View Full Version : Aircraft-grade Headlight Mod
vette427-sbc
10-22-2011, 04:32 PM
Just finished up a headlight conversion for my car. Cheap and works GREAT! If you have a car that uses 4 standard 5.75" bulbs you can upgrade the high beams to aircraft landing lights. They fit in the stock housings with a minor modification to the terminals.
These are GE 4537 aircraft landing lights. Definitely not DOT approved, but you shouldnt be using your high beams with other drivers around anyway.
All of my bulbs have dedicated 12gauge power and ground wires through a relay system off of the alternator.
Pics (I tinted mine yellow, they come clear)
https://static1.pt-content.com/images/pt/2011/10/IMG_0031-1.jpg
Heres how the terminals are... I had to bend and re solder them to fit inside the hole in the back of my headlight housing
https://static1.pt-content.com/images/pt/2011/10/DSCF1283-1.jpg
Its hard to get a good picture of the light output. This was the best I could do with only my iphone handy:
https://static1.pt-content.com/images/pt/2011/10/IMG_0053-1.jpg
https://static1.pt-content.com/images/pt/2011/10/IMG_0057-1.jpg
These are the best high beams Ive ever driven with... Its like driving around in daylight :smoke:
Heres the best pricing I found online:
http://www.bulbconnection.com/ViewSIMItem/bcrw/simid/1804/item.html
67 ls1 vert
10-22-2011, 06:26 PM
my friend had them on his car years ago. They worked really good. Good mod for the 4 light cars.
Yelcamino
10-22-2011, 07:52 PM
That's a different aproach for lighting. $11.04 per bulb isn't bad, but it says average life is 25 hrs. I guess considering you wouldn't normally drive for long periods with the high beams on, a 25 hr life span is decent.
rb70383
10-28-2011, 06:32 AM
How did you tint them? Been thinking of those my self. Nice job
vette427-sbc
12-09-2011, 04:25 PM
Late response... sorry
Duplicolor metal-cast paint. Lay it on as thick/wet as you can without running it. Took me a few tries to get it to dry glossy like that.
rb70383
12-27-2011, 01:57 AM
No prob. Thanks for the update.:twothumbs
