View Full Version : Accel DFI Gen 7 Fuel injection EFI + MSD HVC + Dual sync distributor
joeelutz
09-27-2011, 03:00 PM
This ad is for the following
Accel DFI Gen VII programable EFI system
CalMap GEN VII v 4.0.1 software
CalMap programing cable
Both PRO key dongle (USB) that unlocks all software features and Sportsman key (Serial) for limited features
Accel Dual Sync distributor that allows for true sequential fuel injection
MSD HVC ignition box and high vibration coil.
Wiring harness
Custom mounting panel that holds the computer, ign box, relays, and fuses. This panel is designed to bolt in a 67-68 Camaro glovebox opening for easy access, but could be modified to fit pretty much anywhere.
This is a very powerful system with many features such as boost control, launch control, staged nitrous control, tuneable sequential injection, and much more. It can be used in conjunction with most wide band O2 sensor systems for closed loop operation at all loads and speeds. It worked excellent. I was very pleased with all the tuneability, features, and performance. The only reason I am selling it is I have switched to an LS based engine that came with it's own stand alone EFI computer and harness.
This system was used on a 67 Camaro with a built small block and a Weiand Stealth Ram port injected intake and Vortec style heads. The complete intake, injectors, throttle body, etc is available seperate. In fact the entire engine is available if interested and is pictured for reference.
$1800
Joe (828)381-0391
https://static1.pt-content.com/images/pt/2011/09/resized_DSCN2085JPGpsid1-1.jpg?psid=1
https://static1.pt-content.com/images/pt/2011/09/IM00203820Medium-1.jpg?psid=1
https://static1.pt-content.com/images/pt/2011/09/resized_DSCN2091JPGpsid1-1.jpg?psid=1
https://static1.pt-content.com/images/pt/2011/09/DSC0483420MediumJPGpsid1-1.jpg?psid=1
joeelutz
10-01-2011, 05:31 PM
Reduced price $1800.
joeelutz
10-03-2011, 04:02 PM
Price reduced again $1600
joeelutz
10-06-2011, 03:37 PM
$1500 takes it.
joeelutz
11-05-2011, 05:49 PM
Still for sale.
Offers?
joeelutz
11-14-2011, 03:55 PM
$1200
joeelutz
11-19-2011, 06:24 PM
Sold the ECM and harness. I still have the MSD HVC box and coil and also the dual sync distributor.
