View Full Version : New c5 z06 front 13 inch brakes / rear explorer 12 inch brakes chevelle camaro nova
Chevelle598bb
09-15-2011, 03:02 AM
I am asking 1000.00 for the front and rear set up from my 71 chevelle. I got a killer deal on a new set of c6 z06 brakes so these have to go. I am just trying to get my money back. The front brackets fit 64-72 chevelle, 67-69 camaro, 68-74 nova and all the variants of those cars. The rears are a direct bolt on for any rearend using the torino or new big bearing ford nine inch housing ends. I would like to sell as a front and rear set up. I also would like to keep the kore3 brackets and drum hubs since I can use those for my new c6 set up. If I keep those I'll take 850.00 for the set up. I am on vacation currently so pm your email for pictures since I don't have my computer here but I have pics on my phone. The parts are located in Keller, Texas. Here is a list of the set up.
Fronts are c5 z06
Calipers- new c5 z06 from gm
Abutment brackets - new gm
Pads- new ceramic pads
Hardware- new gm
Brackets- new kore3 for small gm spindle
Hoses- new russell dot braided
Rotors- gm z06 cross drilled turned
Hubs- chevelle drum hubs clearanced, new studs, timken bearings
Rear brakes are 12 inch explorer rear disc
Rotors- new cross drilled with gm bolt pattern
Calipers - new ford calipers
Brackets- cleaned and painted explorer
Backing plates- cleaned and painted. They are a little wrinkled on the bottoms. They were the best I could find at the wrecking yard.
Pads- new ceramic
E brake shoes- new
Disc hardware- new ford
E brake hardware- new ford
E brake cables- used explorer
Hoses- no hoses
Bearing spacers- new currie. These are place on the inside of the caliper bracket to take up the space between the axle bearing and the retainer plate.
Almost everything is new and none of the parts have had fluid in them. I have installed the parts but they have never been used.
l_and_t_reproductions
09-15-2011, 06:43 AM
Got any pictures? I would be interested in the fronts if you want to break them up and I wouldn't need the hubs and could obviously get the adapter bracket from Tobin if needed.
Chevelle598bb
09-15-2011, 07:18 AM
Here are some pictures. I would like to sell as a package deal but will separate if no offers.
Chevelle598bb
09-17-2011, 07:23 AM
Any offers?
ryeguy2006a
09-19-2011, 11:19 AM
I would be interested in the front rotors, calipers, abutments, pads, hardware, and hoses if you would want to sell them separate. That way you could keep the brackets and hubs for your new brakes.
Ryan
Chevelle598bb
09-19-2011, 01:46 PM
Pm sent Ryan.
Chevelle598bb
09-30-2011, 10:59 AM
All items sold...
