View Full Version : Infinity Camaro LS3 Project
Blevinator
10-21-2011, 06:58 PM
Hello,
My 1968 Camaro "project" started out im 3-2011 as a rust free (pretty
much) restored Pro Touring car.
It came with a 383 stroker and a 5 speed Tremec transmission.
I really couldn't post this build on a "true" Camaro site, as I would
most likely receive tons of hate mail. What I did to the car after I
received it would be considered wrong on so many levels by Camaro
purists.
2-2011
Purchased my "restored" 1968 Camaro coupe.
4-2011
Drove my new car to the performance shop
Pulled the entire drivetrain, which was sold to another enthusiast
4-2011
Towed car to local body shop for a "freshen up" on the paint
4-2011
After doing a thorough review of my body and paint work,
we decided to do an entire repaint, as well as a few
other tweaks. After reading several articles, I decided to have the car painted
with all panels, trim etc. off the car.
Body disassembly started
After owning 3 cars with LS drivetrains, decided to treat this car to the same.
Started collecting information on how to swap an LS drivetrain into my car.
After some research, started collecting parts for the project
Year to date collected parts include:
Katech LS3 crate motor (Forged Mahle flat top pistons, Katech rod bolts, ARP head studs, hardened pushrods, PRC dual spring kit,
C5R timing chain, Total Seal second ring, Melling high volume oil pump, ECS "small" blower cam mid 230's, 588 lift on a 117 LSA)
JRE Fuel System Upgrade
Injector Dynamics ID850's
PSI Conversions Engine wiring harness
New Camaro LS3 throttle body
C&R Racing LS Steam Vent Kit
All new GM sensors
Holley Alternator \ power steering bracket (Powdercoated satin black)
Alan Grove Components Low Mount A\C bracket (Powdercoated satin black)
SLP under drive crank pulley
ARP crank pulley bolt
Holley power steering reservoir kit
New Sanden A/C Compressor
New 160 amp alternator (98-02 Camaro style)
New power steering pump (corvette style)
New GM water pump (2010 Camaro style)
New GM tensioner (98-02 Camaro style)
Chris Alston Fab 9 rear end- w/ 35 spline axles and 3:50 gears chromoly w back brace
Chris Alston Billet G link rear suspension
Varishock front coilovers (adjustable) (installed)
Varishock rear coilovers (adjustable)
Ride Tech Tru Turn (full kit with spindles) (installed)
Ride Tech Strong Arms (upper and lower control arms) (installed)
Ride Tech billet gas cap
Wilwood Superlite 6R 6 piston front calipers (front) 4R 4 piston rear calipers (Black with white lettering) 14012271 (front kit) 1409219 (rear kit)
Wilwood slotted and drilled rotors
8" dual diaphragm brake booster
DSE brake booster bracket (reduced angle)
Right Stuff stainless brake lines
Wilwood braided brake lines (front \ rear caliper lines)
2011 Camaro ECM (Tuned for car it came out of, tweaked to remove necessary codes,etc.)
2011 Cadillac CTS-V drive by wire accelerator pedal (chose this vs GMPP pedal so pedal cover would fit) (Bracket powdercoated satin black)
Ironworks bracket for CTS-V pedal (Powdercoated satin black)
Kooks 1 7/8" swap headers (ceramic coated inside and out)
Oxygen Sensors with 02 extensions
Innovate LC-1 boost controller \ 02 sensor
Magnaflow stainless steel 3" exhaust (Will ceramic coat inside and out once mocked up)
4L80E transmission built by Jakes Performance
Kilduff flat top horseshoe shifter (short handle)
2800 Billet stall converter built by Performance Converters of Texas
TCI EZ TCU transmission controller \ programmer
TCI Paddle Shifter
TCI LS Wide pattern 4L80E SFI certified flexplate
BRP Hotrods sure fit crossmember (Powdercoated satin black)
Dirty Dingo sliders (motor mounts) (Powdercoated satin black)
Energy Suspension motor mounts
Energy Suspension trans mount
Holley LS swap oil pan
DSE quick ratio power steering box (ceramic coated)
DSE Mini Tubs (installed)
DSE Radiator closeout panel (will paint body color)
Oversize Sway bars front and rear w\ all new Energy Suspension end links, bushings (greasable)
BMR Del Rin subframe bushings (installed)
BMR Weld in subframe connectors (installed)
Moog ball joint
Moog pitman arm
Flaming River powdercoated tilt column
Entropy LS swap radiator with aluminum shroud and dual built in fans
C&R Racing Camaro direct fit heat exchanger model 56-00010
Aeromotive Phantom dual fuel pump setup (340lph E85 pumps)
Aeromotive 13101 fuel regulator (switching out for 2 port)
Aeromotive 12335 filter (switching out)
Right Stuff 3\8" stainless fuel line (switching to one 5/8" supply, 1/2" return)
Powder coated aluminum radiator overflow
Rock Valley narrowed stainless steel fuel tank
Anti squeak kit (neoprene) for gas tank
Braille 3121 battery in trunk (centered behind seat)
Braille aluminum battery mount
Dakota Digital guages (VHX Carbon, blue backlighting)
Dakota Digital Boost module
Dakota Digital digital gauge control for Gen IV Vintage Air
Painless Phantom Key push button start
Tri note horn
New Corbeau GTS seats II (sold Recaros in photos) Beefing up foam bolsters and springs for longevity
Corbeau seat brackets with double locking sliders
Passenger and driver seat bracket extensions (more leg room)
Rear seat (Mikes Custom) Seat is custom made fiberglass with foam. Covered in Ultraleather Raven Wing with Camaro emblems
Heated Seat kit with carbon fiber elements
Alien Enclosures trunk enclosure (black vinyl with suede inserts)
Rushforth Night Train 18x10 18x12 wheels in Black Chrome III
Toyo R888 tires 275 front, 335 rear
Flaming River tilt painted steering column
Momo "Quark" series steering wheel
Custom fiberglass console (covering)
Trim Parts one piece Essex carpet
3 point seat belts (Morris Classic Concepts)
Rear Morris Classic Concepts Lap Belts
Morris Classic Concepts Driving Lights
Pioneer 7" DVD App radio (replaced JVC chameleon)
Jl Audio HD 900 class D Amplifier (very compact, yet powerful and clean!)
Jl Audio 10" subwoofers (10w3)
CDT Audio Euro front component speakers
Monster cable speaker wiring \ rca cables
Stinger battery terminals, fuseblock
Accel lightning 1\0 guage power cable from alternator to battery location in trunk. Very light and flexible cable.
Accel Lightning 1\0 ground wires
Accel lugs
Fiberglass sleeving (conduit) over all accesible wiring (vehicle, audio etc.)
Powder coated window trim (front and rear)
Powder coated headlight \ grill trim
New front grill (made from GM tooling)
Exterior door handles (new)
1970-81 Camaro bullet mirrors painted to match car. Mirror bodies were media blasted have new mirror glass,gaskets,hardware.
All outside body seams (less engine compartment) welded and smoothed
Lizard Skin CI soundproofing (firewall,floor pan,trunk,wheel wells,whole undercarriage) (installed)
Anvil Auto Carbon Fiber Front Valance
Anvi Auto Carbon Fiber Header Panel
Anvil Auto Carbon Fiber Hood (waiting on another from Anvil Auto as mine's warped)
Anvil Auto Carbon Fiber Cowl Panel
Anvil Auto Carbon Fiber Trunk Lid
Anvil Auto Rear Spoiler
Billet Hood Pins (ordered from Anvil, brushed aluminum)
Fesler Hood Hinges (natural)
Fesler Hood latch
Fesler Hood adjusters (stainless)
Fesler large f door jamb vents
Fesler billet strikers
Fesler headlights
Inner glove box (new)
Carpet guard (new)
Master screw kit (inside and out)
Billet Specialties Pro Bolts (front inner sheet metal stainless bolts)
Totally Stainless body bolt kit
Metro MP 15 year weatherstripping, bumpers, grommets etc. (the best!)
All new interior knobs
All new glass
All new glass hardware (mounting hardware, stops, everything)
Eddie Motorsports taillight bezels
Eddie Motorsports trunk hinges
Eddie Motorsports marker light bezels
Lokar aluminum pedal covers
Nu Relics power window kit (front and rear)
Vintage Air A\C (Gen IV)- SPAL fans!
American Autowire Classic Update (wiring harness)
Raingear Hidden Wiper Motor
Custom order black wiper arms
Lokar parking brake pedal and cables
All new locks with late model GM key (coded to one key)
Innovate LC-1 boost controller with 02 sensor
DEI door lock actuators
Airaid Powdercoated cold air box (will run 4" stainless single piece tube from here to motor)
Modern Classic Interiors fiberglass dash pad
Modern Classic Interiors full length center console
Modern Classic Interiors center dash bezel
Marquez Designs rear package tray
Marquez Design trunk lid cover (May use TMI instead)
TMI one piece fiberglass unisuede headliner (black unisuede)
TMI unisuede door panels
TMI unisuede rear panels
TMI unisuede sail panels
TMI unisuede a pillar covers
TMI unisuede visors
Fiberglass kick panels (Screamin Performance) covered in Ultraleather Raven Wing
Billet dome light (Billet Specialties)
Digitails Rear LED sequential taillight kit
All new marker lights
All new lenses including taillights
LED markers,park lights, dome bulb
Nu Relics Door (s) boots
Billet Dash Vents (Restomod Air)
Ring Brother Billet door sills
Ring Brother Frame Rail charge port
Still Need:
Edelbrock dual ram intake
Second Camaro throttle body (switching
to Edelbrock dual intake)
Second air intake setup
Driveshaft (will have made once rear end is installed
Driveshaft loop
Doorjambs, dash, inner fenders, radiator support etc are being painted PPG Carbon Flash Metallic with PPG Ceramicoat scratch resistant clearcoat.
Exterior will be vinyl wrapped satin metallic gray.
Hoping to be completed late 2021 (lol-keeps changing)
Attention to detail has been paid close attention to.
I am building a true Pro Touring car that can do well on the road, be very reliable, even get decent gas mileage!
550 rwhp goal N/A
All systems built to handle much more
I have many more photos I will be adding.
Any input will be appreciated!
https://static1.pt-content.com/images/pt/2011/10/camaroside2-1.jpg
Beginnings!
https://static1.pt-content.com/images/pt/2011/10/camarofront-1.jpg
https://static1.pt-content.com/images/pt/2011/10/DSCN61151-1.jpg
https://static1.pt-content.com/images/pt/2011/10/DSCN6121-1.jpg
https://static1.pt-content.com/images/pt/2011/10/my_motor1-1.jpg
"Old" 383 Stroker only dyno'd at 354rwhp
https://static1.pt-content.com/images/pt/2011/10/DSCN61161-1.jpg
Sorry! 383 wasn't getting the job done!
https://static1.pt-content.com/images/pt/2011/10/DSCN6154-1.jpg
https://static1.pt-content.com/images/pt/2011/10/DSCN6230-1.jpg
https://static1.pt-content.com/images/pt/2011/10/DSCN61201-1.jpg
Ready for takeoff! Only 747 with 4 wheels!
https://static1.pt-content.com/images/pt/2011/10/DSCN61241-1.jpg
https://static1.pt-content.com/images/pt/2011/10/DSCN6122-1.jpg
Last restoration was 3000 miles ago
https://static1.pt-content.com/images/pt/2011/10/DSCN6148-1.jpg
Patchwork found under front fenders. One of the few replaced panels on the new transformation.
https://static1.pt-content.com/images/pt/2011/10/DSCN6218-1.jpg
Offensive panel removed. RH Tulip panel was good. Replaced lower sill panel (on right) as well. This was done on both sides of car.
https://static1.pt-content.com/images/pt/2011/10/DSCN6236-1.jpg
New Tulip panel installed.
https://static1.pt-content.com/images/pt/2011/10/DSCN6220-1.jpg
Closeup of LH lower door jamb replacement panel. Same panel replaced on other side of car.
https://static1.pt-content.com/images/pt/2011/10/DSCN6228-1.jpg
DSE steering box
https://static1.pt-content.com/images/pt/2011/10/DSCN6222-1.jpg
https://static1.pt-content.com/images/pt/2011/10/062-1.jpg
https://static1.pt-content.com/images/pt/2011/10/058-1.jpg
https://static1.pt-content.com/images/pt/2011/10/055-1.jpg
https://static1.pt-content.com/images/pt/2011/10/DSCF2528-1.jpg
Solid floorpans. Had been replaced upon last restoration.
Even left some blast media under the carpet!
Rybar
10-22-2011, 09:19 AM
Nice project, looks like you have a good plan and list of parts and that's quite a nice car your starting out with.
Blevinator
10-22-2011, 09:37 AM
Thanks so much!
My father owned a '68 Camaro. Out of all the cars he owned, he loved
it the most. I always loved the first Gens as well.
I had a hard time getting past the feel of a new car.
LS motors and the six speeds that go with them kinda ruined me.
My last car was a 2007 Z06.
I am new to the Pro Touring scene and had to do many, many, hours
of research on my own to get where I am. I ordered all that has been done.
Not turning any wrenches, but designing all on my own. As you know, no one
has a complete book on everything you need to know to swap these in.
I put together my parts list in an effort to help others in their design.
You car is awesome! Love the '69 body. Didn't see as many high end 68's,
so this one has to be exceptional! I am cutting no corners and am taking the time
to get the parts and the look I envisioned. Their are some undivulged design plans for the
car that will be shown once finished. This will be a one off design that will keep the classic
look, but nothing else. I hope others will like my taste, as I see many customs that are loved
solely by the owner. LOL.
Regards
CruizinKev
10-23-2011, 07:10 AM
looks good! very nice project and good work so far! already looked great before in silver! but it'll be also nice painted black. can't wait to see more of the progress! :twothumbs
Blevinator
10-23-2011, 02:02 PM
Thank you!
I have owned both colors, liked the black better when it was clean.
My reservation with black was that it spiderwebs easily.
The spiderweb effect is supposedly non existent with the PPG Ceramiclear that
I am using. Otherwise, I would have stayed with silver. I do have two other silver vehicles,
thinking three may be a crowd.
Going to include pics of the minitub job as it will be done tomorrow.
Thinking of pulling the frame and powdercoating it, as car is pretty much a roller.
Especially since we notched and boxed the frame. No rust for me! Guess it's my OCD acting up!
Have to know that car has absolutely zero issues.
Thanks for the comments.
I am thinking of using a Ford 9" for the rear end, but am looking for recomendations.
Also need help with the fuel system, as car should be over 600rwhp. Aeromotive has a new intank pump
that fits in place of a Walbro that should support this kind of power.
Don't know what to do on the rest, as I am not sure the Corvette regulator will work. Thinking hardline, or Teflon (Aeroquip brand) fuel lines,
maybe a combination of both. Thinking Rick's tank.
Looking at Speed Tech Performances torque arm setup, as I will be running 345's vs 335's in the rear. May do their coilovers in front as well.
Also need help with a custom intake. Thinking of custom bent stainless pipe (maybe powdercoated black). I want the least amount of joints possible.
Looking at a custom rear seat, as I am unsure of mine, with the minitub. Maybe a Mike's Custom setup?
Door panels. Looking at Fesler and Marquez.
Any recommendations will be greatly appreciated!
Everyone here has been so cool!
sixfivepost
10-23-2011, 04:19 PM
Wow, and what was wrong with what you started with? lol
That far exceeds anything I would have been happy to start with! :smoke:
Hey, if you've got the means, go for it!!
Cool car!
Blevinator
10-23-2011, 04:49 PM
Well, hate to say it.....but
The car felt old...lol
sixfivepost
10-23-2011, 06:47 PM
They're never really finished anyway... lol
Blevinator
10-23-2011, 07:01 PM
Thats what I was saying! Really wanted a good base to start from. Felt I bought just that.
Bmf5150
10-23-2011, 08:28 PM
Looks great!where u get center console at??
Blevinator
10-23-2011, 08:51 PM
Here ya go!!!
www.modernclassicsinteriors.com (http://www.modernclassicsinteriors.com/)
My design is sorta like the Machete
It will be posted to the site soon, as I am receiving the first one designed
specifically for the '68 Camaro.
Blevinator
12-27-2011, 06:30 PM
Just had mini tub kit installed.
Back at body shop getting soundproofing done,then back to paint booth.
More photos soon. Car is taking a while, but will be great when finished.
DirtShark
12-27-2011, 09:36 PM
This should be a good one, keep us updated with pics and good luck with your build...
67rally
12-28-2011, 06:48 AM
Car looks great, I'll be following this one for sure. Don't worry about what people say on other sites, there will always be purists. It's your car, do what you want with it. I started with a Plain Jane '67 because I didn't want to hack up a real SS or Z, but didn't want to be stuck driving and "old car" either. Still a work in progress...
Blevinator
01-08-2012, 08:57 PM
Heres my new center console. It is very well made and one of the coolest parts of the interior. My particular console was the first one built specifically for the '68 Camaro and is the one pictured on the website. modernclassicsinteriors.com MCI is now a forum vendor!
It will be covered in black leather. The lid opens to a large compartment. The inside bottom of the compartment is lined with neoprene.
joeko23
01-08-2012, 10:09 PM
A website called modernclassicinteriors.com doesn't exist. Can you please recheck the website? Thanks!
DirtShark
01-08-2012, 10:11 PM
http://www.modernclassicsinteriors.com (http://www.modernclassicsinteriors.com/)
joeko23
01-08-2012, 10:17 PM
Got it thanks
Blevinator
02-10-2012, 10:43 AM
https://static1.pt-content.com/images/pt/2012/02/KatechLS32_zps70fbec7b-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/KatechLS32_zps70fbec7b.jpg.html)
https://static1.pt-content.com/images/pt/2012/02/KatechLS31_zps18de260b-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/KatechLS31_zps18de260b.jpg.html)
Katech forged piston LS3
https://static1.pt-content.com/images/pt/2012/02/vhxgauges_zpsa66207cd-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/vhxgauges_zpsa66207cd.jpg.html)
Dakota gauges
https://static1.pt-content.com/images/pt/2012/02/EMStaillightbezels_zps01f87bab-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/EMStaillightbezels_zps01f87bab.jpg.html)
Taillight bezels
https://static1.pt-content.com/images/pt/2012/02/EMStrunkhinges_zps0807984f-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/EMStrunkhinges_zps0807984f.jpg.html)
Trunk hinges
https://static1.pt-content.com/images/pt/2012/02/EMSmarkerlightbezels_zps6e444eed-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/EMSmarkerlightbezels_zps6e444eed.jpg.html)
Side markers
https://static1.pt-content.com/images/pt/2012/02/CorbeauGTSII_zps4af29b7f-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/CorbeauGTSII_zps4af29b7f.jpg.html)
Corbeau seats (will be covered in leather to match rear seat, no headrests when done)
https://static1.pt-content.com/images/pt/2012/02/Mirrorfitment_zpsfd880cb5-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/Mirrorfitment_zpsfd880cb5.jpg.html)
Bullet mirrors will be painted body color
https://static1.pt-content.com/images/pt/2012/02/DSCF8141_zpsc9fc47e0-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/DSCF8141_zpsc9fc47e0.jpg.html)
335MM Toyo R888
https://static1.pt-content.com/images/pt/2012/02/RideTechGascap_zpsb1de9799-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/RideTechGascap_zpsb1de9799.jpg.html)
Gas lid
Mini tub is done
Seam sealing tubs, floor pans, cowls etc.
zipsimons
02-10-2012, 01:52 PM
Gonna be one sick ride! Kudos to doing what you want with the car and not caring what people think! I'm also on a chevelle site and there are plenty of people not pleased with my concept! Lol... Surprisingly, there are actually alot that do though. Looking forward to sreing your surprises. I love outside the box!
Zip
Blevinator
02-10-2012, 04:12 PM
Zip
Thanks Zip!
I have seen several outside the box LS cars selling for alot of $$. LS swaps seemed to be an acceptable
mode of transport for many. Its funny. I bought a restored car just to tool around in, and ended up here.
Should call it Project Money Pit, but am quite sure that name has been already taken. Infinity is the name of the project.
The name of the car will be unleashed once the beast itself is let out of its cage.
Just sent my deluxe door panels,rear side panels,dash pad,grab handle,a pillar panels, and rear package shelf panel to Mike, my fiberglasser.
He is re designing them (as he did with the center console) out of fiberglass. I am recovering all in leather. Should be interesting!
Thanks for the positive feedback! PM me the site and name of your car!!!
tubbed69
02-10-2012, 05:14 PM
very nice job so far,hard to beat the ls motors
Blevinator
02-10-2012, 06:33 PM
Amen!
I know someone will surely shoot me for this, and maybe it's because I dont know any better, but
I feel,all things considered (power per cubic inch,physical weight,gas mileage,durabilty,etc.) LS motors are
unbeatable. If there is a motor out there that is better in all of these catagories, let me know! Ill buy one!
My 505hp Z06 got near 25mpg highway!
zipsimons
02-10-2012, 07:30 PM
No doubt about the money pit! Lol. I actually was expecting to see an infinity 5.6 in your car when I saw the title! Haha.. I wanted to rob my nissan titan at one point if not for the unique sound, then for pure messin with the purists factor! You obviously will have an insane car capable of many things!
Chris 68
02-11-2012, 01:38 AM
Nice looking build so far! What size wheels are on the car now?
Blevinator
02-11-2012, 11:50 AM
17x9 rear (may be 8.5)
17x8 front (I think)
Looking at 18x10
19x12 (whatever Corvette size is)
Eliminating leaf springs, notched the frame. DSE tubs installed.
More pics of the seam sealing, metal work next week!
Added more parts pics above.
Thanks!!!
Blevinator
02-11-2012, 12:38 PM
More Parts
https://static1.pt-content.com/images/pt/2012/02/MomoQuark-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/MomoQuark.jpg.html)
Momo Quark Steering Wheel
Lizard Skin CI
https://static1.pt-content.com/images/pt/2012/02/DSCF3105-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/DSCF3105.jpg.html)
Riggs 74
02-11-2012, 08:11 PM
This is a great looking project, I will love to see it as it evolves. Nice choice on the LS swap. I am almost finished with my LS2 swap in a 74 Corvette. I was very unsure if I was doing the right thing by choosing the LS, but at this point, nearly finished, I feel I made the right choice. I feel the Gen 1 motors are a thing of the past and we will see many more choosing to do the LS swap.
Riggs
Blevinator
02-20-2012, 08:07 PM
https://static1.pt-content.com/images/pt/2012/02/DSCF2537-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/DSCF2537.jpg.html)
BuddyP
02-20-2012, 08:43 PM
Nice! I was in your position not too long ago with the welding and seam sealing... and boy do I NOT miss it!!
Blevinator
03-23-2012, 08:34 PM
Sure is some work!!
Going over all metal, even under the car to make sure lines flow well.
Blevinator
03-23-2012, 08:36 PM
https://static1.pt-content.com/images/pt/2012/03/DSCF3292-1.jpg
Love to see Fedex at the door!
Anvil Auto '68 Valance.
Should I leave it carbon fiber or paint with the car?
FRENCHBLUE72
03-24-2012, 01:58 PM
Id leave it carbon depending on how well it matches the paint...
Blevinator
03-24-2012, 05:59 PM
Paint will be black, so maybe starting out cf is a good idea.
Thank you!
Blevinator
04-02-2012, 02:39 PM
Just ordered Morris Classic Concepts driving lights and 3 point seat belts (front)
plus rear lap belts.
Billy has the ability to leave out the amber parking light lamp for use with my 68 Anvil Auto valance.
He is making mine up to work with the dash mounted switch versus working
only with the high beams. Now thats service!!
Robin (not sure if I spelled her name right) at Morris Classic is wonderful to talk to and will treat
you like gold! I recommend ordering directly from them! Ill post pics of the parts once I get them.
Car still in paint prison, but should be out soon with any luck!
evostilo
04-02-2012, 03:17 PM
Nice build its gooing to look real nice all black w/ a touch of CF
diesel25lrs
04-02-2012, 04:37 PM
Very nice build! post some pics of the 3 point belts when you have a chance! I'm doing a 69 almost Identical to this build and just got it back from paint...Project Schism... Can't wait to see how yours turns out! Good luck!
zipsimons
04-02-2012, 07:03 PM
definitely interested in seeing those morris lights! looking for some for the 69 valance that became one with my 72 chevelle bumper! I was wondering if you could get them as fogs only... now I know, thanks!
Blevinator
04-02-2012, 07:04 PM
Thank you!
Think I am going to do the carbon fiber rear spoiler as well.
Should go well.
Want to do just enough carbon fiber to stand out, without looking tacky.
Blevinator
04-02-2012, 07:06 PM
I will look at your build to see what I can learn!
Will post pics soon!
Blevinator
04-02-2012, 07:12 PM
Morris Classic Concepts actually adds the amber bulb to the assembly for the 69.
I just called them to ask them if we could get it done that way. They were very accomodating!
I will mount the lights in the valance and take pics immediately!
All these parts make it hard to wait, but at least I will be able to finish the car as I envisioned, without comprimise.
The lights are 55 watt halogens. I will be using them as driving lights and will be on their own circuit.
The switch actually shows what color is being illuminated by the halo. Coolest lights EVER!!
Blevinator
04-06-2012, 01:30 PM
Just received the Morris Classic seatbelts, and driving lights. All parts look amazing!
Posting pics soon.
Ordering head unit for turbo. Comp Turbo CT43 6767
67mm turbo 975hp capable triple ceramic ball bearing,21lbs, oiless.
Blevinator
04-30-2012, 08:05 PM
A couple of additions
Morris Classic Concepts lights. Had trouble fitting these. Pretty sure the valance mounting was off. Had to flip the visor for the light. Think I will powder coat the stainless visor for the lights to help them blend in. The lights are very good quality with glass lenses. The color of the led halo ring can be controlled from inside the car.
https://static1.pt-content.com/images/pt/2012/05/DSCF7308-1.jpg
PSI Conversions LS3 engine harness. This was a real bargain. Made to order $549! Only three wires to integrate into vehicle harness. No emission wiring,etc. Wires are lengthened to mount the ecm behind the dash. The harness has a really nice, sliding rubber firewall grommet for a waterproof seal.
https://static1.pt-content.com/images/pt/2012/05/DSCF7312-1.jpg
zipsimons
05-01-2012, 02:31 AM
Got the PSI harness as well! Very nice. You lost me on exactly what went wrong with the morris lights? Any close up pics
Blevinator
05-01-2012, 07:04 AM
The Morris lights comewith a polished metal shroud(bracket) that surround the lights. The part of the shroud that looks like a visor (sticks out) is supposed to mount mount in the hole in the valance facing up. It stuck way out when I mounted that way,so i inverted it. I am convinced that it is the aftermarket valance mounting points causing the issue. I had to elongate the mounting holesin the valance, and sand off some material to make it work. It looks good now.I am okay with the shroud being inverted, as it is just a gap filler. I will powder coat the shroud black and be done with it.
zipsimons
05-01-2012, 01:02 PM
I've heard there was some trimming neccesary.. My bumper is already painted. Thanks for sharing your experience to help me make my decision!
Blevinator
05-22-2012, 07:32 PM
https://static1.pt-content.com/images/pt/2012/05/DSCF7375-1.jpg
Blevinator
12-26-2012, 11:52 AM
More pics soon.
Bought more parts.
Car getting ready to be primed.
Setting gaps at 3\16",etc.
The Am1nal
12-26-2012, 02:32 PM
glade to see you are still going at it. i took a lot of your advice and my project is going smoother.
Blevinator
12-26-2012, 07:06 PM
Thats great!
Glad to help when I can.
Lord knows I've hit many road bumps and have re mapped my project more than once.
Blevinator
01-01-2013, 05:07 PM
Working on door gaps. Setting them at 3/16". Sliding the smooth end of a 3/16'" drill bit through the gap for consistency. We are also taking measurements at several points down the gaps.
Getting close. I installed new door hinge hardware on both doors to make sure they hung properly.
Fine tuning gaps
Waiting on Fesler to ship the hood hinges.
Should be very soon.
We are then panel fitting all the Carbon Fiber components including
front valance ,header panel, hood, cowl panel, trunk lid and rear spoiler.
Will also fit the bullet mirrors at the same time. Smoothing firewall as well.
More pics very soon.
From here on out, should start to get fun!
Blevinator
01-01-2013, 05:15 PM
https://static1.pt-content.com/images/pt/2013/01/DSCF7931_zpsdf6743e5-1.jpg
Front 6 piston caliper. Wow these are massive!
bonecrrusher
01-02-2013, 05:17 PM
Nice C6Z calipers there...
The Am1nal
01-02-2013, 06:12 PM
i love your high standards! my favorite cars aren't always the most horsepower or the prettiest but the clean ones and yours is gonna be clean.
Blevinator
01-02-2013, 07:20 PM
Thank you!
I owned a 2007 Z06 before this car. Cant imagine needing more stopping power.
I did, however add a hydroboost, just for good measure. I hope to make this car
as cool as my Z06 was. Simply amazing cars!
Blevinator
01-02-2013, 07:25 PM
Thanks for the comments! Your car is looking great!
I am adding an Eforce supercharger, so looking between 610-650rwhp.
Already have a blower cam(114 LSA for driveability), dual springs,etc.
You generally don't see high power and clean together, so trying to make
this one a little different.
Blevinator
01-10-2013, 06:37 PM
https://static1.pt-content.com/images/pt/2013/01/Rearwheel_zpsc07004e4-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/Rearwheel_zpsc07004e4.jpg.html)
New wheels
The Am1nal
01-10-2013, 08:29 PM
you wouldnt be selling your old wheels and tires would ya? lol
Blevinator
01-11-2013, 07:01 PM
Sold them already
Sorry man!
The Am1nal
01-11-2013, 08:34 PM
no big deal. the bigger retro wheels look great on old cars. what exact size were yours? looked like 18's to me.
Blevinator
01-11-2013, 09:47 PM
They were 17's.
Wheel Vintiques brand.
Blevinator
02-20-2013, 07:57 PM
Progress!!! Next is a full prime.
The firewall plate is from Mikes Custom Cars and will be welded in next, along with new through the floor BMR subframe connectors.
https://static1.pt-content.com/images/pt/2013/02/IMG_20130219_174650_zps4f0b4b72-1.jpg
https://static1.pt-content.com/images/pt/2013/02/IMG_20130219_143944_zps00b27e60-1.jpg
https://static1.pt-content.com/images/pt/2013/02/IMG_20130219_143937_zps388d8ab7-1.jpg
https://static1.pt-content.com/images/pt/2013/02/IMG_20130219_143929_zpsd8ff3b9c-1.jpg
https://static1.pt-content.com/images/pt/2013/02/IMG_20130219_143914_zps634c41c5-1.jpg
https://static1.pt-content.com/images/pt/2013/02/IMG_20130219_143908_zpsc009b79e-1.jpg
https://static1.pt-content.com/images/pt/2013/02/IMG_20130219_143858_zps47f08cc6-1.jpg
https://static1.pt-content.com/images/pt/2013/02/IMG_20130219_143840_zpsc9368371-1.jpg
https://static1.pt-content.com/images/pt/2013/02/IMG_20130219_143558_zps948c35e4-1.jpg
https://static1.pt-content.com/images/pt/2013/02/IMG_20130219_143428_zpsa92622bf-1.jpg
https://static1.pt-content.com/images/pt/2013/02/IMG_20130219_143214_zps53e640d9-1.jpg
https://static1.pt-content.com/images/pt/2013/02/IMG_20130219_142924_zps4dc2f079-1.jpg
https://static1.pt-content.com/images/pt/2013/02/IMG_20130219_142904_zpsb070f95a-1.jpg
https://static1.pt-content.com/images/pt/2013/02/IMG_20130219_142857_zps382823e6-1.jpg
https://static1.pt-content.com/images/pt/2013/02/IMG_20130219_142837_zpsa62a554e-1.jpg
https://static1.pt-content.com/images/pt/2013/02/IMG_20130219_142828_zps3f2a2218-1.jpg
https://static1.pt-content.com/images/pt/2013/02/IMG_20130219_142815_zps3ea30bff-1.jpg
https://static1.pt-content.com/images/pt/2013/02/IMG_20130219_142806_zpsa8e366d8-1.jpg
Blevinator
03-28-2013, 06:22 PM
https://static1.pt-content.com/images/pt/2013/03/Mirrorfitment_zps47d15909-1.jpg
Fitting new mirrors.
https://static1.pt-content.com/images/pt/2013/03/PanelFittingvalance_zps2587b745-1.jpg
120267
Fitting Anvil Auto carbon fiber header panel, hood, lower valance
https://static1.pt-content.com/images/pt/2013/03/Trunklidfitting_zpsbbdf41ad-1.jpg
Trunk lid fits well.
The Am1nal
03-29-2013, 10:23 AM
looking great man.
KnightMare
03-29-2013, 03:52 PM
I can't wait to finish welding and get the priming and sanding on my Camaro. Gaps look great
Blevinator
04-04-2013, 05:37 PM
Thank you!
I have many more updates coming very soon....tax return is here!
rocketrod
04-13-2013, 12:54 PM
This car is going to be amazing! Keep the updates coming!
Jonathantimms
05-20-2013, 11:29 AM
Sweet car right now I'm building a 1970 chevelle with an ls motor in it and its not even finished and I have people at autozone telling me its a shame I'm putting that motor in.... Im 19 and my chevelle will be my daily driver back and forth to college so i want something decent on gas and not a hassle to stop at a red light with. Its pretty ridiculous how people pretend like its up to them what we do to our cars. your car is going to be sweet and who cares what they think! Nice ride can't wait for updates!
Blevinator
05-20-2013, 11:54 AM
Car is going to the race shop this week to get the Tru turn kit, new subframe, and coilovers installed. Smoothing firewall, installing weld in subframe connectors, Lizard skinning interior and underbody.Will post more pics soon.
BTW, Jonathan, I was searching the last several Barrett Jackson auctions. The last several pro touring LS3 Camaros (with a nice interior,etc) average sold price was $137,000.
Guess LS power isn't such a bad thing!
The Am1nal
06-03-2013, 08:45 PM
What route are u gonna go with your motor now?
Blevinator
06-03-2013, 08:57 PM
Buying a forged LS3. Will be running 12 or so PSI so will need it.
Blevinator
06-18-2013, 05:17 PM
May keep the motor and just forge it. A little more money, but will know what I am starting with.
Blevinator
06-18-2013, 05:30 PM
More pics...getting closer to paint.
https://static1.pt-content.com/images/pt/2013/06/NewSubframe_zps77288e4f-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/NewSubframe_zps77288e4f.jpg.html)
New subframe. I am having a Screamin Performance tow\ jacking plate welded on. Welds are within the outline of the plate.
Priming frame side of plate with weld thru primer before installing to prevent corrosion.
Grinding the welds smooth. This plate will look factory when done. It will add hidden tow hooks to get the car into the trailer without damage.
Priming the frame and painting with John Deer Blitz Black. Using an airless sprayer to apply paint.
https://static1.pt-content.com/images/pt/2013/06/Smoothinglowertailpanel_zps1f5fcccc-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/Smoothinglowertailpanel_zps1f5fcccc.jpg.html)
Smoothing lower tail panel. Spent several hours grinding and smoothing bottom edges, as well as whole underbody.
https://static1.pt-content.com/images/pt/2013/06/Lowertailpanel_zps5200bcef-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/Lowertailpanel_zps5200bcef.jpg.html)
More detail
https://static1.pt-content.com/images/pt/2013/06/wheelwell2_zps97b8a278-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/wheelwell2_zps97b8a278.jpg.html)
Drivers wheel wheel being smoothed.
https://static1.pt-content.com/images/pt/2013/06/Doortoquarteralignment_zpsf9ab6033-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/Doortoquarteralignment_zpsf9ab6033.jpg.html)
Door to quarter alignment passenger. Rebuilt door hinges to achieve this.
https://static1.pt-content.com/images/pt/2013/06/doortoquarteralignment2_zpscdd6fcbe-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/doortoquarteralignment2_zpscdd6fcbe.jpg.html)
Door to quarter alignment driver.
https://static1.pt-content.com/images/pt/2013/06/wheelwell3_zps327aea33-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/wheelwell3_zps327aea33.jpg.html)
Smoothing wheel well passenger
steve671
06-19-2013, 10:39 PM
Where did you get your mirrors from?
diesel25lrs
07-11-2013, 06:32 PM
Looking awesome Blev! Keep the updates coming!
Blevinator
07-11-2013, 07:05 PM
They are OER 70-81 bullet mirrors
I sent the oem sandblasted ones I had back as I couldn't find any
without scratched mirrors or rusted parts.
Matts Classic Bowties carries them.
Blevinator
07-11-2013, 07:17 PM
https://static1.pt-content.com/images/pt/2013/07/DSEtowplate_zps538accc6-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/DSEtowplate_zps538accc6.jpg.html)
Welded Screamin Performance tow plate on new subframe
Blevinator
07-11-2013, 07:29 PM
Rear wheel Rushforth Nightrain in Black Chrome III
https://static1.pt-content.com/images/pt/2013/07/RideTechUppercontrolarm_zps974152ce-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/RideTechUppercontrolarm_zps974152ce.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/RideTechlowercontrolarm_zps22d73372-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/RideTechlowercontrolarm_zps22d73372.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/RideTechspindle_zps666877d4-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/RideTechspindle_zps666877d4.jpg.html)
Make sure you powdercoat the ride tech spindles. They will rust right away! LOL
https://static1.pt-content.com/images/pt/2013/07/RideTechGascap_zps86dd786d-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/RideTechGascap_zps86dd786d.jpg.html)
Ride Tech
https://static1.pt-content.com/images/pt/2013/07/Varishockrearshocks_zps77e651ef-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/Varishockrearshocks_zps77e651ef.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/Varisprings_zps3c57aa8a-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/Varisprings_zps3c57aa8a.jpg.html)
Varishocks
https://static1.pt-content.com/images/pt/2013/07/NuRelicPowerwindowmotors_zpsf655b177-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/NuRelicPowerwindowmotors_zpsf655b177.jpg.html)
New Relics
https://static1.pt-content.com/images/pt/2013/07/DSEcloseout_zps2bc7e71c-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/DSEcloseout_zps2bc7e71c.jpg.html)
DSE Closeout
Eddie Motorsports
Corbeau GTS II
https://static1.pt-content.com/images/pt/2013/07/VintageAirGenIVevaporator_zps827b5010-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/VintageAirGenIVevaporator_zps827b5010.jpg.html)
Vintage Air Gen IV system. These use Spal fans!
rocketrod
07-12-2013, 06:48 PM
DSE Closeout
Wow did you have a fleet of UPS trucks stop by.......and the DSE Closeout panel and finely crafted shipping container look familar...
Blevinator
07-12-2013, 08:01 PM
Gotta love UPS!
Thanks for the deal on the DSE closeout!
The Am1nal
07-13-2013, 10:59 AM
keep it coming!!!
sebtarta
07-17-2013, 04:32 PM
Blev keep at it. Thank you for the LS3 intake.
zipsimons
07-17-2013, 05:31 PM
crispy lines... lovin it!
ff5013
07-17-2013, 05:44 PM
I cant wait to see finished car. my heart is already skipping a beat
Blevinator
07-22-2013, 04:17 PM
Thank you!
Making sure it all looks right
before each next step is super important
to me on this car.
Blevinator
07-22-2013, 04:22 PM
Thanks for the comment!
Car has many surprises not seen here.
Want it to be one of a kind, at least for a little while.
Just bought a forged LS3 from Katech. Felt it was good insurance
since I will be strapping an Eforce on it.
Have my stock LS3 sold to another forum member.
Blevinator
08-23-2013, 12:57 PM
Started working on the firewall. Applied Lizardskin. New subframe installed. Front suspension is almost done.
Welding in BMR subframe connectors.
https://static1.pt-content.com/images/pt/2013/08/firewallplate_zps4d92ba17-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/firewallplate_zps4d92ba17.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/Frontsuspension_zps53385415-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/Frontsuspension_zps53385415.jpg.html)
Should have powdercoated the Ride Tech spindles before install.
They developed surface rust just sitting in the shop.
Removed them and powdercoated them black.
Blevinator
08-23-2013, 07:59 PM
https://static1.pt-content.com/images/pt/2013/08/rearpcktry_zps5e6d2a8a-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/rearpcktry_zps5e6d2a8a.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/wheelwell2_zpsda1ecaf6-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/wheelwell2_zpsda1ecaf6.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/trunkfloor2_zps3accca84-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/trunkfloor2_zps3accca84.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/rearwheelweelpassngr_zps06e85b3c-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/rearwheelweelpassngr_zps06e85b3c.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/passfrontrotor_zpsd62acbf9-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/passfrontrotor_zpsd62acbf9.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/passfrontsusp_zps56700d40-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/passfrontsusp_zps56700d40.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/frontsuspwithfirewall_zpsc771d76d-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/frontsuspwithfirewall_zpsc771d76d.jpg.html)
TonyV
08-24-2013, 10:00 AM
great project....need to know how the lizard skin went on and are you happy with it...?
Blevinator
08-24-2013, 10:20 AM
The guy that applied it said it was easy to spray. I purchased the Lizardkin application kit to help things along.
To me, it made a huge improvement over the way the underbody looked. I am very happy with it.
We did quite a bit of work to make sure the bottom of the car would look great before spraying it,
including using panel bond on all seams. The car was stripped of all components,brackets, clips,etc. before spraying.
We also sprayed it with the subframe removed. I feel prep is 99% of what will make this application look good.
It looks much better than bedliner and should make a huge improvement as far as the noise level of the vehicle.
Will be spraying the interior with Lizardskin ceramic insulation early next week.
TonyV
08-24-2013, 10:27 AM
good to know....i'm still on the rotisserie but plan on shooting it here in about a month...been working on prep as you said can't do enough. I also plan on shooting it with a single stage ureathane. How much did you use ........i bought 6Ga of the sound deadner and 4 Ga of the ceramic....?
Blevinator
08-24-2013, 11:43 AM
I used 4 gal sound control so far. Probably will use the same on CI.
Blevinator
09-11-2013, 07:59 AM
Rear Seat is in!
Mike's Custom Cars made this happen!
Very impressed with it!!
WICKED_SS
09-12-2013, 05:56 PM
Very Nice Build! keep it up!
67SSDan
09-15-2013, 04:50 PM
VERY nice man!
Dan
Blevinator
11-03-2013, 11:54 AM
Thank you!
Blevinator
11-03-2013, 11:57 AM
VERY nice man!
Dan
Much appreciated!
Car is having the firewall painted as we speak.
Will be in mechanics after that. Starting with all new wiring.
Decided to install all mechanics before paint, as I want to
avoid any damage to the final paint. Shouldnt be long now!
HOSTILETAKEOVER
11-04-2013, 01:44 PM
Nice build! Top shelf pics.
I have sprayed my 69 Camaro inside and out with Lizzard skin SD and Ceramic insulation. I have been told that it needs to be covered in a coat of paint (on the underside) to protect it from the elements. Mine is not on the road yet but I can't wait to see how effective the lizzard skin really is.
I have also covered the inside with a half inch thick layer of foam sound insulator sheet where I could. I am aiming for as close to modern OEM sound levels as possible.
Blevinator
11-09-2013, 01:20 PM
Car is at Sweedens Paint and Body in Garden Ridge Tx getting firewall smoothed and painted before major mechanical is started.
Finally, the fun begins!
11-24-2013, 01:00 AM
https://static1.pt-content.com/images/noimg.gif (http://s475.photobucket.com/user/Blevinator_2008/media/frontsubframewithsuspension_zps292f34af.jpg.html)
looks good but make sure they pull the sway bar and flip it over before they drop the engine in.
opnwide
12-24-2013, 07:42 AM
I just saw this link, and you beat me to it!
Great car. I'll forward this link to my bro, but he's really looking for a '65 fastback to build.
Blevinator
12-24-2013, 08:39 AM
Thanks guys!
The shop that put the swaybar on wont be touching my car again!
I have a great mechanic now that is going over all.
I bought stainless bolts to replace all suspension bolts that weren't stainless or zinc
plated.
I also purchased Billet Specialties Pro Bolts for the front sheet metal and
Totally Stainless OE style stainless bolts for the rest of the body. Inside the car,
I have a master screw kit that is labeled for each area to make sure the small details
are correct.
Blevinator
Thanks for the forward!
If the car gets to mechanics (mid January) I will finish it
Blevinator
02-10-2014, 05:58 PM
Just received my Screamin Performance kick panels!
Brian is a great guy!
https://static1.pt-content.com/images/pt/2014/02/ScreaminPerformancekickpanels_zpsdc7e870-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/ScreaminPerformancekickpanels_zpsdc7e870f.jpg.html )
FLYNAVY53
02-10-2014, 10:39 PM
awesome build!!
Blevinator
02-17-2014, 09:24 PM
awesome build!!
Thanks man!
Blevinator
02-26-2014, 10:59 AM
Just ordered the new heat exchanger from C&R Racing.
Part number 56-00010.
This is a direct fit heat exchanger.
No mods needed other than one drilled hole in the
radiator support!
C&R saved me a boatload of $$$$, as I would have had to have one custom made
and modify my hood latch \ support.
The exchanger is designed for ZR1 ZL1 LSA high horsepower applications, so will
be perfect with my forged LS3.
C&R worked directly with Vintage Air on this part.
It is said to work perfectly with the Vintage Air condenser!
Purchased it from Summit Racing for $599 shipped.
Link to product:
http://www.crracing.com/cr-racing-makes-lsa-swaps-easy-69-camaros
Blevinator
03-04-2014, 01:02 PM
Firewall almost done. A little more body work needed.
Aligning fenders, hood, header panel, cowl, etc after this.
After this, we will paint the underbody. Mechanics soon after!
https://static1.pt-content.com/images/pt/2014/03/smothfirewallnearcompletion_zps85eb7776-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/smothfirewallnearcompletion_zps85eb7776.jpg.html)
Blevinator
06-01-2014, 03:07 PM
Finally some progress!
Core support, firewall, cowl, dash have been painted PPG carbon Flash Metallic.
Lizardskin on underside painted satin black (John Deere Blitz Black)
Next is electrical.mechanics soon after. Things will definitely pick up now!
https://static1.pt-content.com/images/pt/2014/06/Firewallpainted_zps0e76894f-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/Firewallpainted_zps0e76894f.jpg.html)
https://static1.pt-content.com/images/pt/2014/06/Firewallcloseup_zps8acc40c6-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/Firewallcloseup_zps8acc40c6.jpg.html)
https://static1.pt-content.com/images/pt/2014/06/Coresupportpainted_zps37d7fd7a-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/Coresupportpainted_zps37d7fd7a.jpg.html)
https://static1.pt-content.com/images/pt/2014/06/dashpanelpainted_zps2a610d49-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/dashpanelpainted_zps2a610d49.jpg.html)
https://static1.pt-content.com/images/pt/2014/06/cowlpainted_zpsbf845cf3-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/cowlpainted_zpsbf845cf3.jpg.html)
https://static1.pt-content.com/images/pt/2014/06/firewallpainted2_zpsc7010ff7-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/firewallpainted2_zpsc7010ff7.jpg.html)
Blevinator
08-30-2014, 08:34 PM
Electrical started!!
https://static1.pt-content.com/images/pt/2014/08/imagejpeg_4_zpse327c21e-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/imagejpeg_4_zpse327c21e.jpg.html)
https://static1.pt-content.com/images/pt/2014/08/imagejpeg_7_zps83864157-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/imagejpeg_7_zps83864157.jpg.html)
https://static1.pt-content.com/images/pt/2014/08/imagejpeg_2_zps37b5d793-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/imagejpeg_2_zps37b5d793.jpg.html)
https://static1.pt-content.com/images/pt/2014/08/imagejpeg_3_zps4c30437f-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/imagejpeg_3_zps4c30437f.jpg.html)
https://static1.pt-content.com/images/pt/2014/08/imagejpeg_9_zps69308f42-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/imagejpeg_9_zps69308f42.jpg.html)
Vintage Air Box set
https://static1.pt-content.com/images/pt/2014/08/imagejpeg_8_zps2b32aabf-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/1968%20Camaro/imagejpeg_8_zps2b32aabf.jpg.html)
Bonehead
08-30-2014, 10:28 PM
C&R is one of those little known gems. They do all of the cup cars. They don't use epoxy or cheap cores. I've been a fan for awhile now. Getting ready to order their LS swap radiator for my El Camino project. Will never run another brand. Eager to hear how you enjoy yours!
srengr
08-31-2014, 10:21 AM
New wheels
I am working on a '68 very similar to yours. Would you mind sharing what size wheels and tires you ended up using, and what back spacing you specified?
Thanks.
Blevinator
08-31-2014, 07:47 PM
Thanks.
Wheels
Front 18x9 5.5" bs
Rear 18x12 5.5" bs
Will have rear end cut to center tires in rear wheel wells
Tires
Toyo R888
Front 275 (may go narrower if they rub. Using Ride Tech Tru Turn)
Rear 335 (car has DSE mini tubs with coilovers)
Blevinator
09-03-2014, 07:44 PM
Went to drop off some loom for my wiring today (replacing all plastic loom with fiberglass\fabric loom)
My car is sitting next to the Spurs 1969 Camaro.
I was talking to the electrician working on my car, telling him what all mods, etc I am doing to my car.
He remarked by saying "It will never be what the Spurs Camaro is"
I asked why wouldnt it be? He said that the Spurs Camaro was "built for the Spurs"
I asked him what the Spurs Camaro would sell for. He said they probably have 200k in it and
went on to say that I could never afford it, and to not make him laugh.
WOW!
I only have 100k cash in my car so far, so he must be right.
I am in sales and have rarely, if ever, had someone say something so out of place to a customer.
Hes very good at what he does, just set me back a little with his words.
Decline
09-06-2014, 09:29 AM
So I had to Google what the "spurs Camaro" was after reading this.
Meh... Besides the ZL1, it just looks like a dated overhaulin' wanna be.
This is exactly why I have a picture of my '95 integra from high school on my fridge. With its huge spoiler/body kit and clear tail lights, it was the hottest ride in the parking lot..now it just looks silly(although I maintain to this day that my rare JDM Mugen spoiler was the ****)
Keep it clean people
Blevinator
09-06-2014, 01:18 PM
Heres an issue I really need input on.
Using an American Autowire harness
My electrician is telling me I will see an 8 inch run of wire from the factory pre cut hole for the fusebox to the back of the motor
Cant the fusebox be relocated to the other side of the trans tunnel??
Any other ideas?
Any help here is much appreciated!
Update: Ended up spacing the fusebox off the firewall and running the wires
through the passenger compartment. My idea!
Blevinator
02-22-2015, 10:24 PM
Still moving along!
https://static1.pt-content.com/images/pt/2015/02/photo2011_zpszwz3lvaf-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/photo%2011_zpszwz3lvaf.jpg.html)
https://static1.pt-content.com/images/pt/2015/02/photo2017_zpsu9ovgzpd-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/photo%2017_zpsu9ovgzpd.jpg.html)
https://static1.pt-content.com/images/pt/2015/02/photo2014_zpsrrnsqhx0-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/photo%2014_zpsrrnsqhx0.jpg.html)
https://static1.pt-content.com/images/pt/2015/02/photo2024_zpsn17ykaie-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/photo%2024_zpsn17ykaie.jpg.html)
https://static1.pt-content.com/images/pt/2015/02/photo2015_zpsalldglek-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/photo%2015_zpsalldglek.jpg.html)
https://static1.pt-content.com/images/pt/2015/02/photo2012_zpsgsqkidzv-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/photo%2012_zpsgsqkidzv.jpg.html)
https://static1.pt-content.com/images/pt/2015/02/photo2013_zpsi6bnovtb-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/photo%2013_zpsi6bnovtb.jpg.html)
https://static1.pt-content.com/images/pt/2015/02/photo2022_zpscrznitok-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/photo%2022_zpscrznitok.jpg.html)
https://static1.pt-content.com/images/pt/2015/02/photo2021_zpst0xpm09h-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/photo%2021_zpst0xpm09h.jpg.html)
https://static1.pt-content.com/images/pt/2015/02/photo2023_zpsbjrxrpo2-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/photo%2023_zpsbjrxrpo2.jpg.html)
https://static1.pt-content.com/images/pt/2015/02/photo2019_zps55dibqqz-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/photo%2019_zps55dibqqz.jpg.html)
In cowl wiper motor
https://static1.pt-content.com/images/pt/2015/02/photo2025_zpst37arfjl-1.jpg (http://s475.photobucket.com/user/Blevinator_2008/media/photo%2025_zpst37arfjl.jpg.html)
Justin@EntropyRad
02-27-2015, 02:01 PM
Moar!!
Blevinator
03-01-2015, 02:50 PM
Moar!!
There will be much more soon!
Going into mechanics after a few weeks!
Fun will really begin.
I have the entropy LS swap radiator with the Entropy direct LS fan control harness.
Believe me, next few months, this beast will look totally different!
1nastyZ06
04-09-2015, 10:20 PM
Coming along nice. Can't wait to see more updates.
Blevinator
04-10-2015, 02:44 PM
Thank you!
Very near mechanics now.
Added harness for my TCI paddle shifter.
Skipping Boost a pump and Tanks Inc fuel tank (with Walbro 450)
Going with a Rock Valley stainless steel tank with Dual Aeromotive 340lph E85 pumps.
Blevinator
07-25-2015, 09:29 AM
Thank you!
Rock Valley Tank with twin Aeromotive 340lph pumps
This is the Aeromotive Phantom setup in an E85 tested pump vs standard pump
Tank has a really nice baffle provided by Aeromotive to prevent starvation.
Before anyone comments, baffle has been tested for a long while and doesnt degrade with E85 (I confirmed with Brett at Aeromotive)
I am thinking I will do a full polish on the tank.
115449115450
Blevinator
08-02-2015, 08:15 PM
115708
Mounted the gas pedal
CTS-V pedal
Ironworks Speed and Kustom bracket (powdercoated)
icemanrd19
08-02-2015, 08:54 PM
how do you like the bracket and position? Doesn't look little high?
Blevinator
08-02-2015, 09:16 PM
My installer said it looks like the pedal sits too far inward
Wont know until brake pedal is mounted, which will be soon
We will shorten the distance if necessary
Would think Ironworks would know
Zappa
08-04-2015, 01:45 AM
Just read all 7 pages of this thread :) Very nice build! I will be watching this one as it progresses!
P.S; I know its over a year old but I would say there was a solid bit of jealousy behind the comments from your auto sparky re; Spurs....yes its a nice build and I have a soft spot for the RamJet as I am also running one but that not the point, its certainly not a flawless car and at the end of the day you build a car for yourself, how you want, not to try and be like someone else....amazing he would dare speak like to a client!
Keep up the good work! :twothumbs
Blevinator
08-04-2015, 11:09 AM
I am building this car to be one of
the coolest 68's out there.
Update:
My auto electrician had been in the industry for over 30 years
He said my car has more "gadgets" than any car he has worked on.
Guess he changed his mind.
bwarren
08-04-2015, 05:58 PM
Thank God! What was he thinking? Maybe he recognized he hurt your feelings and felt bad, or . . . someone reminded him that you (indirectly) sign his check. Sucks when you realize there's ALWAYS a bigger boat in the marina. Think you said you were in sales? What do you sell (just curious)?
Blevinator
08-19-2015, 12:59 PM
I am in new home sales
Blevinator
08-19-2015, 01:01 PM
116330
Kilduff shifter arrived
Blevinator
08-29-2015, 11:59 AM
Placed the new brake pedal in place.
Location of the pedal is perfect.
Thanks Ironworks!
icemanrd19
08-29-2015, 12:07 PM
I used the DSE bracket but our pedal doesn't work work the bracket so i just drilled 3 more holes and made it fit. I wonder if DSE would like to use my bracket so they can modify their existing ones?
Blevinator
10-15-2015, 07:45 AM
118392118393
Flipped the sway bar over. LOL
Powdercoated the Ride Tech spindles.
Should have came this way. Rusted up quickly.
Electrician installing new tilt column and paddle shifter controls.
Will have performance and race mode switches under dash.
Engine and trans are next!
sebtarta
10-15-2015, 11:02 AM
Blev, nice progress. Just want to let you know your old LS3 intake is being used on the Nova and works perfect!
Blevinator
10-17-2015, 01:09 PM
Awesome!
This is my third LS3 LOL
Hope someone chimes in with the install of the other two motors.
Blevinator
10-17-2015, 01:12 PM
118473
118474
Put steering back together
Replaced many bolts with a stainless version (same strength \ hardness)
Really doing this car right
Installing new Flaming River column, paddle shifter, and Momo wheel in a few days.
wfo guy
10-17-2015, 02:53 PM
I just read all 7 pages. I appreciate you're going for a high end build, but the John Deere black you used is old style enamel unless the formula has been changed. There is more durable coatings available. If it's been changed , I apologize for mentioning it. I'm in agreement with your statement about not wanting it to drive old. I have old and new. My 32 is old and my 51 is new. :)
Blevinator
10-24-2015, 01:43 PM
If high end is determined by cost of parts, I am over 100k so would be considered a high end build.
John Deere Blitz Black was purchased as a recommendation by many hotrodders as a fade (has a great UV blocker)
and chip resistant, durable coating
Read here:
blitzblack.com
Heres a 29 page blog on Blitz Black
http://www.hotrodders.com/forum/john-deere-blitz-black-31993-29.html
Quote from page 8 of the blog:
motoedge's Avatar
motoedge motoedge is offline
Member
Wiki Edits: 0
motoedge's Photo Album
Seasonal JDBB??
Seasonal JDBB??
OK? Ya wanna explain this seasonal thing?
So... In the summer its ok to drive your car but in the winter your screwed because the paint is seasonal?
Really, who said this? Why would they think its seasonal?
JDBB held up in the "the weather room" where the worst type of hell was unleashed upon it. From acid rain to salts. Paints from A to Z were compared to BB, and BB came out on top. It wasn’t formulated for bling bling it was made for hard core industrial applications.
So for the price, formula, durability, ease of spray, JDBB is the best bet. We will NOT be able to out use it. We will be dirt nappin long before BB will fail.
Cool?
It is a good paint. My frame has been transported, installed, and uninstalled.
No chips, etc on the frame. Still looks the same as when I first painted it.
I used it on the frame and undercoating only.
Rest of all metal parts are powdercoated satin black.
I primed it using John Deere primer and thinned it accordingly
Had it sprayed by a body shop
Couldnt powdercoat the frame as I will be welding the subframe connectors which will burn the powder.
Blevinator
11-14-2015, 03:56 PM
119582
New column installed.
Ordered the Flaming River powdercoated 6 hole
steering wheel adapter to blend with the column and wheel.
119583
120321
Steering wheel installed
If you look closely, you can see the + symbol on the paddle shifter
armourmark
11-16-2015, 03:00 PM
I've used blitz black on projects before with no issues whatsoever. Held up as good or better than dp90 with clear on frame and suspension parts.
Blevinator
11-16-2015, 03:19 PM
Thanks for your input!
I think its all in the prep
Have to use the reducer etc.
Blevinator
12-15-2015, 09:38 PM
Great!
Thank for the input.
Installed the master cylinder and dual diaphragm booster.
Used the DSE brake booster bracket to level things out.
Just dropped off a ton of parts
Motor, trans, brakes, shifter etc
Will get interesting soon!
121017
Blevinator
01-07-2016, 02:48 PM
121879
Proportioning valve installed
121880
Brake lines started
121881
6 piston calipers installed
Blevinator
05-12-2016, 12:12 PM
127045
127044
127046
Fitting center console
Have a finish plate that goes over the shifter area
Motown 454
05-12-2016, 02:08 PM
It's going to be sweet! I like the console.
Whooppass
05-12-2016, 07:12 PM
The detail on that console is awesome, will it be leather wrapped? What wilwoods did you go with front/back, and i might have missed it but have you decided on wheels yet?
Blevinator
05-28-2016, 02:15 PM
Sorry for the late reply.
Somehow the thread settings were changed and didn't see this until today.
Console, dash panel, a\c panel and door panels will be leather wrapped and double stitched.
I also have a trim plate that fits over the slot in the shift plate, so will look good.
Wilwoods are 6 piston front, 4 piston rear. Think they are Dynalites.
Wheels are Rushforth Nightrain.
Posted a photo earlier in the thread.
Thank you for the compliment on the console!
Blevinator
05-28-2016, 02:17 PM
It's gooing to be sweet! I like the console.
Thank you!
Got one of the last interior kits built by modern classics interiors.
Console will butt up to rear seat
Blevinator
01-09-2023, 07:23 PM
Looks like I may part out car
67birdak
02-13-2023, 01:06 AM
Hey there,
I’d like to buy your trunk lid and spoiler from the classifieds section, but my account doesn’t have high enough credentials to reply to the post or send a DM. Could you send me a DM instead?
Thanks!
Motown 454
02-15-2023, 09:18 AM
Sorry to hear that.
