View Full Version : Leaking water from under glove compartment area..
lutzy
09-11-2011, 02:42 PM
I have a 69 camaro I bought with a vintage air system..after running a few minutes with ac on, its leaking water from under the glove compartment area..anyone know what this could be?
Van B
09-11-2011, 02:47 PM
It sounds like the condensation drain is plugged. Better yet, make sure the drain hose did not come off. I have had mine in extreme humidity freeze the evaporator and have the case start sweating.
Ollie8974
09-11-2011, 04:58 PM
If smells like antifreeze it's the heater core. That is where they leak.
lutzy
09-11-2011, 08:09 PM
It's water.. Not antifreeze. What
does the drain hose connect to? Never got to look under there yet
TT302Z28
09-12-2011, 05:53 AM
The will be an outlet low on the VA unit under the dash that needs to have a rubber hose attached and vented outside the car.
lutzy
09-12-2011, 02:01 PM
well silly me..theres no hose on it..I wish they were all that easy to fix..thanks!
TT302Z28
09-12-2011, 03:53 PM
That's a whole lot better than the dreaded antifreeze leak under the dash.
Van B
09-12-2011, 04:34 PM
Glad we could help!
