View Full Version : Building the Great One – 1964 Pontiac GTO
cspecken
09-15-2011, 10:40 PM
I originally purchased my 1964 Pontiac GTO in 1989, during my high school senior year. The car was picked up in Jamestown California, a small mining town in the Mother Lode of California. For $1000 I bought the car with an engine, Muncie 4 speed transmission and enough extra parts to fill the back of a pickup bed. After a quick call over to the Pontiac Historical Society, I received information back on the car which verified that it was in fact a true 1964 GTO. As summer progressed so did the dismantling of the car.
49303493044930549306493074930949308
Things were starting to progress. The motor was sent off to Vic Hubbard’s in Hayward, CA to rebuild, but they determined that the engine was shot. Two blocks later I finally got an engine back. During that time I had the Muncie 4 speed rebuilt and dropped in a posi rear. The entire stock suspension was rebuilt and put back into place. The body was then set on the updated frame. Then life took its natural course, education, family, work, etc… The car was parked in the back corner of the shop and wasn’t touched for years.
Then one day I came across this site and determined that it’s time for me to pull out the GTO and finish it. I have once again disassembled the entire car!
4931449310493134931149312
So far all of my suspension components have been purchased!
Suspension Shopping List
Spindles – ATS from Speed Tech
Upper and Lower Control Arms – SPC
Front and Rear Springs - SPC
Front and Rear Sway Bar – Hellwig
Front and Rear Shocks – Varishock
Steering Unit - Lee
Steering Column – Ididit
Steering components - Borgeson
Rear End – Currie Ultimate 9 – 370 gears – 1” shorter on each side
Next on the project list is to get the factory frame welds stitched up a bit. The factory welds were horrible! Then off to the powder coater for a little color and onto the suspension assembly. Hope to have a roller by the end of the month.
Any ideas, suggestions, help is always greatly appreciated. Oh and any parts, supplies, materials, etc donated by sponsors or others will be gladly accepted!
More photos of the build can be found here: http://s1232.photobucket.com/albums/ff376/mrgto1964/1964%20GTO/
LeighP
09-16-2011, 02:14 AM
Hi,
Great project...I love Pontiacs. A post GTO is fairly rare...most of the ones you see around are hardtops....I personally like the post coupe body....its supposed to be a bit lighter, but mainly they are stiffer than the hardtops.
Good luck on the project.
Smock67
09-16-2011, 05:38 AM
Goat looks solid, and a nice list of upcoming mods for sure.
cspecken
09-18-2011, 06:57 PM
Here are a few pictures of the factory welds cleaned up and restitched, sandblasted and back from getting powder coated.
https://static1.pt-content.com/images/pt/2011/09/DSC06539-1.jpg
https://static1.pt-content.com/images/pt/2011/09/DSC06543-1.jpg
https://static1.pt-content.com/images/pt/2011/09/DSC06555-1.jpg
https://static1.pt-content.com/images/pt/2011/09/DSC06558-1.jpg
Next up get the upper bushing pressed back into the rear end. I had to remove them for powder coating. After that I will install the rear end, with the upper and lower control arms.
19 usac
09-19-2011, 02:15 PM
I am also buliding a 64 post. Also in the valley where are you located?. Jim
cspecken
09-19-2011, 04:47 PM
Hi Jim, I am just south of you in Turlock
cspecken
09-23-2011, 09:15 PM
Here is the new rear axle ready for brakes and installation.
Details: Currie Track 9, 3.70 gears, 31 Spline, TruTrac posi, narrowed 1" on each side, screw in 12.5 mm studs, LPW aluminum rear cover
https://static1.pt-content.com/images/pt/2011/09/DSC06591-1.jpg
https://static1.pt-content.com/images/pt/2011/09/DSC06592-1.jpg
https://static1.pt-content.com/images/pt/2011/09/DSC06593-1.jpg
LeighP
09-24-2011, 04:58 AM
Interesting set up...haven't seen a 9" with a bearing support cover before...though I suppose it makes sense. Nice one!
cspecken
10-27-2011, 06:01 PM
Quick update --- Finally got around to install the rear end, upper and lower rear control arms and new springs under the frame. Next up rear shocks and sway bar. Then I will move to the front to tackle the suspension.
https://static1.pt-content.com/images/pt/2011/10/d6374b0d-1.jpg
https://static1.pt-content.com/images/pt/2011/10/ac66f7df-1.jpg
SRD art
10-27-2011, 09:59 PM
Looking good and purdy Chris! Keep it going!! :cool:
CruizinKev
10-28-2011, 02:12 AM
now bolting on all the new parts on a fresh repainted frame starts the real fun! :twothumbs
cspecken
10-28-2011, 01:51 PM
The front end should be fun. I am still trying to figure out how to put it together without dropping body and the old engine back onto the frame for weight. It sounds like from other members experience with similar suspension components, it is a challenge to get everything bolted up together.
dhutton
10-28-2011, 04:09 PM
I have the same front suspension on my 64 GTO and I did not have much trouble bolting it together on the bare frame.
Don
T_Raven
10-28-2011, 04:10 PM
Very nice, I like those control arms. I hope to build an A body Pontiac after I get through all my Firebirds lol
cspecken
10-28-2011, 04:45 PM
Don
Hi Don, how did you compress the springs without using the weight of the motor?
dhutton
10-28-2011, 04:51 PM
Hi Chris. My recollection is that I was able to compress them by hand. It depends on how many spacers you are trying to install. I have an LS motor so you might need more spacers than I used. Have you tried to assemble it yet?
cspecken
10-28-2011, 04:58 PM
I am planning on using an LS3 engine. After reading thru several other A Body installations of similar suspension I was going to go with an aluminum spacer and two shims. I will try mocking up the suspension and see how well it is going to go together.
dhutton
10-28-2011, 05:01 PM
That's what I used too.
analyte
10-28-2011, 08:34 PM
Very nice build. I've made very similar suspension choices on my Chevelle.
Kerry
cspecken
11-27-2011, 09:44 PM
Here is the latest update, I was able to finally get the rear end together. I bolted up the Hellwig Adjustable pro-touring sway bar. I was not overly impressed with the quality of the mounting hardware. I am not sure if they are powder coated or not, but appears to be a very rough finish . If you are planning on using a Currie Enterprise 9 inch rear end, you will need to acquire larger (wider and longer) u bolts to mate the brackets up to the rear end. In order for this sway bar to work correctly in my application I had to move the bracket inward onto the center house of the rear end. In the pictures you will notice that the bar is somewhat closer to the housing on the passenger side. The brackets have been tighten down to where the bar will not move (I guess the bar should not be able to move?). Also, I am not sure if there is a way to even out the gap on both side, if anyone has input on this please let me know how to fix this problem.
https://static1.pt-content.com/images/pt/2011/11/bcf2e50a-1.jpg
https://static1.pt-content.com/images/pt/2011/11/0578ce5b-1.jpg
https://static1.pt-content.com/images/pt/2011/11/db205cda-1.jpg
https://static1.pt-content.com/images/pt/2011/11/0735df38-1.jpg
https://static1.pt-content.com/images/pt/2011/11/4265a874-1.jpg
Installed Lee 670 Power Steering unit.
https://static1.pt-content.com/images/pt/2011/11/8e6bc54d-1.jpg
If you are looking for GM replacement mounting hardware I used http://inlinetube.com/. I purchased the power steering unit bolts, front and rear upper and lower controls bolts, and the front shock retainers from them.
cspecken
11-27-2011, 09:49 PM
I noticed that the logo on the upper control arm sleeves have SPC in the same direction on the driver side, and are pointing opposite each other on the passenger side, is there a reason for this? Also is there a way to fix this? See pictures below
Passenger Side
https://static1.pt-content.com/images/pt/2011/11/daed0eac-1.jpg
Driver Side
https://static1.pt-content.com/images/pt/2011/11/fc6f6e3f-1.jpg
gearbanger
11-28-2011, 01:10 PM
No problem with the logos, but the arms need to be installed on the car with the bolted joint to the rear of the ball joint.
cspecken
11-30-2011, 08:31 AM
Great I will swap those around. Spoke with Mark at SC&C sounds like he was not surprised that the logo's on the adjustment sleeve don't match up on both sides.
John Wright
11-30-2011, 08:46 AM
the logo's on the adjustment sleeve don't match up on both sides.a little glossy black paint will take care of that. A couple Sppfffts, Spfffts from the can = logos now all match.....LOL
CFster
11-30-2011, 10:19 AM
Chris,
My rear Hellwig bar is offset as well.
-Colin
cspecken
11-30-2011, 07:31 PM
Chris,
-Colin
Good to know thanks Colin.
Dave@Hellwig
12-09-2011, 05:54 AM
cspecken - The center hump of the sway bar should be tilted down so that it is even with the bottom of the center section of the differential. If you are still having issues with fit give me a call at 559-734-7451 and so that we can resolve your fit issues.
John Wright
12-09-2011, 06:54 AM
Without the weight of the motor sitting on the frame rails, it seems this was an easy solution to get the front springs in.
See what you think: http://transamcountry.com/community/index.php?topic=4042.msg40322#msg40322
cspecken
12-09-2011, 08:20 AM
Unfortunately, the Varishock will not go up thru the bottom of the lower control arm due to their size and the opening on the SPC lower control arms. I will have to mount the shock first, then place the coil on the lower control arm before I can start to compress the coil.
John Wright
12-09-2011, 08:54 AM
Unfortunately, the Varishock will not go up thru the bottom of the lower control arm due to their size and the opening on the SPC lower control arms. I will have to mount the shock first, then place the coil on the lower control arm before I can start to compress the coil.Ah, that stinks...can't use the shock mounting hole in your case. Be careful with those compressors...they scare the bageebeez out of me...lot's of stored energy just waiting for a chance to get loose.
CFster
12-09-2011, 09:03 AM
Yeah unfortunately the Varishocks don't have the extended length of OEM style shocks so that means you'll have to compress the spring that much more to get the shock bolted. Kind of a pain - but we did it with a complete car so it was just a matter of using a floor jack. Good luck.
cspecken
12-09-2011, 11:14 AM
Hi Dave, it looks like I will need to take the rear bar off an flip it over. Currently, I have the bar titled up. I don't recall seeing anything in the instructions that talked about the tilt of the bar, and the pictures were some what difficult to determine the positioning. I spoke to you a few weeks back regarding getting larger ubolts to mount the bar, so those did work out.
Thanks, Chris
Dave@Hellwig
12-09-2011, 01:59 PM
If you still have clearance issues contact me a 559-734-7451 x36.
cspecken
12-09-2011, 02:57 PM
I am planning on going with Baer Brakes. The front will be their Pro Plus 14" rotors (4301352) and on the rear the SS4 Plus 13" rotor (4262263c). Now my dilemma is choosing the caliper color. Below is a picture of the color my car will be. The choices are Red w/ Black Script, Black w/ Red Script, Silver w/ Red Script.
52320
Let me know what you think.
cspecken
12-10-2011, 03:32 PM
Hi Dave, I flipped over the rear sway bar. Now it has more clearance but definitely sits about the bars thickness below the rear axle housing. Notice where I put the clamps for the rear bar. I have to mount them more inboard on the center section housing and not the axle tubes so it will bite down and clamp to the housing. I would think the bar in this position may present a problem with the ride height of the vehicle.
Chris
https://static1.pt-content.com/images/pt/2011/12/bd41132d-1.jpg
cspecken
12-10-2011, 03:37 PM
Today was a great day, I successfully bolted up the passenger side SPC A Arms and the Speedtech AFX Spindles. It went together rather easy. Much easier than I had originally expected after reading several posts regard the difficulty some other members had. Tomorrow I will bolt up the driver side, then Monday order some brakes and get ready to purchase the engine and transmission.
https://static1.pt-content.com/images/pt/2011/12/a5c989ee-1.jpg
https://static1.pt-content.com/images/pt/2011/12/836bd1e7-1.jpg
real57vetteguy
12-11-2011, 07:12 AM
Looking great
therobski
12-11-2011, 08:39 AM
Couple of us on here went the Oldsmobile way, but very similar builds. Mine is the 64 F-85 post. Lets getter done!
Dave@Hellwig
12-12-2011, 04:27 AM
cspecken- Once you put the body on the frame the suspension will compress and the bar will rotate upward. It should be even with the bottom of your center section. You can adjust the length of the end links for final adjustment.
cspecken
12-13-2011, 02:56 PM
Thanks for the info Dave. Hopefully I will have the body on the frame by the end of this year!
cspecken
12-19-2011, 03:00 PM
Finally got the front end bolted all up, and now the chassis is down on all fours!!!! Started with the installation of the Hellwig front sway bar, but noticed that the holes in the frame where not that snug with the 5/16 bolts I had, waiting to here back from the Pontiac board on the correct size. Notice how I flipped around the rally wheels! Also, ordered my brakes Baer Pro Plus up front with Baer SS4 Plus in the rear.
https://static1.pt-content.com/images/pt/2011/12/2b10c38d-1.jpg
https://static1.pt-content.com/images/pt/2011/12/443e6a1e-1.jpg
cspecken
05-10-2012, 11:52 AM
Currently mocking up the car for the body work. Also, in the process of getting the firewall smooth out, to cover up some holes for the Vintage Air setup, and new American Autowire kit. Decided to go done the body work first since the majority of the other items (Engine and Trans) will be fairly straight forward. I would rather not use up my new engine warranty, while the car is locked up in paint jail!!!
For those running Vintage Air, should I have any mounts welded on the inside of the firewall to hold the system up?
https://static1.pt-content.com/images/pt/2012/05/6277f2f1-1.jpg
https://static1.pt-content.com/images/pt/2012/05/5d7f73ba-1.jpg
https://static1.pt-content.com/images/pt/2012/05/111a4a5d-1.jpg
rohrt
05-10-2012, 12:56 PM
The Frame is awsome! I really like the 670 box.
TEMP GTO
05-10-2012, 01:12 PM
Chris,
Nice ride. I am actually working on a 65 tempest that I bought from Cali back in October. Your frame looks sweet. I hope to get mine to that stage here shortly. Good luck with your build.
59292
therobski
Sweet very similar to my 64 F-85 Post car build
cspecken
10-06-2012, 01:04 PM
Quick update, sent the car out to have the firewall done correctly and the body work started. They started the work with removing old firewall that was previously added, hund the A/C unit, and created a new clutch/pedal box that is for the new Wilwood setup I recently purchased. I will update as the project progresses. Here are a few pictures.
https://static1.pt-content.com/images/pt/2012/10/4C64680F8DDE4C70AB8E964487B075AE27827000-1.jpg
https://static1.pt-content.com/images/pt/2012/10/13070403C4DD4E2E83F70942AA4FFABD27827000-1.jpg
https://static1.pt-content.com/images/pt/2012/10/2352CE3ABF354BC8B743136FFF0C411A27827000-1.jpg
https://static1.pt-content.com/images/pt/2012/10/3D55FE84DCCA4796A475F3D4509EC60027827000-1.jpg
New Clutch/Pedal Box Setup
https://static1.pt-content.com/images/pt/2012/10/437EB6AF9BCD41F98C637FF76B380C2327827000-1.jpg
https://static1.pt-content.com/images/pt/2012/10/92E01424D9DA49FBBD9DB7E560C00ABB27827000-1.jpg
coolwelder62
10-07-2012, 05:55 PM
Very Nice.I think the pedal setup is a good choice.
10-07-2012, 08:27 PM
Dominator will do you right. Looks good so far.
Vince
cspecken
10-07-2012, 09:04 PM
Hi Vince, I took my car to three different shops to get estimates and look at what they had to offer. After a rather long day on the road, I decided Dominator was the choice. Unfortunately, I didn't make it over your direction. Dominator's close proximity (35 min) to my house was also factored into my overall decision. Everyone's estimates seemed very comparable. So far I am happy with the results.
therobski
10-08-2012, 01:43 PM
The Vintage AC looks great, I guess you fabbed up and welded some brackets to hold the unit in? I looking closely I'm assuming under the dash on my 64 F-85 is similar. Any extra detail would be appreciated.
cspecken
10-08-2012, 03:08 PM
I will try to get some more pictures later this week.
therobski
10-09-2012, 05:02 AM
Thanks Chris look forward to the pictures
cspecken
10-12-2012, 06:10 PM
Progress! I now have a firewall with pedals and Vintage Air unit installed. There will be a few more braces and brackets welded onto the inside of the firewall. In order for the fender to fit properly they stepped down the metal to allow the fender tab to fit nicely, look great. Next will be the mockup of the motor and transmission to modify the tunnel for proper fitment.
https://static1.pt-content.com/images/pt/2012/10/53E919AC8F154889A5A3B428C57056CE35236000-1.jpg
https://static1.pt-content.com/images/pt/2012/10/2DF12F1C3D7B4979BF3EFB1EAA2F2F5835236000-1.jpg
https://static1.pt-content.com/images/pt/2012/10/056C88DC8FD14654864541677BFD72FE35236000-1.jpg
https://static1.pt-content.com/images/pt/2012/10/CBFAE22F0CCB41ECB0559BD1E951445335236000-1.jpg
https://static1.pt-content.com/images/pt/2012/10/A84591CD1B704D13B2AEFCD469074DC035236000-1.jpg
https://static1.pt-content.com/images/pt/2012/10/1BB0F9A31EDC4D8C9D71C3D2FA2E21D835236000-1.jpg
https://static1.pt-content.com/images/pt/2012/10/AFB06FB1B23F47A69FDD8E4943FE6B9035236000-1.jpg
https://static1.pt-content.com/images/pt/2012/10/6C4A33A501194D1B88F1E0BA68F51C3D35236000-1.jpg
https://static1.pt-content.com/images/pt/2012/10/34D7ECBE6E474153909FC6C48C17ED3335236000-1.jpg
therobski
10-13-2012, 10:47 AM
The Vintage fitment looks great. I will use these ideas when I get to putting Vintage A/C in the F85. Thanks
ekmxryda
12-07-2012, 05:19 PM
Looking good, I will be following your build. Good choice on the pedals.
I am jealous of your rust free body, I will be doing major rust repair for a while since I am slow.
Had the same thought of engine warranty running out before I get a chance to drive it so I grabbed a junkyard LQ9 to do all of my dry fitting with.
cspecken
01-11-2013, 09:17 PM
Here are some pictures of the progress being made on the GTO engine and transmission mockup. Ran into a couple vendor related issues but finally got those worked out last month. Things appear to be progressing nicely. Trying to determine how low we can set the engine into the stock cross member. I am using 66-67 Chevy small block mounts bolted to Dirty Dingo adjustable LS brackets. I acquired a Champ Racing pan to allow for more clearance as well. All of this is bolted to the T56 via a Quicktime LS bell housing. You can see in the picture we have some room to work with. The engine may have to go in a little lower to get the drive line angle right.
https://static1.pt-content.com/images/pt/2013/01/ADB504432D5748C59EFD4DD756761DC326490000-1.jpg
https://static1.pt-content.com/images/pt/2013/01/49CDE2E622E94880A3FDD85CFC0AB97D26490000-1.jpg
https://static1.pt-content.com/images/pt/2013/01/66F3FFD6A97A495F988D982B2A51636B26490000-1.jpg
https://static1.pt-content.com/images/pt/2013/01/E7FDA31696DA4A838548E4E08578DB8826490000-1.jpg
https://static1.pt-content.com/images/pt/2013/01/F7AD9CA478724542AF0F8AD86BAFD8F026490000-1.jpg
https://static1.pt-content.com/images/pt/2013/01/326A686674D7458D9A6D8B42AF05286826490000-1.jpg
01-11-2013, 10:09 PM
looks good Chris, that quick time bell and champ pan opens up so much room.
Im getting ready to start a 67 and I think I may take that angle out of the firewall. So those are stock frame stands?
cspecken
01-11-2013, 10:24 PM
Thanks! There appears to be a lot of room which is nice. Yes, those are stock frame stand for a small block Chevy.
Todd in Vancouver
01-11-2013, 10:50 PM
Great build and I have a deep affection for the old GTOs as I use to "borrow" my dad's '65 389 tripower and go for a burn when he wasn't around. Although my current build will be my last car I might be swayed if I found a gem like yours. Subscribed and keep up the great work and the pictures coming.
67goatman455
01-12-2013, 06:36 AM
Lookin good! Love the pedal setup.
cspecken
03-15-2013, 07:15 PM
Quick update, new tunnel almost 100% complete. Had to make up a new cross member to support the T56 transmission. The shop threw in some exhaust ports to keep the pipes up off the ground! Waiting the arrival of the kooks stainless headers to make sure everything is going to work together nicely. Next up is the body.
https://static1.pt-content.com/images/pt/2013/03/E1CB5655C3D14F778AFDAF0D42282CFE75570000-1.jpg
https://static1.pt-content.com/images/pt/2013/03/5264B14A8F2D443DB46F34362A5182F775570000-1.jpg
https://static1.pt-content.com/images/pt/2013/03/723A0306CA864701BD4F21865A30266F75570000-1.jpg
https://static1.pt-content.com/images/pt/2013/03/8E0312B1AE5F4FF9AD83E0B673E9BB6E75570000-1.jpg
https://static1.pt-content.com/images/pt/2013/03/D7F64D4469F3469EAFE13E0D4DFA045375570000-1.jpg
https://static1.pt-content.com/images/pt/2013/03/EF3DAF231ECF43FD860C7D59BF71516375570000-1.jpg
cspecken
05-01-2013, 12:17 PM
Mounted up kooks headers. Appears to fit nicely, the lower A Arm mounting point will need a bit trimmed off. Body panel alignment and metal work have begun. The guys over at Dominator are working their way around the back half of the car. The passenger quarter was replaced at onetime, and the previous person did not do a good job. The top of the quarter panel was smashed flat, where the factory had a gentle roll. The metal magician's has to cut it out and repair the area! My car was made very early in the production year, and did not have a roof support running from the front of the car to the rear. They had to install one, to prevent the roof from sounding like a tin can and give it some rigidity.
https://static1.pt-content.com/images/pt/2013/05/F40D4F25797044DC985080D22EC43EA434432000-1.jpg
https://static1.pt-content.com/images/pt/2013/05/87F55657831040229B0C918D82D151BD34432000-1.jpg
https://static1.pt-content.com/images/pt/2013/05/F2E0EEFF03D64504AEF5C08D855571D634432000-1.jpg
https://static1.pt-content.com/images/pt/2013/05/photo12_zps4c1ce69a-1.jpg
https://static1.pt-content.com/images/pt/2013/05/photo22_zpsfe67554c-1.jpg
https://static1.pt-content.com/images/pt/2013/05/BE2FCCC10F214B75A588409D403368FE28927000-1.jpg
https://static1.pt-content.com/images/pt/2013/05/1B399A71D5D24BF8AF7818737813F41028927000-1.jpg
https://static1.pt-content.com/images/pt/2013/05/989AB2A84549428490A1FE771A5A912228927000-1.jpg
https://static1.pt-content.com/images/pt/2013/05/E2FB413A443F4A1388DB797BD8F0B84328927000-1.jpg
CruizinKev
05-01-2013, 08:50 PM
looking good!!
andrewb70
05-02-2013, 05:44 AM
Good progress.
keithq69
05-02-2013, 06:17 AM
Beautiful work so far.
Love the choice of body styles.
I have a 69 Camaro but I love to see cars like yours that don't get done very often.
The guy working on the sheet metal is amazing. Nice to see you can still find someone who takes pride in his work.
Looking forward to more updates.
Keith.
cspecken
08-17-2013, 09:48 AM
Here are some updated photos, the body work is under way. Should be laying down primer soon and will let it bake in the California sun for a couple of weeks.
https://static1.pt-content.com/images/pt/2013/08/39C9AE7E31094CF6A84D80534CEC972040932000-1.jpg
https://static1.pt-content.com/images/pt/2013/08/E8E9F1790E1F4FA1BA1AED39E586F9AA40932000-1.jpg
https://static1.pt-content.com/images/pt/2013/08/A27601F43F8D41C8B3FB3CE27B5B426840932000-1.jpg
https://static1.pt-content.com/images/pt/2013/08/B163D8BA91A8482DBB2365A37A477AA440932000-1.jpg
therobski
08-18-2013, 03:19 PM
Great job-as soon as saw where you fabbed/welded in a support in the roof, I went to the shop and looked at the F-85 and it has the support.
69*Goat
08-18-2013, 06:16 PM
Wow, another Goat. They're everywhere!!! Nice work so far!!!
cspecken
08-18-2013, 07:20 PM
My car is an early production build, I also have another 1964 GTO that has a support which runs the length of the roof (Front to Rear). I had the shop put the support in there to give it some rigidity. Made a big difference. Your car looks like it is turning out pretty nice.
Definitely a good representation and a nice change of pace.
67goatman455
08-18-2013, 08:19 PM
for sure! lookin real good!
cspecken
06-11-2014, 02:02 PM
Looks like it has been sometime since I updated this post. Car now has color on it (finally). Will still need to be cut and polished. It took a lot of work to get to this point. Awaiting the chrome / aluminum items to come back from Superior Chrome in San Jose. Next I have to determine, interior, finalize the engine selection, gather up all of the misc trinkets that will go on the car. Wheels & tires, exhaust, etc. On the fence about a 6 point roll bar. Still have a ways to go before it is on the road.
Engine Options
Crate LS3/430 - With aftermarket Cam
Crate LSA
Custom Built LS3 with forged goodies, custom heads, etc
Seating Options
Recaro front buckets
Sparco front buckets
Wheels
Forgeline
RAD
Rushforth
BOZE
Exhaust
Borla - Most likely
https://static1.pt-content.com/images/pt/2014/06/IMAG1895_zps1abd392e-1.jpg
https://static1.pt-content.com/images/pt/2014/06/IMAG1901_zpsad7d9b17-1.jpg
https://static1.pt-content.com/images/pt/2014/06/IMAG1900_zps77b8c4c6-1.jpg
CampbellshotrodsAZ
06-11-2014, 02:08 PM
Cool build, looking forward to seeing it done!
Nicks67GTO
06-12-2014, 01:15 AM
Keep the updates coming
cspecken
08-25-2014, 10:07 PM
Installing sound deadening material from Raam Audio http://www.raamaudio.com/. This is taking more time than expected but so far it appears that it is worth the effort. Chrome goodies are ready to be picked up, plan to pick them up within the next week. LS3 engine build is underway and should arrive in the next couple of weeks. After the motor arrives it is time to go on a shopping spree. Radiator (?), Clutch (McLeod RST Twin Disc), Hydralic Throw Out Bearing (?), Exhaust Borla XR1's, and Fuel Tank (Rick's).
102046
102047
102048
andrewb70
08-26-2014, 04:23 AM
Since the car is apart, I would go over that sound deadener with a sound blocker. The deadener only going to keep the metal from ringing, but it won't block much road noise. A blocker would consist of a layer of closed cell foam with a layer of mass loaded vinyl on top.
For hydraulics, I would go with a new f-body slave matched to a 3/4" MC.
cspecken
08-26-2014, 08:45 AM
Hi Andrew, I already have the sound blocker and will be the next item to install. I will take a look at the f-body slave, thanks for the suggestion.
Chris
therobski
08-26-2014, 05:55 PM
I am ready to put the Dynomat down on the floors, I also have a complete a new precut factory jute for my 64 F-85 that's sitting in a box, would that work?
cspecken
08-26-2014, 08:35 PM
The jute may help,but Andrew is referring to a compressed foam product. Take a look at the dynaliner from dynamat. There are several companies out there who have similar products.
cspecken
11-15-2014, 07:04 PM
Quick update Baer 6p's have been mounted, stainless lines have been run. Under dash wiring has been put into place and the Vintage Air unit has been installed. Quicktime bell housing is currently being indexed to engine. Should have the engine and transmission installed in the next week or two, then onto the exhaust.
105265105265105266105267
Motown 454
11-23-2014, 09:45 PM
I just went through your whole thread and enjoyed every minute of it.. Nice project and it looks great. I love seeing fab work like the rear quarter fix they did . It amazes me.
cspecken
10-20-2015, 08:15 PM
Quick update on the progress that has been made since the last post. The 600 hp Engine and T56 Magnum transmission are now in. Almost all of the wiring has been completed. The battery has been mocked up, with the CTEK charger. II MUCH fuel tank vent has been installed along with a rick's stainless steel tank. The Baer brakes are installed and plumed.
Still outstanding is the cold air intake and exhaust.
https://static1.pt-content.com/images/pt/2015/10/IMAG6946_zpsgsg9xqkr-1.jpg
https://static1.pt-content.com/images/pt/2015/10/20151016_104458_zps13if9s2p-1.jpg
https://static1.pt-content.com/images/pt/2015/10/20151016_112123_zpssizuildc-1.jpg
https://static1.pt-content.com/images/pt/2015/10/20151016_112132_zps5d5rbkjv-1.jpg
https://static1.pt-content.com/images/pt/2015/10/20151016_112246_zpsk9egyovy-1.jpg
Crestronwizard
10-20-2015, 11:19 PM
Great progress. How do you like that battery?
HotRod47
10-21-2015, 03:39 AM
Just now seeing this project thread. Great job on the build so far!
cspecken
10-21-2015, 12:19 PM
I have not had any experience with the battery yet. It is about the same price as a Optima Red or Yellow. The battery only weighs in at 21 lbs half the weight of the Optima. We determine that it would fit nicely up front and tucked under the front fender.
cspecken
10-23-2015, 09:15 PM
The cold air intake is almost completed. A few more welds and it should be ready.
https://static1.pt-content.com/images/pt/2015/10/20151023_131557_zps9lipzu0g-1.jpg
https://static1.pt-content.com/images/pt/2015/10/20151023_131608_zpsowtizysv-1.jpg
https://static1.pt-content.com/images/pt/2015/10/20151023_131620_zps6h3bwbix-1.jpg
https://static1.pt-content.com/images/pt/2015/10/20151023_131703_zpspu9grzqp-1.jpg
Zoomin
10-24-2015, 06:50 PM
Glad this thread came back to life. I'm in the middle of doing a 64 Lemans, lots of good ideas in here - great build.
cspecken
10-24-2015, 07:04 PM
Thank you. I hope to have a video soon of the car running!!! I think we may be a week or two out before that happens.
cspecken
11-26-2015, 07:50 AM
Quick update - Exhaust is almost completed. 3 Inch Stainless, Cross Over Pipe, Borla XRP's. Check out the exhaust tips I think they turned out nicely.
https://static1.pt-content.com/images/pt/2015/11/20151125_153836_zpst4ikgvaw-1.jpg
https://static1.pt-content.com/images/pt/2015/11/20151125_154001_zpsd3ticgeb-1.jpg
https://static1.pt-content.com/images/pt/2015/11/20151125_154005_zpsjnb9ceka-1.jpg
Motown 454
11-26-2015, 08:55 AM
It looks great I like the idea of having the CTEK installed in there. Nice work.
Zoomin
11-26-2015, 09:28 AM
Chris, everything's up there nice and tight - looks great!
Have you fired it up yet?
cspecken
11-26-2015, 12:23 PM
Thanks for the positive comments. I really like the way the battery and ctek fit nicely up front. Contemplated having everything in the trunk, but it all worked out nicely up front.
We are discussing ways to add a little support to the mufflers facing the front of the car. Looking at incorporating a drive shaft loop/hoop.
Currently, I have a few items getting powder coated, once completed the front end will go to final assembly. Fluids and fuel will be added. Hope to fire up soon. That would be a great Christmas present. I will definitely upload videos.
cspecken
02-16-2016, 08:32 PM
My Finspeed wheels showed up today!!!!! Tires will be here tomorrow.
https://static1.pt-content.com/images/pt/2016/02/20160216_144701_zpsiliocgly-1.jpg
Zoomin
02-16-2016, 09:03 PM
Great looking choice, Chris!
Size and backspace?
cspecken
02-16-2016, 10:23 PM
Size and backspace?
Front 18 x 8 - 5" BS
Rear 18 x 9 1/2 - 5" BS
LUV2XLR8
02-17-2016, 03:04 AM
Battery looks like a good fit in the fender well, where & how many grounding locations were utilized?
therobski
02-18-2016, 07:45 AM
Chris, where did you get those 2 radiator hold downs? They look like you use the GM rubber cushions on them too. Thanks....
cspecken
02-18-2016, 07:56 AM
Great question, I will find out about the ground locations. I actually do not know if they have been installed yet.
cspecken
02-18-2016, 07:58 AM
Hi, Dominator Street Rods, in Tracy Ca built them for me. And yes you are correct they incorporated the stock 64 Pontiac GTO rubber pads.
cspecken
02-19-2016, 07:47 PM
There are several ground locations in the front engine bay. Also grounds running from chassis to engine. A terminal stud located under the dash was created as a ground locations for items inside the car.
cspecken
02-19-2016, 08:03 PM
The Falken Azenis RT-615K tires were mounted today. I got the itch and had to seem them installed on the car. So I made the 40 minute journey over to my car and put them on!!!
https://static1.pt-content.com/images/pt/2016/02/20160219_140739_zpsws2zij46-1.jpg
https://static1.pt-content.com/images/pt/2016/02/20160219_140748_zpsh0hq3vms-1.jpg
https://static1.pt-content.com/images/pt/2016/02/20160219_142119_zpsyyg8ywgh-1.jpg
https://static1.pt-content.com/images/pt/2016/02/20160219_142129_zpsvtvzqie0-1.jpg
keepat
02-20-2016, 06:32 AM
Wheels look awesome on the car with the silver paint and they compliment the sharp lines of the 64 GTO nicely!
Pat
MOREHORSEPOWER
02-20-2016, 07:34 AM
That is a great looking ride !! Nice and clean .
cspecken
03-18-2016, 09:56 PM
Fired the new motor up. Sounds great. A couple of minor issues were handled and then we were in business.
https://youtu.be/L6OL-k_zzbk
https://youtu.be/0E80yVIDviE
Nicks67GTO
03-18-2016, 10:09 PM
That's awesome! Congrats on the fire up!
Motown 454
03-19-2016, 09:38 AM
Great News! it sounds sweet! Congratulation's
Roger Poirier
03-20-2016, 03:45 PM
Excellent continuous progress. Looking very good. Roger
steveZL
03-21-2016, 08:37 PM
Looks and sounds great!
What tire sizes did you go with? I'm running similar wheel sizes on my 65 Chevelle
cspecken
03-21-2016, 09:39 PM
Falken Azenis RT615K - I ordered them thru my local America's Tire Store. Timed it perfectly to take advantage of a $75 off promo they were having.
Front 245/40 R18
Rear 265/35 R18
steveZL
03-22-2016, 08:02 PM
Thanks for the info... Your GTO is looking good!
cspecken
04-01-2016, 09:35 PM
Finally put the car on the ground. Also installed NRG hub adapter, quick release and MOMO steering wheel.
https://static1.pt-content.com/images/pt/2016/04/20160401_110014_zpsxcx1rqbp-1.jpg
https://static1.pt-content.com/images/pt/2016/04/20160401_141523_zpskvpmeguo-1.jpg
wfo guy
04-02-2016, 05:49 AM
Looking good!
therobski
04-02-2016, 05:59 AM
Awesome build, and it's a "Post Car" !
Zoomin
04-02-2016, 07:20 PM
All you lack is finishing up - really looks great!
Zoomin
05-11-2016, 07:30 PM
What's been going on?
cspecken
05-11-2016, 08:06 PM
I am just awaiting for my car to be resprayed! The painter who originally laid down the color was not good. It is going on year two since it has been painted, and the owner has assured me that it will be within the next two weeks. Although that is what I have been hearing for the last year! Paint jail here we are. Once the paint is completed it is time to order some glass, and begin to wrap up the car.
PonchoJohn
12-07-2016, 12:43 PM
Any updates?
cspecken
12-09-2016, 09:17 PM
No updates. Still waiting on a repaint. Very frustrating.
