Results 1 to 10 of 10
Thread: .5" spacer on drum hub-HELP!
07-01-2005 #1
I just mocked up the ls1 12" brakes on the workbench to check wheel clearance and it looks like the need for a wheel spacer of at least 3/8" and I will probably use 1/2". I have a couple of concerns- safety, can spacers be used and not stress the studs to failure (I will be using arp 12mm studs) -spacing as far as offset goes to avoid tire rub. Does the factory disc move the wheels outboard around .5"compared to drums?,- caliper float- when the capiler floats does it move inboard or outboard primarily?
With the drum hubs and .5" spacer would the wheel placement be in the same approximate place in the wheelwell as with the factory disc that I currently have on the front?
wheels are 16" V45, and new wheels aren't a legitimate option. Any info or opinions are appreciated. SS
07-01-2005 #2I'm having the same issue with my setup (LS-1 brakes and V40s). My plan is to machine my own spacer that registers on the hub, so that the studs remain loaded in tension only. I think the stock disc brake setup does move the wheel out, but I don't know if it was a half inch.
I think a half inch spacer is about the max that I would run, beyound that I'd be looking at a bolt on adapter. I don't know that it is necessary to have it register on the hub either, I'm mostly worried about a loose spacer causing an imbalanced condition on the wheel.
07-01-2005 #3Nancejd, Keep me informed as to how the spacers come out, I would be willing to purchase 2 from you if you made four. I am in the northwest so maybe I will PM you at some pt. Thanks for the reply, SS.
07-02-2005 #4
