View Full Version : Headlight Switch 70 Camaro
DButler
10-03-2011, 04:07 AM
Ok so I am working on a 70 camaro with new wiring harness. I have to wire new headlight switch connector plug. I would go off the old one but I don't have it. Does anyone have a diagram for what wires will wire to the plug? I found 2 blue wires which one id the headlight switch and the other is the dimmer wire. I also see a grey wire that says dash lights will this need to wire to the headlight switch to make my Covans dash kit light up?
esenior
10-04-2011, 09:22 AM
David, pretty sure that the 70 switch is the same as the 69. If so, then this diagram from my AAW manual may help you out...
https://static1.pt-content.com/images/pt/2011/10/GM_Headlight_Switch-1.jpg
DButler
10-04-2011, 09:29 AM
Ok thanks alot. Where does your dimmer switch wire go here?
esenior
10-04-2011, 12:14 PM
The Headlight feed runs to the dimmer switch. The dimmer switch has two wires that run from it to your low and hi beams.
Below is a Camaro wiring diagram that may help (Click for larger). The dimmer switch is at the top, left of middle (BEAM SELECTOR SWITCH).
https://static1.pt-content.com/images/pt/2011/10/69CamaroWiringDiagramFull_SM-1.jpg (http://www.the-seniors.net/img/forum/69CamaroWiringDiagramFull.jpg)
DButler
10-06-2011, 06:11 PM
Ok so i wired the tailights were they go and also the dash lights. i have a brown wire that goes out to the headlights that say low beam. It runs into the column to the dimmer switch along with e dimmer switch wire and a few other green wires. I have a blue wire that says headlight power so I ran it to were the headlights go on the connector and then I ran a constant hot to the 12 volt battery place on the connector. I havent hooked up dome lights or parking light but I turned on switch and NO lights. Do these have to be hooked up for the headlights and tailights to work. Should I hook the brown low beam wire where the connector says headlights and the headlight power to the 12 volt on the connector where I ran a constant hot? I am thinking I have the headlight part hooked up wrong.
