View Full Version : Had to get these two together tonight...
rockdogz
08-31-2004, 09:07 PM
Introducing the new front subframe and body...
I think they'll make a good couple... don't you??
No, they're not really attached - trying to figure out where to cut the tunnel for the shifter :candle:
08-31-2004, 10:12 PM
Looking good Tom, are you running a vintage air or no air? Shifter hole...thats easy start with a 1/8" hole then keep going up untill you get it lined up...then just weld up the misses...j/k thanks for the pictures
rockdogz
09-01-2004, 07:27 AM
Thanks Vince, running the Vintage Air unit - got the kit from DSE. Probably a good time to install the bulkhead fitting - before the front subframe is attached...
