View Full Version : F/S :lt1 t56,centerforce flywheel
69projectKAOS
09-13-2011, 01:27 PM
Im selling my used LT1 t56 with about 65-70k miles, with hurst short throw shifter. i had it in my 69 camaro for about a year behind my 383 stroker and it worked flawlessly. the only reason im selling it is because my motor blew for the second time and im going a different route as far as drivetrain goes. i also have the centerforce flywheel that is made specifically for a 2 piece rear main seal, pre1985 sbc, the flywheel is in great shape it has a perfect ring gear with no missing teeth. i have a pressure plate and ram clutch as well. i have everything needed to swap this into a car with a pre-1985 sbc. the swap includes...
t56 transmission 65-70k miles
bell housing
shifter
pressure plate
used ram clutch
fork
dust shield
hardware(nuts &bolts)
im looking to get $1500 for the swap. im located in mastic beach ny,11951 . i would perfer local pickup over shipping. thanks for looking! pm for details or questions.-Dom
https://static1.pt-content.com/images/noimg.gifhttps://static1.pt-content.com/images/noimg.gif
t/a-speedfreak
09-13-2011, 05:04 PM
Did this set up require any cutting of the floor board? What about the drive shaft, did it need modification? I'm interested.
69projectKAOS
09-14-2011, 12:41 PM
Nope the only cutting that was needed was the hole for the shifter. i have a 1 piece drive shaft for a 69 camaro that i had shortened a few inches to fit. it uses the same slip yoke as a th350. let me know if you have any other questions. -Dom
senor_camaro
09-14-2011, 03:45 PM
dude are you going LS? please tell me your going LS, that would be awesome
69projectKAOS
09-14-2011, 06:52 PM
nope! its going to be front wheel drive! hahahaaa just kidding. im not going Ls series but something a little different so keep an eye out for my build thread ;) -Dom
turbo corey
09-14-2011, 07:03 PM
will this tranny bolt up to a ls1 motor?
69projectKAOS
09-14-2011, 07:49 PM
im pretty sure it will not, because of the difference in input shaft length and thickness in the input shaft spline. sorry-Dom
t/a-speedfreak
09-15-2011, 07:17 PM
If I wasn't in texas I would take it. When I saw the post I thought you were closer. Not sure why I thought that. For kicks, what would shipping costs be?
unseenTA
11-02-2011, 02:25 PM
Taking a shot in the dark and asking if this is still available which i'm hoping it is..
njmtbrider
11-02-2011, 04:52 PM
pm sent is it still available?
69projectKAOS
11-03-2011, 07:15 AM
sorry guys its no longer available
