View Full Version : side b-pillar exhaust dump
jordanh
10-25-2011, 03:18 PM
I can't get the idea out of my head... I wan to dump my exhaust out the side of the b-pillar. Similiar to the harbinger mustang, or Vaughn gitten rtr-x. For the most part I know how I'm going to do the fab work etc. My plan is to remove the rear seats and rework the floor to make a sort of Exhaust tunnel. My plan is to rework the floor and box it into the b-pillar on the inside. When all is said and done It will be boxed in so the exhaust never actually enters the interior. I have a few concerns with this.
first off is heat- I'm thinking it should be no different than running your exhaust up tight to your floor? Thinking some exhaust wrap and sound deadening should do the trick? This is going in a second gen f-body.
My other concern was vibration. The rtr-x mustang looks as if the exhaust just exits the side of the body, not actually attaching to it. Where as the harbinger mustang has a S.S.(?) plate thats welded to the exhaust tip and riveted to the body.
I seem to often have to remind myself that this is a weekend street warrior, and not a race car...but I really can't get the idea out of my head. If I don't go threw with it I'll just keep thinking about it. So why do you think this is a good/bad idea?
jordanh
10-25-2011, 03:23 PM
harbinger mustang
jordanh
11-01-2011, 05:52 PM
No advice huh?
Tom Welch
11-02-2011, 10:21 AM
what if you use the rocker panel to route the exhaust back to the b pillar, just in front of the wheel opening, kind of like a side pipe but attached to the car like the rocker panel is.
jordanh
11-09-2011, 03:23 PM
Are you saying to route the exhaust so it actually run threw between the inner and outer rocker?
If not, and you are just saying to cut a hole in the rocker... then the torque box and frame rail create alot of clearance issues.
Tom Welch
01-03-2012, 01:26 PM
I'm thinking that if you cut the rocker along the length of the car, then using a 4" pipe that is welded in place of the cut away part of the rocker you would be able to route a 2 1/2" pipe inside the 4 inch pipe wrapped with insulation and have it exit before the rear wheel like an attached side pipe. I'm still studying this idea for my 67 Firebird, but I think it will work if the pipe is as strong as the rocker once it is welded to the body. Somebody tell me I'm wrong and why so I can learn something about this.
ace_xp2
01-04-2012, 06:35 PM
Eleanor clones go through the rear torque box:
http://www.mustangdepot.com/OnLineCatalog/Exhaust/side-exhaust-kit.htm
They'd be a little low still, but it's an idea.
