View Full Version : 69 camaro rear suspension
jigga99
06-29-2005, 03:47 PM
i have a 69 camaro, and would like to keep the rear from hopping and keep it bolted to the ground, whats a good setup?
CAMAROBOY69
06-30-2005, 03:58 AM
I will list a couple questions so the suspension experts in here can help you out.
What suspension do you currently have?
What shocks?
What rear bushings?
How Many leaf springs if you leaf spring rear end?
What tires size do you have?
What type of rear end? Posi, spool, limited slip?
What gears?
Do you want a whole new rear set up or just something to get rid of your wheel hop?
The more info you give the easier it is for us to help you out. :)
Now I will let the professionals take over from here.
jigga99
06-30-2005, 10:36 AM
leafs, 3 i think, stock bushings, tires 275/45/17, 10 bolt want posi and 373 gears. i guess what im looking for is to keep the rear from moving at all, somthing like panhard bar kit, im going to lower it so i dont want anything that hangs and looks funny like slapper bars.
6'9"Witha69
06-30-2005, 03:24 PM
I have 0 wheel hop with Hotchkis dropped multi leafs and Comp Engineering slide-A-Links with Bilstein shocks. The slide a links are visible. I am with you, I don't like anything that hangs and dirtys up the lines of the car. I didn't have any issues w/ wheel hop when it was just the Hotchkis springs and Bilsteins. Is the motor dyno'd? What is the hp/tq?
jigga99
07-02-2005, 09:14 AM
thanks for the reply, ya it dynoed at 408hp 433torq
