidy with a new alternator belt in the morning. used two 5/16" spacers on drivers side(5/8" total) and three of them on the passengers side(15/16" total) until i order single spacers for each side. On to the pics!(all cell pics tho..)
stock spring next to one of my cut ones
https://static1.pt-content.com/images/pt/2012/04/IMG_20120416_125610-1.jpg
and just some of how the car sits now
https://static1.pt-content.com/images/pt/2012/04/IMG_20120416_161238-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120416_161252-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120416_161307-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120416_161439-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120416_161554-1.jpg
MattWash08
04-26-2012, 07:40 AM
took a few pics the other day..
https://static1.pt-content.com/images/pt/2012/04/140-1.jpg
https://static1.pt-content.com/images/pt/2012/04/132-1.jpg
https://static1.pt-content.com/images/pt/2012/04/1481-1.jpg
Hollywoodknight69
05-20-2012, 07:42 PM
Great stance......Great Car.......Great Project!!! Keep up the good work as I will be watching this build very closely.
droptop73
05-21-2012, 04:59 PM
The car looks great, the stance is perfect.
MattWash08
10-27-2012, 05:02 AM
Photobucket account got all screwed up so most of the pics were moved into new albums.. So Im just going to post up random pictures. Im actually getting the car back from the shop monday from getting the motor freshened up!!
Ill try to go oldest to newest on pics..
https://static1.pt-content.com/images/pt/2012/10/11020122121-1.jpg
https://static1.pt-content.com/images/pt/2012/10/mustangyellowhouse-1.jpg
MattWash08
12-28-2012, 01:19 AM
Finally bought seats and fabbed up some simple mounts and got them in today. Its nice not having it sit on duct taped seats for the first time in years!!
https://static1.pt-content.com/images/pt/2012/12/010_zps6e0616bf-1.jpg
https://static1.pt-content.com/images/pt/2012/12/013_zpsb2cbb9db-1.jpg
https://static1.pt-content.com/images/pt/2012/12/020_zps532447f2-1.jpg
https://static1.pt-content.com/images/pt/2012/12/021_zpsc97d3fff-1.jpg
https://static1.pt-content.com/images/pt/2012/12/030_zps831e93c9-1.jpg
JBCO
12-28-2012, 04:52 AM
Car looks good. Love the ride height stance :)
gsxrken
12-28-2012, 10:16 AM
Great car. There's something about a beater that a finished car just cannot compete with. A magazine should take a gamble and do one month with just in-progress cars just like yours. Real life driven cars.
Carl @ Chassisworks
12-28-2012, 02:27 PM
Nice car. This is a great place to start or a great place to stay. :)
MattWash08
12-28-2012, 04:37 PM
Thanks Guys! today I made a little shifter extension to bring it back closer to me a bit. Dont have the $$ to be buying a new one so this should work nicely
https://static1.pt-content.com/images/pt/2012/12/043_zpsbc5e343b-1.jpg
https://static1.pt-content.com/images/pt/2012/12/040_zps3b4de3ea-1.jpg
Dolmaner
12-29-2012, 12:56 AM
love your car man, really inspiring, I'm 17 and will be starting college soon enough with my 68 as a dd
MattWash08
12-29-2012, 03:06 PM
Its frustrating at times because they all have their own little quirks, but definitely worth it! Plus the girls love it too haha
MattWash08
02-02-2013, 05:29 PM
Installed my new front sway bar today, I didnt realize how massive it was compared to the old one until i put them next to each other!
https://static1.pt-content.com/images/pt/2013/02/20130202170140_zps984482d4-1.jpg
https://static1.pt-content.com/images/pt/2013/02/20130202170205_zps96c89912-1.jpg
Z06killinSBF
02-03-2013, 04:41 AM
Should handle better, now let me borrow your wheels.
MattWash08
02-03-2013, 02:24 PM
It made a noticeable difference! Haha you can borrow them anytime
cwmiller
02-03-2013, 08:58 PM
Looks good, hope to see it driving around some time.
MattWash08
07-07-2013, 08:21 PM
Well the motor took a ****. cant get good compression so its going to need a complete tear down & rebuild.... Im on a budget still, but any suggestions for affordable performance things I could do?
Specs from supposed rebuild in 2001:
-302 block bored .030 over
-new PAW flat top pistons(new rings & bearings) for about 10.5 to 1 Compression
-Ported exhausted openings on heads
-new water pump
-new timing chain
-new high volume oil pump
-roller tipped rockers
-performer rpm intake
-Edelbrock 1406 600cfm carb
-Crane Fireball II 290H cam(216* @ .050 and .484 lift, intake and exhaust)
Now for some cellphone pics before she died!!!
https://static1.pt-content.com/images/pt/2013/07/instagramstang1_zps155d1112-1.jpg (http://s265.photobucket.com/user/mattwash08/media/instagramstang1_zps155d1112.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/instagramstang3_zps1c893a83-1.jpg (http://s265.photobucket.com/user/mattwash08/media/instagramstang3_zps1c893a83.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/instagramstang2_zps90a813ff-1.jpg (http://s265.photobucket.com/user/mattwash08/media/instagramstang2_zps90a813ff.jpg.html)
rwcstang
07-07-2013, 08:52 PM
very nice build!
Z06killinSBF
07-08-2013, 07:03 AM
Budget you say?
Re-ring and some aluminum heads.
MattWash08
07-11-2013, 09:51 PM
Budget you say?
I have Zero mechanical skills so Im going to have to have a shop do it.... The motor hasn't been torn down yet either so no telling if osemthing else in there is messed up
Nicks67GTO
07-12-2013, 12:29 AM
On a budget you say? Well a long time ago my buddies dad built him a 302 for his 79' fox body. Stock crank, stock rods with arp bolts and he polished the beams, flattop TRW pistons and moly rings. World products windsor heads that he did nothing more than clean up the ports and chambers and narrow the guide area inside the bowls. I believe it had an erson hydraulic FT cam around the 236/[email protected] range on a 108 ls, harland sharp roller rockers, victor jr intake, 750 DP holley and some cheap headers. That thing ran like a scalded dog for years and years of abuse backed by a tremec 5 speed and a deep geared 9". He hit an 11.99 in it one night but I think he gone to a bigger cam at some point and the air was just right. Anyhow he pulled it and sold it to a buddy when he built a 331 for the same car. That 302 is still in a Torino today making runs and its never even been freshened. Im talking hundreds of low 12 second runs at the track and beat mercilessly on the street for 10 years before he sold it to the Torino guy who is still running it. My point in telling you this, is that with little to nothing you can make a 302 ford run really hard and be reliable for a very long time. Theres nothing fancy needed. It will take some gearing though and to make that friendly on the interstate I would suggest a 5 speed swap if thats in the cards.
MattWash08
08-06-2013, 10:40 PM
Well motor rebuild has been put on the back burner.... Im toying with the idea of an ls1/t56. I think I can get it to fit in teh stock engine bay with a gto pan. Tunnel will have to be modified for t56 though... Still just an idea at this point. I know Zachalanche's project Half-Breed is running an LS motor... Mine would a cheap ugly hacked up cousin to his amazing car(seriously, his work is top notch on that car!). Any thoughts on if its doable with the stock style suspension/steering still in place?
Matt
AusMarty
08-06-2013, 10:57 PM
Eek, Ok...
I gotta say something LS swaps are cool yeah.
But the cleanliness of this build deserves a nice ford motor.
Get one out of a Mustang wreck or something, a supercharged donk.
rickpaw
08-07-2013, 03:09 AM
Matt
Yup, it's been done with stock style suspensions. Check out this thread
https://www.pro-touring.com/showthread.php?89855-LSx-1967-Mustang
There are several LS swaps into stock suspension mustangs on LS1tech.com
MattWash08
08-07-2013, 05:30 PM
Eek, Ok...
03-04 cobra motor/t56 would be AWESOME, but that thing wouldn't fit between the shock towers I don't think....
turboclevor
08-07-2013, 05:40 PM
with the first gens mod motors fit with relative ease if you do the boss 429 shock tower cutouts
AusMarty
08-07-2013, 06:20 PM
It is worth the 429 shock tower cut.
Dat Ford growl. :-3
MattWash08
08-27-2013, 01:18 PM
Well my impatience is starting to get to me.... On the hunt for a budget craigslist 351 I can drop in/possibly just add a cam to. I want to get this thing on the road, I miss driving it. Buy a 351 & swap over what parts I need off of my 302, then sell that(needing a rebuild)... Should be able to do it on the cheap! Hopefully haha
